Forums Migration
Please read this thread
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
96 registered members (28oz, 01rangerxl, 2K2AcuraTL, 2015_PSD, aba4430, 4WD, 12 invisible), 2,000 guests, and 41 spiders.
Topics307,633
Posts5,314,710
Members71,894
Is Mobil 1 Euro 0w-40 LSPI prone? #5453087 06/13/20 06:06 PM
M
MrStamper Offline OP
M
Read somewhere that high calcium oils can trigger an LSPI event. According to some VOAs I’ve stumbled upon, the current formulation of Mobil 1 Euro 0w-40 has close to 3000 ppm of calcium, which is quite a lot. Conversely, I’ve read that ZDDP also lowers the chance of an LSPI event, which this oil sufficiently possesses. Recently I switched from Mobil 1 EP 5w-30 to 0w-40 thinking it might be better for my turbo 2.0L Ford in the hot summers of California. Just want to make sure I’m not screwing anything up. I assume that if Audi and VW specs it for their turbos, it shouldn’t be a problem for a Ford.
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453106 06/13/20 06:23 PM
2015_PSD Online Content
Online Content
Plenty of Mercedes-Benz and BMW engines that have power factors to make them prone to LSPI that M1 Euro 0W-40 with no issues.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453139 06/13/20 06:54 PM
SR5 Offline
LSPI events goes up with Ca detergent concentration in a linear fashion.
While ZDDP quenches LSPI events in an exponential fashion, so a little more ZDDP goes a long way to stop LSPI.
This was the finding from a Infineum study
https://www.infineuminsight.com/en-gb/articles/passenger-cars/quenching-low-speed-pre-ignition/
Euro A3/B4 engine oil with all the OEMs like BMW LL-01, MB 229.5, Porsche A40 tend to carry about 25% more ZDDP than an ILSAC rated fuel economy oil (800 ppm Vs 1000 ppm being typical).
Note, look for A3/B4 and the OEMs for higher ZDDP or better yet look at a VOA analysis of the oil. I say this because I saw a VOA of Amazon Basic Euro A3/B4 and it didn’t have any Euro OEMs and it just had ILSAC levels of ZDDP.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: SR5] #5453151 06/13/20 07:28 PM
M
M
Partly soothes my paranoia and it was a reason why I went with the euro spec. It’s cool that the Europeans aren’t reducing zddp like the Americans are appearing to do. Lots of pro-zinc articles here on bitog.
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453166 06/13/20 07:53 PM
SR5 Offline
In Australia it’s very common for our oils to carry both American API specs and Euro ACEA specs, for example I have a jug of full-synthetic Castrol Magnatec 5W30 and it’s rated both API SN and ACEA A3/B4.
ZDDP is a very good additive
- it reduces LSPI events to protect the engine
- it’s an anti-oxidant that protects the oils itself for longer oil life and OCI
- it’s an anti-wear agent that protects the metal of the engine when the oil film breaks down
I think the Euro OEM level of around 1000 ppm is spot on for most applications.
Sure the Phos in it can damage exhaust cats in an oil burning car, yet Europe has been running this level of ZDDP for decades without issue.
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453195 06/13/20 08:40 PM
U
UG_Passat Offline
U
Tell that to my engine that used VW 502.00 (ACEA B3/B4) oil for 100,000 miles that died of piston skirt damage from LPSI.
2016 VW Tiguan
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453211 06/13/20 08:59 PM
R
Rand Online Content
Online Content
R
where are you seeing a recent m1 0w40 VOA?
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453227 06/13/20 09:27 PM
donnyj08 Offline
A great alternative is PP 0w40 SN+. LSPI protection and A3/B4
2008 Silverado LT Z71 104k PP 10w30
2016 Tucson Limited 1.6T AWD 38k PP 0w40 SN+
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453260 06/13/20 10:11 PM
edyvw Offline
Low calcium oil is band aid to LSPI issue. You are paying attention on oils here in the US. However in Europe, all vehicles, gasoline or diesels are running on oils that have low ZDDP levels. For example in the US BMW is still using LL01 in its gasoline engines, but in EU they are using LL04 since 2009, yet they do not have LSPI issues. Only known LSPI issue in Euro engines was first generation 1.4 turbo/compressor engine in VW. But VW resolved that quickly.
However, you have to take into consideration that European manufacturers are way ahead in so called "downsizing" game than American or Asian companies.
Also, 2.0 ltr engines are not as prone to LSPI. LSPI is primarily problem in engines 1.6ltr and lower displacement. 2.oltr engine in 2020 that has LSPI issue is poor engineering, there is no way around that. Personally, your choice of oil is good as Mobil1 0W40 FS is almost 0W30 oil. It is very light W40 oil.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: Rand] #5453292 06/13/20 10:38 PM
M
M
I found a VOA on the internet, but it’s not very recent. It’s from 2016. Comparing it to one from 2013, it had lower calcium so I figured it was an updated formula. Been trying to find a 2020 one but it’s non-existant lol
https://m.imgur.com/714HbQ2
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: UG_Passat] #5453296 06/13/20 10:46 PM
M
M
Were you boosting regularly in the low rpm range?
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: edyvw] #5453305 06/13/20 10:53 PM
M
M
I think you’re on to something. In the ford community LSPI is almost unspoken of, though it is feared. For example on the focus St forums it’s the bogeyman but the common factor for blown engines is aftermarket tunes. If I remember correctly, GM developed their Dexos tests due to the 1.6L ecotec blowing up. The Ecoboost is better platform in that regard. Heck, Ford specs semi-synth in-house Motorcraft for their EcoBoosts
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: MrStamper] #5453320 06/13/20 11:17 PM
edyvw Offline
Both Ford and GM have some know-how from their European brands. So, both have more experience with turbo applications than Asian manufacturers where LSPI is common in some brands. Also, Focus ST issue is not LSPI, it is open deck architecture of an engine. That architecture is really not good for such hp per 1ltr of displacement. BMW for example never wanted to bump radically hp in its 3.0 ltr engines as they are open deck. When they developed S55 engine for M3/4 F30 generation, they went back and changed the block. New BMW B generation engines are closed deck bcs. they are modular, and they will have versions running 500+hp from factory. So, Focus ST issue is actually much bigger than LSPI.
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: edyvw] #5453368 06/14/20 01:50 AM
K
Kamele0N Offline
K
EcoBoosts
Both Ford and GM have some know-how from their European brands. So, both have more experience with turbo applications than Asian manufacturers where LSPI is common in some brands. [/quote]
"Asians" also "bought" those expiriences....topic is from 2015 btw
https://www.bmwblog.com/2015/11/14/hyundai-i30-n-to-spawn-new-division-run-by-former-bmw-m-boss/
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Is Mobil 1 Euro 0w-40 LSPI prone? [Re: Kamele0N] #5453369 06/14/20 01:51 AM
K
Kamele0N Offline
K
EcoBoosts
