Forums Migration
Please read this thread
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
89 registered members (2015_PSD, 01rangerxl, 28oz, aba4430, 4WD, 1911CHAMPION, 12 invisible), 1,965 guests, and 41 spiders.
Topics307,633
Posts5,314,693
Members71,894
Denso AC Compressor Warranty #5451763 06/12/20 05:43 AM
A
artbuc Offline OP
A
Price from authorized distributor is $220 with one year warranty. Price from Amazon and RockAuto is $40+ cheaper but no factory warranty. Rockauto offers warranty only if you replace all components and flush system which is not something I need or plan to do.
Assuming the units from Amazon and Rockauto are genuine new Denso units (and that is a big assumption these days) do you think it is worth spending an extra $40-50 for a one year factory warranty? I do not because I believe the probability of a failure in the first year is extremely low. But, I was interested in your experience. I am assuming the new Denso Unit will be high quality and reliable but maybe you have experience that says otherwise. Thanks.
Re: Denso AC Compressor Warranty [Re: artbuc] #5451772 06/12/20 06:05 AM
M
mattd Online Content
Online Content
M
I suppose it depends how much your peace of mind is worth.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Denso AC Compressor Warranty [Re: mattd] #5451775 06/12/20 06:13 AM
A
artbuc Offline OP
A
I usually don’t think that way. I like to go with the facts. I absolutely never buy extended warranties...the house always wins. The warranty here costs 20% of the purchase price. If the new Denso compressors have a 20% failure rate in the first year I would not install one anyway. Since I can’t get my hands on real data I will rely on anecdotal experience you have.
Re: Denso AC Compressor Warranty [Re: artbuc] #5451814 06/12/20 07:09 AM
Chris142 Offline
What happened to your compressor?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Denso AC Compressor Warranty [Re: Chris142] #5451821 06/12/20 07:24 AM
A
artbuc Offline OP
A
Nothing yet. I have some play in the pulley bearing. Makes a little noise when the clutch is engaged. Compressor itself is fine. I can still get a new OEM clutch assembly from Toyota for $140. Thought maybe it would make sense to install whole new compressor since you have to open system and remove compressor either way. Compressor is 21 yo with 150k miles.
Re: Denso AC Compressor Warranty [Re: artbuc] #5451828 06/12/20 07:35 AM
A
anpconnors Offline
A
Went with a Four Seasons compressor on Amazon with 1yr warranty, self installed, vacuumed, charged with gauges. Still running five years later. Paid $155.
Re: Denso AC Compressor Warranty [Re: artbuc] #5451888 06/12/20 08:58 AM
M
MarkM66 Online Content
Online Content
M
If a DIY person installs it, they'll probably say it wasn't done properly and deny any warranty anyway.
Re: Denso AC Compressor Warranty [Re: MarkM66] #5451907 06/12/20 09:22 AM
N
nobb Offline
N
I find that trying to claim warranty from local places are dependent on the person. Some people are just there to collect a paycheque and will accept anything whereas the eager beaver will make up any reason to deny your warranty.
Re: Denso AC Compressor Warranty [Re: MarkM66] #5451913 06/12/20 09:28 AM
A
artbuc Offline OP
A
That has certainly been my experience over the years. So many hurdles, return shipping, etc etc. Given my confidence in Denso, I have come to the conclusion that I should go with lower initial cost and say heck with the warranty. The Amazon reviewers seem pretty confident they got genuine product so I may go that route.
Re: Denso AC Compressor Warranty [Re: artbuc] #5452002 06/12/20 10:45 AM
J
JMJNet Offline
J
I bought a Denso AC Compressor from Amazon a few years ago for my former Sienna.
It was coming from Amazon Warehouse which means it has some sort of blemish, in this case, the box was taped back together.
The compressor itself was in great conditions, the oil cap is still intact and there is oil in it.
It looks original comes in Blue Denso box.
I DIY the install with new condenser and it worked flawlessly till I trade in the Sienna 2 years later.
One of the secret I learned from the forum is the use of a thread sealant called Nylog.
It is specifically design for threading AC threaded fittings to prevent leaks.
I even take off all the fittings I had access to and smear the nylog on it.
Also, get a pack of the o-ring for AC system and replace all o-ring that you have access to and new connections.
  • 2017 Toyota Sienna
Re: Denso AC Compressor Warranty [Re: artbuc] #5452005 06/12/20 10:47 AM
N
nwjones18 Offline
N
The Denso compressor from any place will have a warranty through Denso. Have to show proof that the drier was replaced at the same time. The last compressor I bought was a Denso off Amazon and as long as its sold/shipped from amazon you should be good to go.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Denso AC Compressor Warranty [Re: nwjones18] #5452115 06/12/20 12:48 PM
A
artbuc Offline OP
A
Unfortunately this is not correct. I just received written confirmation from Denso that their warranty is extended through authorized distributors only and Amazon is not an authorized distributor. This confirms what they told me on the telephone. I agree that probability of getting genuine item from Amazon is high vs buying from an Amazon third party seller.
Re: Denso AC Compressor Warranty [Re: MarkM66] #5452121 06/12/20 12:53 PM
Z
zzyzzx Offline
Z
This is what I would expect.
Re: Denso AC Compressor Warranty [Re: MarkM66] #5452157 06/12/20 01:21 PM
diyjake Offline
I totally agree, they probably won't warranty a diy'ers job.
Re: Denso AC Compressor Warranty [Re: artbuc] #5452160 06/12/20 01:24 PM
N
nwjones18 Offline
N
Ah that's interesting.. I feel like that wasn't reflected on the warranty card that was enclosed with the compressor.
Regardless I'd rather put in a Denso with 0 warranty than a (insert other China brand here) with a 1yr warranty. I've had a run of sorry new compressors in my old F-150. Wish Denso sold a compressor for it.
