How To Remove Overspray On Aluminum Wheels?
by NDL - 07/02/20 07:16 AM
Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Bazza32, Klink_II, williamshrader, 96JeepXJ, TxVet33
71826 Registered Users
77 registered members (alarmguy, 55hambone, AndyB, anpconnors, aircooled, 94astro, 6 invisible), 1,077 guests, and 29 spiders.
Topics307,391
Posts5,309,665
Members71,826
HDEO w/o API Gas Rating in Mower? #5452647 06/13/20 08:11 AM
V
viscous Offline OP
V
Many here report using 15W-40 or other HDEO in gas-powered lawnmowers. For this application, is a gas API service rating (e.g. SN) necessary, or is diesel engine oil sufficient?
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452655 06/13/20 08:18 AM
simple_gifts Offline
The API grades of SM, SN, were developed for catalyst protection, so I avoid using them in OPE. I have been using Rotella T5 10w-30 (diesel oil) in OPE calling for 30 weight.
2004 Prius; 131K; ATM
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452677 06/13/20 08:45 AM
A
ARCOgraphite Offline
A
What Mower?
Push Mower - run anything.
Riding mower, lawn tractor.you can - and should get more picky.
Rotella T4 10w30 has been the defacto standard in ODPE for ages.
Got to be specific.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452689 06/13/20 08:53 AM
R
Rob_Roy Offline
R
Most HDEO also carry a certification for gasoline use, and many are suitable for non-catalyst gasoline engines even if they no longer carry a gasoline API stamp. Rotella is a good example:
https://www.bobistheoilguy.com/foru...a-no-longer-gas-engine-rated#Post4464931
Is there a particular oil you are considering?
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452748 06/13/20 10:01 AM
CT8 Offline
.. Peruse the uoa sections and the virgin oil section and look at the additives used , ponder your findings.Report back.
2015 F150 2.7
2018 F350 6.2
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452769 06/13/20 10:30 AM
B
Brian123 Offline
B
The most important thing to do with a lawnmower is to check the oil level before each use. A 15W-40 may use less oil than a 10W-30 motor oil, but my oil temps run about 210 degrees during the summer so I see no need for a thicker oil. I also use the mower a few times when it is cold out and I feel the mower will start easier with 10W-30 versus a thicker oil.
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452910 06/13/20 01:40 PM
B
bchannell Offline
B
This has been discussed a lot, and I really don't think it's a big deal using it in OPE. I have to admit I feel better with the cert, but I really think, such as the case with some of the Rotella oils, they simply don't want to pay for the testing for the cert for gas engines when there's tons of oils out there to choose from for that cert.
I use 15w40 oil in my gas tractor, now for a long time, and it's a great choice.
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5452982 06/13/20 03:50 PM
V
viscous Offline OP
V
Originally Posted by ARCOgraphite
What Mower? Push Mower - run anything.
Yes, a push mower.
What should I look for? Phosphorous? No need to worry about catalytic converters in a push mower, you mean?
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5453024 06/13/20 04:55 PM
CT8 Offline
Yes, a push mower.
Yes and zinc etc. The oils will be fine.
2015 F150 2.7
2018 F350 6.2
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5453075 06/13/20 05:54 PM
B
Bighorn2500 Offline
B
I run 5w40 Mobil Delvac 1 or Rotella T6 in my 1996 Kawasaki powered John Deere and in my 5hp B&S powered DR string trimmer. No issues at all, run smooth.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5453580 06/14/20 09:24 AM
J
jeepman3071 Online Content
Online Content
J
For small engines, you could literally walk into an auto parts store, close your eyes, and any oil you pick will probably work just fine. I work on small engines on the side, and I've seen 20 year old mowers where the oil has never been changed and they don't even smoke or burn oil somehow. Changing it will certainly make it last longer, but they aren't picky. Keeping the oil full on small splash lubricated engines is more important than the viscosity used.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (62k) - Liqui Moly 5w40, MANN HU816X
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5453973 06/14/20 07:33 PM
V
viscous Offline OP
V
Thanks everyone. Sounds like any diesel oil will work fine.
Re: HDEO w/o API Gas Rating in Mower? [Re: viscous] #5453983 06/14/20 07:54 PM
4WD Offline
Mowed today at 93F … recently changed from 5w30 to some old Delvac 15w40 CK …
19 HP Briggs never ran better …
