FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
57 registered members (2002 Maxima SE, Astro14, BAJA_05, AlienBug, 94astro, AndyB, 6 invisible), 1,134 guests, and 21 spiders.
Topics307,398
Posts5,310,379
Members71,843
TJ Wrangler Differential Oil Change #5453196 06/13/20 08:45 PM
derweed Offline OP
I changed the oil in the front and rear differentials of my Wrangler today. It has the Trac-Loc rear and I put in Mobil 1 gear oil that says has limited slip additive. The manual says to add four ounces of limited slip additive. Do I still need to?
2019 Ford F-150 5.0
2015 Mazda CX5
2014 Toyota Camry Hybrid
2005 Jeep Wrangler Unlimited
Re: TJ Wrangler Differential Oil Change [Re: derweed] #5453197 06/13/20 08:48 PM
2015_PSD Offline
Drive it a bit and see if you experience any chattering when turning. If not, you are good to go, otherwise you should add only a little at a time until it stops. You can add too much so be conservative when adding.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: TJ Wrangler Differential Oil Change [Re: derweed] #5453198 06/13/20 08:49 PM
Chris142 Offline
Try it as is. If it does not bother you leave it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: TJ Wrangler Differential Oil Change [Re: derweed] #5453518 06/14/20 08:08 AM
G
GSCJR Offline
G
No, It's already in the gear oil. Take it for a test drive and confirm.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: TJ Wrangler Differential Oil Change [Re: GSCJR] #5453737 06/14/20 01:13 PM
R
Randy_R Offline
R
No. It’s limited slip oil. I used Mobil 1 LS oil in my 04 Silverado w/G80 locking differential. Used a Kendall limited slip oil, I think it was old stock, in a 60 something positraction about 6 or 7 years ago. No additive necessary.
2018 Mazda CX-5 9000 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 70,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 Wix 51061
