Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Turboman92, TrustyAutos, TacoFergie, electro, SilentC
71852 Registered Users
108 registered members (72te27, 2010Civic, 18LateModelFan, 14Accent, 4WD, 9 invisible), 1,805 guests, and 25 spiders.
Topics307,463
Posts5,311,619
Members71,852
how to make AC cold or even colder? #5452098 06/12/20 12:27 PM
A
apollo18 Offline OP
A
hey guys so in my 2003 hummer h2, i noticed that the AC isnt cold anymore. What can I do to fix that? i ahve it at the lowest temp and its just not as cold and comfortable as my other vehicles
also is there any way to make the ac system even more cold somehow?
thx
Re: how to make AC cold or even colder? [Re: apollo18] #5452104 06/12/20 12:34 PM
Astro14 Online Content
Online Content
Get your AC fixed by a professional?
You could be low on Freon, have a clogged evaporator or condenser, bad expansion valve or weak compressor.
Start with the Freon but have a professional check the charge.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: how to make AC cold or even colder? [Re: apollo18] #5452141 06/12/20 01:05 PM
Nick1994 Offline
The refrigerant will slowly leak out over time, which is normal to an extent. But there's too many variables without a mechanic to look at it unless you've got all the tools and an A/C machine to refill by weight.
2015 Hyundai Genesis 5.0L 62k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: how to make AC cold or even colder? [Re: apollo18] #5452159 06/12/20 01:23 PM
B
Barkleymut Offline
B
I used some of that AC in a can quick fix stuff last year. It worked fine on my truck, AC was blowing cold again for a few months - it is not cold anymore. I tried it on my wife's Flex since it never felt cold - just kind of cool. I broke something, no idea what. Took it to the local mechanic who fixed my stupidity for $175. The Flex still doesn't blow cold air, but at least I got out of the doghouse.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: how to make AC cold or even colder? [Re: Barkleymut] #5452165 06/12/20 01:33 PM
Chris142 Online Content
Online Content
The flex needs a "compressor control valve" most likely.
https://www.amazon.com/New-1090069-Compressor-Control-Valve/dp/B07N342VWL
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: how to make AC cold or even colder? [Re: apollo18] #5452194 06/12/20 02:13 PM
Marco620 Offline
I have another theory. If the coolant is worn out cant that affect the performance of other systems? Engine running hotter,less efficiency.
15' Civic r18, 342,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: how to make AC cold or even colder? [Re: apollo18] #5452198 06/12/20 02:22 PM
J
JMJNet Offline
J
If that is a GM's made Hummer, then the compressor may leaks.
Check the pressure if you have the AC Manifold, otherwise as suggested in Post #2, bring it to a mechanic specialized in GM's AC system.
  • 2017 Toyota Sienna
Re: how to make AC cold or even colder? [Re: apollo18] #5452267 06/12/20 03:53 PM
K
krismoriah72 Offline
K
" in my 2003 hummer h2, i noticed that the AC isnt cold anymore"
I am sure you will get alot of great advice.. but let me throw in my 2 cents.
Check the easy stuff first
A) Cabin Filter
B) Fan Clutch
Report Back.
Re: how to make AC cold or even colder? [Re: apollo18] #5452306 06/12/20 05:26 PM
J
JMJNet Offline
J
I forgot, wash the cooling stack: Condenser and radiator stack together in the front with other coolers.
Clean the evaporator which is usually behind the fan inside/under the dash.
I am not sure if the 2001 model have cabin filter, though.
I suppose, if there is a cabin filter, then there is no need to clean the evaporator.
This is assume that the ac system is healthy.
Re: how to make AC cold or even colder? [Re: apollo18] #5452313 06/12/20 05:41 PM
L
Lubener Offline
L
Likely is low on refridgerant. Refilling won't accomplish anything until you have a professional find the leak.
The "thinking" man's friend.
Re: how to make AC cold or even colder? [Re: apollo18] #5452354 06/12/20 07:05 PM
O
OilUzer Offline
O
Seems like if you are lucky, it takes about 15 +/- a few years before AC requires some sort of help ... at least that's the pattern with my last 2 old cars. One lasted 18 years and the other 14 years. Op is in the middle with 17.
Re: how to make AC cold or even colder? [Re: OilUzer] #5452474 06/12/20 10:43 PM
2
2009Caraman Offline
2
OP is Canadian as am me.
Don't use that stuff OP. Specifically R12a.
We can't get the proper stuff up here very easily. If you use the commonly sold R12a then any future ac service will be very hard to get done. Once that stuff is in your system the ac machines detect it and won't evacuate the gas. It costs big bucks to get it serviced after that. I don't know why they continue to sell it. Only bad will come of it.
OP, if you live in a big city then search Kijiji for AC recharge. Lots of hvac guys do it on the side. Costs about $60. If you're in Calgary I can give you a number of the guy who did mine.
