Forums Migration
Please read this thread
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
35 registered members (07hemi, Dallasmale1970, bmod305, cknight49090, 5 invisible), 867 guests, and 25 spiders.
Topics307,582
Posts5,313,562
Members71,876
Well that went well #5452954 06/13/20 02:59 PM
supton Offline OP
Decided it was time to change the ATF in the truck--I flushed most of it at 80k, and it's 80k later, so it's time. It's a sealed transmission so filling it should be the hardest part, right?
I didn't remove the pan so no headaches there (did last time, and this time the fluid is only a bit dark, no worries). Pulled the cooler line and did a full flush. Did the procedure to set the level, back the truck out of the garage, and... find a crush washer in the drain pan. Go outside, try to put the crush washer on (it was for the check port) but of course half quart comes out. Pull forward and repeat process.
Go to write it in the log and hey it's been 10k since an oil change. Fight with the stupid skidplate, get the drain pan set right and ... mini geyser, right out of the pan, all over the tire and the garage floor. At least a quart on the floor I've changed oil on the this truck at least 8 times, using this pan, never had a problem--not until today. Killed a few brain cells cleaning up the mess with brake fluid.
Wife is never going to let me use her side of the garage again.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Well that went well [Re: supton] #5453000 06/13/20 04:17 PM
R
Reddy45 Offline
R
We all have those kind of days.
Re: Well that went well [Re: supton] #5453003 06/13/20 04:19 PM
Z
ZeeOSix Offline
Z
Can you elaborate some on how you did the flush.
Re: Well that went well [Re: supton] #5453011 06/13/20 04:27 PM
bdcardinal Offline
Le sigh. That usually happens to me when I try to work too fast.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Well that went well [Re: ZeeOSix] #5453032 06/13/20 05:02 PM
supton Offline OP
First I cracked the fill plug, drain plug and check plug, to make sure all would come loose. I snaked a 1/2" ID / 5/8" OD down through the engine bay and shoved a funnel in. Drained and then filled the pan--supposedly it holds 4 quarts but I think that is if you drop the pan (which I didn't).
Then I overfilled by 1 quart. I pulled a cooler line, hooked up 3/8" ID / 1/2" OD hose and would let the engine run 1-2 minutes and it would pump out 2 quarts. Shut down, add 2 quarts. Something like 11-12 quarts on this Tundra, so I went until I had gone through 11 quarts.
Then did the check procedure for the Tundra. I was pretty sure I was close on quarts through the PVC tubing, so I used one of those small lift pumps that go into a quart bottle while under the truck--I removed all the PVC for level checking. The PVC isn't rated for any heat but it has to run real close to the exhaust system, and the ATF has to warm up quite a bit to the right temperature.
Snaking down the engine bay, trying to steer clear of exhaust:
[Linked Image]
Front of radiator, showing the line I pulled:
[Linked Image]
Edit: in the last photo there is a pair of vice-grips pinching shut the hose going down to the transmission. Not sure if required. When I did this job the first time a few years ago I pulled the wrong line and I was hoping to avoid the same mistake twice... not sure vice grips would have prevented a mess but it was worth a shot.
Re: Well that went well [Re: bdcardinal] #5453035 06/13/20 05:03 PM
supton Offline OP
I wasn't even working all that fast. Just my luck I guess. Thankfully it cleaned up well.
Re: Well that went well [Re: supton] #5453064 06/13/20 05:45 PM
E
ecotourist Offline
E
I have a large cardboard sheet that I put under a vehicle when I'm changing fluids. Makes lying on concrete easier, and collects drips, squirts, splashes, gushes, etc. I aim to do a completely "dry" change but somehow a little bit escapes no matter how careful I am.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Well that went well [Re: ecotourist] #5453077 06/13/20 05:57 PM
supton Offline OP
I did that with the transmission, forget if I had any for the engine oil. It would not have helped though: the oil came out, hit the pan, and then splashed onto the tire. It then ran down onto the floor. I guess I needed a funnel or something.
Re: Well that went well [Re: supton] #5453220 06/13/20 09:10 PM
W
WyrTwister Offline
W
I think I would have used petroleum based paint thinner to clean up . In my younger / wilder days I would have used gasoline .
Wyr
God bless
Re: Well that went well [Re: supton] #5453226 06/13/20 09:24 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Sometimes you have one of those days.
Ive found Japanese vehicles often have poor locations for drain plugs and filters compared to domestic and German cars, fwiw.
Re: Well that went well [Re: supton] #5453324 06/13/20 11:27 PM
dave1251 Offline
Don't beat yourself up for this. It happens. Tomorrow should be a better day. One day it will get better.
don't use.
Re: Well that went well [Re: dave1251] #5453400 06/14/20 04:08 AM
bachman Offline
thumbsup
I had an Olds 403 that felt sluggish and decided to have a buddy and his friend do some stuff in the early 80's. Went to dual exhaust with headers, and a dist. curve kit. In doing the headers, one of the guys broke off the engine oil dip tube so I could never really check my oil again. frown
From then on, I'd add a quarter quart around 1500 to 2000 miles and then change it out at 3500 mi.
It's not terrible being unhandy at DIY car stuff as I am on many things car but it kinda bites when the guys doing the work screw it up ... and even that wasn't too bad once I realized the plan around it. My car still felt like a dog but it sounded nice. duh
95 Honda Nighthawk- Rotella T6 syn
17 Golf SW 4MO dsg- Dealer LOF/5-6k *New spec syn -VW/Audi XOM ?
16 Mazda CX9 Tour- Dealer LOF/5-6k Casterol full syn
Re: Well that went well [Re: supton] #5453523 06/14/20 08:15 AM
supton Offline OP
Oh I'm not mad about it. Sure wasn't happy about it at the time, and it's not really laugh-worthy, but it was a slow day on BITOG so I felt like posting. smile
I still haven't figured out the geyser--I've changed the oil at least 8 times, using this same drain pan. Never an issue. This was the first time with a warm engine though, maybe that was the problem. Nah, it was because it was the first time I wasn't parked on dirt, and instead parked on something I didn't want oil on, that must be it...
Next time I need an oil change I'm going to order a bunch of stuff from Amazon so I can line the garage in cardboard.
Re: Well that went well [Re: supton] #5453640 06/14/20 10:33 AM
Delta Offline
I manage to make a mess every oil change on the Tacoma with the drainplug strait on the bottom. Like you, it winds up everywhere no matter how I try. Splashes outta the drain pan with force. I'm done with the drain plug on that thing and will be using my extractor from now on.
Far as the transmission, I'll gladly pay the dealer $300 every 80-100K for a fluid exchange. Takes about an hour and I can eat all their provided snacks/sandwiches while I'm waiting... LOL
'17 VW GTI 2.0T - 6MT - 22K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 27K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 142K - RGT 5w30
Re: Well that went well [Re: supton] #5453662 06/14/20 11:06 AM
R
RichR Offline
R
Not that you were working too fast.
I had a Tundra and everytime I changed the oil
it would splatter out of the pan due to the placement of the drain plug. I hated oil changes on that truck.
I guess a Fumoto would help to slow the gusher but that's a whole different thread. grin2
A co-worker said
I have an oil fetish
