Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
14 registered members (GMguy84, Danno, blufeb95, Brynjaminjones, edhackett, domer10, 1 invisible), 628 guests, and 38 spiders.
Topics307,388
Posts5,309,617
Members71,821
If one catalyticn converter goes bad is the other not far behind? #5452552 06/13/20 05:07 AM
N
Navi Offline OP
N
I replaced one catalytic converter at 114000 miles...the left one or "Bank 2"...should now I be looking at the right one or "Bank 1" as suspect? Should I be ordering the right cat getting it ready for the next episode?
Re: If one catalyticn converter goes bad is the other not far behind? [Re: Navi] #5452560 06/13/20 05:43 AM
T
Trav Offline
T
No necessarily, the real question is what caused the cat to fail? Something like higher misfire count, running lean on one cylinder causing that bank to dump more fuel in an attempt to bring it to stoichiometric on that bank among other things could be the root cause and if not not corrected the new one may also have a shorter lifespan.
Re: If one catalyticn converter goes bad is the other not far behind? [Re: Navi] #5452565 06/13/20 05:55 AM
N
Navi Offline OP
N
I suspect the cat failed as a result of #6 fuel injector going bad causing misfire. However before that situation I waa hearing noise come from the left cat as if sand or pebbles was inside. So I cant be certain if the fuel injector going bad caused the cat to go bad or vice versa.
In other cars I owned the cat went bad when the car reached a certain point after 100k miles. For a Toyota Solara 4 cylinder it was 160000 miles and that was cheap using a RockAuto sourced aftermarket version. For the Suburban Chevy made you buy both cats at the same time and this occurred after 120k. Both times there wasnt another obvious event which seemed to cause it.
Also I had the spark plugs and wires replaced after the cat went bad because of the miles on the truck and as preventative maintenance...just in case that had anything to do with it.
Re: If one catalyticn converter goes bad is the other not far behind? [Re: Navi] #5452590 06/13/20 06:48 AM
PimTac Offline
The bigger question is, with all the problems you’ve had with this vehicle and all the time it has spent in the shop, when are you going to decide it’s time to dump it for something more reliable?
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: If one catalyticn converter goes bad is the other not far behind? [Re: PimTac] #5452672 06/13/20 08:41 AM
N
Navi Offline OP
N
These cars I have were going to be replaced this year. That was the plan back in February but as a result of the current times Im not exactly certain. I will be thinking hard about this during the current week. Business volume is 1/4th of what it was pre-pandemic. There have been signs its picking up but its nothing what it was back in February. Thus Im confronted with a situation of making the cars last as long as possible or replacing them and incurring debt...etc...
I will do that analysis, however, right now I need to make sure the cars are working right AND try to squeeze more life out of them like through lowering the operating temperature and of course thicker oils and such. Also more conservative driving, etc...
Re: If one catalyticn converter goes bad is the other not far behind? [Re: Navi] #5453367 06/14/20 01:49 AM
A
Anduril Offline
A
Driver's side cat on my XTerra was killed by a misfire. Passenger side is still good with 178k on it. I'd only replace the one that's bad, and fix what caused it if you can figure it out.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
