Originally Posted by JohnG
Word of caution. 1 hp is a pretty big motor for a 110V application, make sure you have the wiring to support that load. I don't think 14 ga. will do the trick unless it's a dedicated circuit (like no dishwasher on it too). I know the motor won't be running full current draw, (like 16 amps) but just be sure that it meets code.
14 ga. COPPER is only rated for 15 amp circuit breakers.
1 HP = 746 W. P = IV. 746 W/120 V = 6.x A, which is not excessive for a 14 AWG/15 A circuit. (15 A circuits are typically rated for 15 A peak and 12 A continuous load.)
But, I don't know what the actual current draw, peak or steady state, of a nominal 1 HP motor would be. Perhaps peak would be a lot higher.
