Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
26 registered members (Alaskanmont, BigGeo, AlienBug, caprice_2nv, Char Baby, 4WD, 3 invisible), 594 guests, and 25 spiders.
Topics307,389
Posts5,309,631
Members71,821
Blow out a well #5453010 06/13/20 04:26 PM
SHOZ Offline OP
My well has a supply problem with any large demand. It's not water level. 60 years old. I assume it needs blown out.
Blowing out a well as I understand it you pump air down and then suddenly release it spew all the crap out and pushing the aggregate away from the point, is this correct?
So I assume you need the top of the casing exposed. The pipe actually coming from the well has a check valve on the end so nothing can be forced down that. It's a shallow well pump with one 1" pipe feeding it.
The well head is buried but I know it is 54' from the pump as measured with a fish tape shoved down the 1" feed pipe til it stops. Using a metal detector I think I found where it is.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Blow out a well [Re: SHOZ] #5453018 06/13/20 04:48 PM
Chris142 Offline
The casing gets full of sediment. I asked about having mine cleaned out and was told that doing so would likely collapse the old and rusty casing.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Blow out a well [Re: SHOZ] #5453062 06/13/20 05:44 PM
samven Offline
If its a shallow well just start planning on replacing the casing. Then you can have someone try to blow it out with the expectation that you will have to replace it. I am not looking forward to those problems as mine is 400 ft deep and its going to cost me big.
Re: Blow out a well [Re: SHOZ] #5453099 06/13/20 06:19 PM
W
walterjay Offline
W
I recommend that you consult with a local well driller. Different areas of the country are prone to specific problems. I think that a well driller could give you some valuable information. See if there is an older driller in your area. They know a lot.
Re: Blow out a well [Re: samven] #5453100 06/13/20 06:19 PM
Chris142 Offline
I hear ya. Mine is 300 ft deep. Local price is $62/ft to redrill.
Re: Blow out a well [Re: SHOZ] #5453114 06/13/20 06:29 PM
SHOZ Offline OP
The well is 125' or so and in sand. Good supply. There is a neighbor drilling a new well next door so I'm going to check them out to see what they say.
Re: Blow out a well [Re: SHOZ] #5453123 06/13/20 06:40 PM
R
Rand Offline
R
you say its shallow, then you said it has a 1" pipe feeding it.
then 54'
then 125'
Is this a submerge pump or jet pump? Can you clarify so we have a better idea of the actual setup.
Re: Blow out a well [Re: SHOZ] #5453124 06/13/20 06:42 PM
SHOZ Offline OP
Yes, it's a 4" 125' casing with a shallow well pump. 54' horizontal until I hit what I believe to be the well head. I do not know really how deep the foot valve is.
I can set my metal detector to find iron about 4' down when I calibrate it to the wire in the sidewalk. And it's going off in the area of 54'.
Re: Blow out a well [Re: SHOZ] #5453152 06/13/20 07:28 PM
R
Rand Offline
R
so there is a jet well pump in your basement?
I have never seen one past 25ft depth with a single pipe usually
they have 2 pipes and neither is 1"
Re: Blow out a well [Re: SHOZ] #5453206 06/13/20 08:53 PM
SHOZ Offline OP
1" plastic. Standard around here. I would not doubt the foot valve is 25' or so vertically deep. Pump is in the crawl space.
Re: Blow out a well [Re: SHOZ] #5453209 06/13/20 08:58 PM
danez_yoda Offline
i dont think the fracking truck are busy now, smile.
