Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
111 registered members (55hambone, 2015_PSD, 4WD, 1WildPig, 2015Corolla, 08z06, 12 invisible), 1,897 guests, and 21 spiders.
Topics307,462
Posts5,311,600
Members71,850
Noisy Mower Pull-Cord Spool #5452648 06/13/20 08:12 AM
V
viscous Offline OP
V
The pull-cord spool on top of my 6HP B&S makes a loud metallic rattle while the engine is running. It sounds like there may be some interference with each rotation of the spinning cooling system, but nothing appears bent out of place. Slowly pulling the cord while the engine runs makes an especially loud screech, and sometimes this causes a momentary cessation of the rattling. Importantly, the rattling began when I bumped the front of the engine (not the spool or spinning part) into an obstacle. I removed the plastic cover to inspect for damage, but nothing appears wrong. Has anyone else experienced this? Any remedies?
Re: Noisy Mower Pull-Cord Spool [Re: viscous] #5452668 06/13/20 08:37 AM
P
Padawan Offline
P
It sounds to me like the springs that retract the "fingers" on the starter mechanism when it's not being pulled are either stuck, have partially failed, or gotten some debris wedged in them. If the mechanism isn't riveted together, you should be able to unbolt it and inspect them pretty easily.
Re: Noisy Mower Pull-Cord Spool [Re: viscous] #5452824 06/13/20 11:24 AM
Yah-Tah-Hey Offline
Probably debris keep pawls from retracting. Usually an easy fix.
Re: Noisy Mower Pull-Cord Spool [Re: viscous] #5452888 06/13/20 12:50 PM
E
eljefino Offline
E
There are a couple screws holding the pawls-and-circle-thing together. Loosen them slightly.
If you take this gizmo out, its clockspring will go sproing and you're in for a minor treat resetting it and getting the tension right if you haven't before.
Re: Noisy Mower Pull-Cord Spool [Re: viscous] #5452891 06/13/20 12:53 PM
M
mk378 Online Content
Online Content
M
How hard was this "bump?" If the whole cover is pushed back, the starter won't be centered on the engine shaft, and that would make it drag.
Very old models have a ball clutch that requires periodic greasing.
Re: Noisy Mower Pull-Cord Spool [Re: mk378] #5452978 06/13/20 03:38 PM
V
viscous Offline OP
V
Originally Posted by mk378
...How hard was this "bump?"...
Firm, but it doesn't appear to have done any damage. It didn't appear to push the whole cover back.
