Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
50 registered members (alex16, ArrestMeRedZ, Alaskanmont, Alex38, bbhero, 3 invisible), 843 guests, and 21 spiders.
Topics307,436
Posts5,311,036
Members71,848
Irrigation system leaking, need help. #5452260 06/12/20 03:43 PM
L
LeakySeals Offline OP
L
I have a 6 zone irrigation system running off the well. This part is leaking. Plastic tee with a cap is cracked. What is it called, what is it used for? [Linked Image]
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Irrigation system leaking, need help. [Re: LeakySeals] #5452274 06/12/20 04:04 PM
H
hemitom Offline
H
possibly a back flow preventer ??
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: Irrigation system leaking, need help. [Re: LeakySeals] #5452278 06/12/20 04:13 PM
N
Nukeman7 Offline
N
It appears to be a simple PVC barbed Tee fitting with a NPT threaded plug in the middle like these items:
Barbed & Threaded Tee
PVC Threaded Plug
Removing the plug allows the system to be drained below the frost line in the winter to prevent ice from bursting the system. Some owners will connect compressed air to ensure the majority of the water is adequately purged.
Re: Irrigation system leaking, need help. [Re: Nukeman7] #5452280 06/12/20 04:17 PM
dlundblad Offline
PVC Threaded Plug
X2 ^
You should be able to reuse one or the other depending on what is cracked. I know those plugs can be easily torqued and cracked.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Irrigation system leaking, need help. [Re: LeakySeals] #5452309 06/12/20 05:31 PM
R
Rand Offline
R
sounds like it didnt get drained and blown out in the winter?
as mentioned its the port to winterize your system.. should be an easy replacement goto any big hardware or menards, lowes, home depot etc.
sometimes those can be a real bear to get apart if they are barbed type. might need to shorten the hose by a inch or so to get it off..
last time I gently heated it and it worked.. time before I couldnt get it to seal right.. all kinds of ways to fix it though .. nothing major.
Sometimes you can just hercules them apart.. carefully. I deal with them alot in well jet pump/tank installation.
Re: Irrigation system leaking, need help. [Re: Rand] #5452365 06/12/20 07:25 PM
T
tbm5690 Offline
T
Are you saying that's where you are supposed to hook up the compressor hose? If not, not sure why you would need that there at all with the standard ball valves to use to empty the system up by the breaker.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport/Tech
2007 Honda Shadow Spirit VT1100C
Re: Irrigation system leaking, need help. [Re: LeakySeals] #5452396 06/12/20 08:16 PM
AZjeff Offline
First, interesting you run irrigation in NH.
If you've lived there for a while and have no idea what that is for and never needed to use it for anything.... take it out?
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Irrigation system leaking, need help. [Re: tbm5690] #5452483 06/12/20 11:06 PM
L
Linctex Offline
L
Typically.
In areas that experience hard frost below the surface, you have to blow all the water out of the lines before they freeze solid.
Re: Irrigation system leaking, need help. [Re: Linctex] #5452619 06/13/20 07:38 AM
T
tbm5690 Offline
T
Typically.
Yep I get that, my system gets blown out every fall but I've got a valve in-ground located nowhere near the vacuum breaker that is used for the compressor input, and it's huge. I've never seen a small cap-style like this so close to the breaker.
Re: Irrigation system leaking, need help. [Re: Rand] #5453119 06/13/20 06:36 PM
L
L
You were right no way I could get that barbed fitting out of the aged pcv pipe so I cut it off. The tee was split underneath.
[Linked Image]
Both times I was at work when they blew out the lines so I never actually saw where they connect. There's nothing in the box but the manifold and 6 solenoids. Do they attach at the arrows in this pic? Not sure what they do.
[Linked Image]
