Forums Migration
Please read this thread
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
107 registered members (4WD, 2015_PSD, AdamZ, 28oz, 2004tdigls, 77GrandPrix, 13 invisible), 1,989 guests, and 58 spiders.
Topics307,640
Posts5,314,823
Members71,897
99 Dodge Ram 2500 v10 issue #5452850 06/13/20 11:55 AM
B
Blazelavell Offline OP
B
I just bought this truck a little over a month ago it had a code for a bad injector on cylinder 2 which was dumping raw fuel into that cylinder which would to flood to the exhaust and cause flames, I replaced it and it was still having its issues so I ordered an ecm for it (which a mechanic I took it too told me was bad) Fast forward to a month later got the ecm put it in and truck runs amazing when cold once it warms up the truck idles funny sitting and when driving it’s backfiring and has very little power. I’ve gone to the back end of the truck and looked into the muffler when this is happening (half my muffler has rusted off at the end so it starts at the fat part of the muffler just after the catalytic converters) and when I look into it I can see on the left side it’s glowing orange/red. When it’s not acting up it’s not glowing. Could this be a bad or clogged cat? What could be causing this issue if not the cat?
Re: 99 Dodge Ram 2500 v10 issue [Re: Blazelavell] #5452897 06/13/20 01:10 PM
J
junk1020 Offline
J
Raw fuel is REALLY hard on converters. How much has it been run since the ECM was replaced? If it's red hot, it's either 1) full of unburned fuel it hasn't gotten rid of, 2) plugged, or 3) a combination of the two. I've seen plenty of bad converters that run OK cold and will barely run at all when warmed up, and that would be my guess here is that it's plugged and needs to be replaced.
2011 Hyundai Sonata, Castrol Edge 0w40, Hastings LF565
2017 Toyota Sienna, Castrol Edge 0w20, Hastings LF607
2018 Hyundai Sonata, Mobil 1 5w30, Hastings LF565
Re: 99 Dodge Ram 2500 v10 issue [Re: Blazelavell] #5452902 06/13/20 01:23 PM
E
eljefino Offline
E
You could have had a cat partially die and had its guts blow through until they got caught in the muffler.
