Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
15 registered members (Char Baby, i6pwr, KneeGrinder, hank2, Danimal1q2w3, Loi, 1 invisible), 691 guests, and 21 spiders.
Topics307,436
Posts5,311,051
Members71,848
Schaeffer 219 Review/Opinion #5452039 06/12/20 11:34 AM
Creekside Offline OP
First post here however a long time lurker. Seems I’m here almost daily. Wanting to see if anyone is using the Schaeffer 219 Synforce Green grease here yet. I use it in almost everything from boat trailer bearings to a subcompact TLB to my dump truck. Curious if anyone has any opinions on it.
Re: Schaeffer 219 Review/Opinion [Re: Creekside] #5452055 06/12/20 11:46 AM
R
Rand Offline
R
only issue I have with schaeffers is I dont need a lifetime supply mail order only.
Re: Schaeffer 219 Review/Opinion [Re: Creekside] #5452080 06/12/20 11:58 AM
doitmyself Offline
The spec sheet doesn't show if it is GC-LB rated. The water washout of the # 2 is 5.5% while an off the shelf product like Mystic JT-6 is 2.5% - what's up with that? No Timken load # on the spec sheet?? to compare with others. It leaves me wondering what the grease is suitable for beyond very heavy equipment, exposed to weather (bushings, etc.). Without better information, I would be leery to use it in wheel bearings, u-joints, etc..
Re: Schaeffer 219 Review/Opinion [Re: doitmyself] #5452097 06/12/20 12:21 PM
I’m almost positive that it carried GC-LB when I purchased it however I see now it’s not shown on the data sheet. Hopefully salesrep will chime in here. I may reach out to my local rep who I purchase through and see what he says.
Re: Schaeffer 219 Review/Opinion [Re: Creekside] #5452558 06/13/20 05:28 AM
ChadHubbard Offline
My son uses this for his farm and construction equipment. It is a polyurea grease. John Deere uses polyurea for everything on their new equipment. Even the corn head grease from Deere is polyurea. Schaeffer's 219 is all we use. For whatever reason(s) the salesman changed him over from Schaeffer's 278 to 219. No way to know if it is performing better or worse than the 378, but so far no bearing or pin failures.
Re: Schaeffer 219 Review/Opinion [Re: ChadHubbard] #5452828 06/13/20 11:27 AM
doitmyself Offline
The tech sheet shows it to be aluminum complex base grease with "polyalphaolefin (PAO) synthetic base fluids". Not the same as polyurea.
https://sep.yimg.com/ty/cdn/yhst-76241474357167/schaeffer-219-synforce-tds.pdf
Re: Schaeffer 219 Review/Opinion [Re: Creekside] #5453067 06/13/20 05:49 PM
B
Bighorn2500 Offline
B
Haven’t tried It yet, heard a little about it. I still have about ten tubes of 274 & a few 238 on the shelf.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: Schaeffer 219 Review/Opinion [Re: doitmyself] #5453255 06/13/20 10:03 PM
It is aluminum complex for sure
Re: Schaeffer 219 Review/Opinion [Re: Creekside] #5453471 06/14/20 07:24 AM
ChadHubbard Offline
Thank you for the correction.
Re: Schaeffer 219 Review/Opinion [Re: Creekside] #5458957 06/21/20 07:16 AM
salesrep Offline
https://www.schaefferoil.com/documents/302-219-td.pdf
Schaeffers Synforce 219 is a GREAT grease in lock step with a historical line up of greases. 221,238,229,274 are just some of its forefathers. All are excellent blended with strong base oils, effective additives and most are aluminum complex.
High quality Specialized Lubricants pay for themselves!
Re: Schaeffer 219 Review/Opinion [Re: salesrep] #5463415 06/26/20 02:39 PM
Thanks for the post salesrep. When could we expect to see the 219 carrying a GC-LB or will it ever? I’m using it in everything from wheel bearings to farm equipment and my Cat track loader. How does the synthesized moly compare to traditional moly in a conventional 3 or 5% grease? For the record I just bought 30 more tubes and a case of 204 from my local rep. Just dumped 5 gallons of the 700 15w40 in my Cat 941B this morning before we move to the next job.
