Forums Migration
Please read this thread
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
30 registered members (07hemi, E365, Dallasmale1970, dishdude, 4 invisible), 864 guests, and 25 spiders.
Topics307,582
Posts5,313,562
Members71,876
Mazda FL22 Coolant / antifrezze Q's #5452361 06/12/20 07:12 PM
M
mossietheno1 Offline OP
M
HI all,
I just bought my first car (Mazda 3 DV6C 1.6 Diesel) and I don't know much about coolant.
I tried to do some research and got very confused based on the color and the tech behind them and how some are universe and some are not meant to be mixed.
I know my mazda requires the ford/mazda FL22. My main questions are?
1. Is there a way of finding out what coolant is in a car? I can see my coolant is green which is the color most of the FL22 are but I want to be sure.
2. Do all of the collant marked as FL22 have the additives required to help stop the damage from cavitation? Or is this not a issue with my engine, I'm used to hearing that bigger diesel require these additives.
3. Is it better for me to use a FL22 coolant or a general coolant like Perstone.
Thanks in advance
Mossie
Corolla 4zz-fe [1] 6 Month OCI Will do
Corolla 1nd-tv [1] Moving to better
530D M57D30TÜ [1] Will do
107 1kr-fe [1] Moving to better
Mazda 3 Diesel DV6C, New to me
[1]Castrol C3 5W-30
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5452459 06/12/20 09:27 PM
P
Popsy Offline
P
I'm not going to help...I just use original Mazda FL22 in my Mazda, and call it a day.
$22 a 4L jug at the dealer, that's not much over "Traditional" Prestone or similar at Walmart, and less expensive than other brands' FL-22. Keep in mind I don't have a ton of alternative choice where I live.
Other car I just use Motul Inugel Optimum, but they don't require anything specific.
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, M1 TDT 5W40 | Colt Ralliart, 300V 0W40
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5452605 06/13/20 07:16 AM
P
pbm Offline
P
Mazda FL22 is a P-HOAT coolant that doesn't contain 2-EHA (which is found in Prestone and most Dexcool clones).
If you can't find FL22 you could look for Pentosin A2 which is much the same...if you can't find the Pentosin...any Asian
vehicle approved coolant would be similar to FL22. The Japanese manufacturers do not like 2-EHA....while European
makers usually do....
'Journalism is Dead'
Re: Mazda FL22 Coolant / antifrezze Q's [Re: Popsy] #5453020 06/13/20 04:51 PM
M
M
Thanks for the replies,
Popsy thanks for the message It good to see that I wont have any problems if it right cold here(-10C).
pbm, regard your first line "Mazda FL22 is a P-HOAT coolant that doesn't contain 2-EHA (which is found in Prestone and most Dexcool clones)" does this mean it would be better for me to use FL22 over the Preston universal. I am tying my best find any of it but its hard to find here.
[1]Castrol C3 5W-30
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5453092 06/13/20 06:10 PM
P
Popsy Offline
P
This is what I can get at my local Mazda dealer, it's given for -43°. The only other FL-22 I found was given for -37°, which is ok since we don't get much under -30° usually.
[Linked Image]
I wouldn't use a universal type in your Mazda. I wonder what PSA is using. They have a red/pink fluid with some PSA approval, from memory.
You can always call a Mazda dealer and ask for price, if you're as lucky as me you could be surprised (this is valid for transmission fluid too, you never know!).
I don't know if that's relevant but I recently changed the water pump of my 2,3 (13 years and around 185k Km at that time) and there was barely any deposits or cruds with what I assume was the factory coolant. Maybe that's the case for every modern type coolant, I'm more used do deal with antiques so YMMV.
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5460882 06/23/20 03:23 PM
M
M
I haven't found any test to tell me if my green coolant is a P-HOAT coolant. I am just going to leave it and forget about it for now.
Was reading through why some EU made cars use OAT[1] or other and Asian cars use P-HOAT.
Thanks Popsy, really good to known about the price of ATF fluid as I am doing a flush of the power steering fluid is dexron II or Mazda M-V and gearbox oil which ford's M2C200-D2 if anyone else looking for this car.
[1] https://citroenc3owners.com/tips-fo...IHeEFxFUHEy9tHlV10zKwAAZh4RuUhf6pEfJIzag
[2]http://forums.tdiclub.com/showthread.php?t=464575&page=6
[1]Castrol C3 5W-30
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5460985 06/23/20 05:58 PM
P
pbm Offline
P
I would prefer the P-HOAT in a Japanese car because the Japanese manufacturers don't like 2-EHA (which is a plasticizer known to soften certain gaskets (usually older gaskets before manufacturers upgraded them). I think P-HOATs like FL-22, Pentosin A2, Zerex Asian etc....are some of the best coolants on the market....sort of the best of both world's....The Mazda dealer's should carry the FL-22....
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5461291 06/24/20 07:40 AM
V
VQ35DE Offline
V
I only use FL-22.
2017 Mazda CX-5 GS AWD
2018 Mazda 3 GT
2020 Toyota 4Runner Limited Nightshade AWD
2007 Chevrolet Colorado ZQ8
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5465424 06/29/20 07:44 AM
P
pbm Offline
P
I changed the coolant in a friends KIA yesterday using Pentosin A2 purchased at AA.
It mentions being a replacement for Mazda, Kia, Hyundai, Nissan and others. It is a P-HOAT
according to Pentosin's website. It's also a nice blue-green hue like the OE stuff.
If I owned a Mazda...that's what I'd use because it comes in a concentrate.
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5465705 06/29/20 02:26 PM
L
larrymoencurly Offline
L
Apparently Ford VC10-A2 is the same as Mazda FL22, only cheaper and available as 100% concentrate.
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5465706 06/29/20 02:28 PM
L
L
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5465735 06/29/20 03:19 PM
DBMaster Offline
Peak Final Charge is what I will use if I ever change mine. I've been using RMI-25 (add 4oz every 15,000 miles) to the FL22 in my 2012 Mazda3 since new and I don't ever plan to change the coolant unless I have to replace hoses or the water pump.
Re: Mazda FL22 Coolant / antifrezze Q's [Re: larrymoencurly] #5465782 06/29/20 04:23 PM
bdcardinal Offline
You are correct on both points. It is only available as 100% concentrate from Ford. Funny part is when I go to order it instead of saying "coolant/anti-freeze" in the description, it says 77-508e-20 which is a partial Mazda part number.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5467786 07/02/20 10:55 AM
M
M
Thanks all for the comments and the part number that will be helpfully when i go to change it later.
I will try to see if threes away of checking what coolant but i think I will leave if I cant find you what type it is.
My local Mazda Dealer does not stock any of the fluid but I have time il keep asking around and i'll find before I need it hopefully.
[1]Castrol C3 5W-30
Re: Mazda FL22 Coolant / antifrezze Q's [Re: mossietheno1] #5469342 07/04/20 10:38 AM
M
Marcozi Offline
M
Why not have the dealer order the coolant?
