Forums Migration
Please read this thread
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
89 registered members (A310, 2strokeNorthstar, 4WD, 53' Stude, Audios, Averroes, 7 invisible), 1,976 guests, and 24 spiders.
Topics307,769
Posts5,317,430
Members71,914
12v solar battery charger for short trip driving #5451695 06/11/20 11:01 PM
A
apollo18 Offline OP
A
hello i have a 2003 hummer h2 and i do tons of short trip driving and i believe i already partially ruined my 1 year old battery as it was always discharged and never recieved a full charge. i was thinking of getting one of those 12v solar battery chargers and hooking it up thru my cigarette lighter port since in my vehicle the ports are live 247. Is this a good idea to keep the battery topped up? the only thing i am scared of is that i do not want to over charge my battery nor do i want to get a solar panel that has too little wattage to even make a difference, or are the 5w units fine?
i am in canada so i found this on amazon:
https://www.amazon.ca/ECO-WORTHY-Portable-Battery-Charger-Batteries/dp/B015ZGDYII/ref=sr_1_4?crid=1OBOM2DUH0NCF&dchild=1&keywords=12v%2Bsolar%2Bbattery%2Bcharger&qid=1591933961&sprefix=12v%2Bsolar%2Caps%2C298&sr=8-4&th=1
its a 5w unit
what do u guys think any input?
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451707 06/11/20 11:34 PM
chemman Offline
A 5 watt solar charger is only going to put out a little over 400 mA (0.4 amps) max. Factoring in the amount of sunshine per day, then you'll be able to see that unless your battery is close to being 100 percent charged, a 5 watt solar charger is not really going to do much in the way of charging/maintaining.
You would be better off purchasing a decent battery charger/maintainer built for that purpose. I know there are several posts that recommend specific charger/maintainers in the this forum. All you need to do is dig a little.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451712 06/11/20 11:56 PM
J
JimPghPA Online Content
Online Content
J
The poor angle of the sun in Canada and the short days in winter will seriously degrade the output of any solar battery charger used there. You probably should be thinking about a much larger size, realizing that it will most likely put out a maximum of something like 1/4 of what it is rated for where you are.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451725 06/12/20 12:40 AM
A
apollo18 Offline OP
A
oh yeah im just thinking about for summer cuz its gonna be sunny, in winter ill be doing trickle charge for sure
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451726 06/12/20 12:43 AM
R
Reddy45 Offline
R
I'm curious how your short trips are killing your batteries in a year. Are you running audio equipment or something else that draws faster than your alternator can top up the battery each time you drive? Maybe there's a parasitic draw you aren't aware of?
This sounds like a fundamental issue that needs to be solved before you use solar panels or trickle chargers to help things out.
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451738 06/12/20 02:39 AM
Char Baby Offline
Mighty I suggest a battery maintainer/float charger/tender?
Though IDK if this will be convenient for your specific situation(you'll need a place to plug in). However when your vehicle is parked, you can just plug her in and forgetaboudit!
I have a Schumacher Battery Maintainer mounted atop the battery in my Firebird(in signature). I plug in every time I put her away at night(when I do drive). Otherwise, it just stays plugged in all the time.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: 12v solar battery charger for short trip driving [Re: Reddy45] #5451746 06/12/20 04:13 AM
A
apollo18 Offline OP
A
Thanks for the reply. Actually here where I live the winter was super cold like -40 fahrenheit paired with short 5 min winter trips I believe my battery was severely discharged during the winter. I rarely take longer trips and I heard from other people on here that the alternator can’t fully recharge the battteeh in short trips like mine. So I believe I sulfated the battery within a year, I tried using a noco to repair it but no go so I’m just gonna run it till it dies. I believe it was probably discharged even before the winter as well.
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451788 06/12/20 06:36 AM
W
WyrTwister Offline
W
Two things . Get an electric engine heater and a trickle charger / maintainer and plug the vehicle in .
Also , take it on a good drive every weekend .
Wyr
God bless
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451809 06/12/20 07:02 AM
Astro14 Offline
We talked about the situation a bit in this thread:
https://www.bobistheoilguy.com/foru...rger-alternator-a-no-brainer#Post5440224
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451812 06/12/20 07:04 AM
T
thastinger Offline
T
Your windshield will block half the sun to any panel you put inside the vehicle.
If you can mount a panel outside, you would need a 25W panel to output what a typical trickle charger will do.
Sounds like you have a parasitic draw that you need to find.
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5451871 06/12/20 08:40 AM
R
Reddy45 Offline
R
Are you able to take long drives on the weekends? Not just for the battery, but for your vehicle in general. Short tripping it constantly means your oil never fully warms up in the colder months and you're going to have condensation buildup inside the crank case.
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5452434 06/12/20 09:02 PM
circuitsmith Offline
In Canada I'd start with 20W through the winshield.
I'm in Wash DC and 10W is working well on the dash. Max I've seen on a sunny day is 13.6V
It doesn't take much to go over voltage (>14V) if there's no regulation.
A maintainer would be nice, but I park on a city street and plugging in isn't an option.
This link talks about the issue of overcharging with a small solar panel:
https://marinehowto.com/do-i-need-a-solar-controller/
2017 Hyundai Tucson SE FWD
SuperTech synth, 5w-30, 5000mi/12mo OCI
Re: 12v solar battery charger for short trip driving [Re: apollo18] #5458024 06/19/20 07:49 PM
M
meep Offline
M
My f150 has does the mpg thing where battery charging is reduced to save a few points of mpg. A few years ago I put a fairly sizeable flexible panel on the camper shell... it feeds .9 amps in full sun at 13.8 volts, don’t recall the wattage. It’s about 3’ x 1’, glued down with silicone and screwed at the four corners. It’s about 2mm thick so most folks don’t even notice it. On the average day, the charge controller shuts it down about 3 hours after getting to work. If you you are just looking for a maintainer, I’d think 1sq ft panel, as long as it’s not the single-sheet-of-glass type, would be fine. Those square glass sheet types are less than half as efficient (powerful) as real PV cells.
Truck starts quickly every day with a 5-6 year old battery. I’d do it to the car if there was a way to make it look ok.
2018 F150
2015 crv (wifey!)
