Forums Migration
Please read this thread
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
86 registered members (4.8 Silverado, 53' Stude, 2004tdigls, A310, 2strokeNorthstar, 4WD, 10 invisible), 1,973 guests, and 28 spiders.
Topics307,770
Posts5,317,446
Members71,916
2016 Honda Pilot 0W-20 Spec #5451286 06/11/20 11:20 AM
J
jcbcts Offline OP
J
Just purchased a Honda Pilot with 36k miles. Does Honda have my best interest (from an engine longevity standpoint) at heart in recommending 0W-20 weight oil or is this a gas mileage play? I have an Infinity Q-50 as well and there is a range of recommendations for the 3.0l from 0W-20 to 10W-30 (or maybe even 40) depending on climate conditions. There is a lot of debate on the Q forum about whether there is a trade off with the thinner viscosity oils in protection vs just providing less resistance for mileage or performance.
Anyway, I would prefer to maximize engine protection and longevity over marginal fuel economy improvements. The car had last been changed at a Jiffy-Lube type place so I immediately changed it to a 5W-20, figuring that was safe at the start of spring/summer in the mid-west. My instincts say 5W-30 would be better long term for the motor but I am not an expert on the topic.
What is the consensus thoughts here on the BITOG forum?
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451290 06/11/20 11:26 AM
edyvw Offline
So my in-laws are running 5W20 in previous Pilot in Las Vegas. I do not have to tell you how summers are over there. Your internal engine temperature is maintained by thermostat, so regardless of ambient temperature oil will have very similar temperature in 0 degrees and 100 degrees. Difference is how fast it will reach operating temperature. I am not sure of internal engineering of current V6 in Pilot. Toyota for example can swallow anything. For what is worth, Mobil1 Australia recommends 5W30 in 3.5 V6. So 5W30 will do well if that is your preference. I run in my Sienna 5W30 although it is recommended for 0W20. But then, 2GR-FE in Toyota can run on 20W50 too.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+M1 AP filter).
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451302 06/11/20 11:42 AM
Charlie2015 Offline
0w20 is good. Any name brand full synthetic will do. I would read up on VCM if your car has it. You may want to consider a VCM disabling device.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 170k mi - Valvoline Maxlife 5w30
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451303 06/11/20 11:45 AM
PimTac Offline
Sure are a lot of these threads popping up today.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451305 06/11/20 11:51 AM
7
77Se7en Offline
7
There is no consensus here. Both work well in your Honda. You may see a slight uptick in consumption with the thinner oil. But you may also see a slight / half-percent uptick in MPG with Mr. Thin.
Or, if you keep tossing on your pillow tonight, just run a 50-50 blend of both viscosities.
Spiritual Intuitive / Whisperer-Medium (Involuntary & Non-Profit)
Valvoline ME, Mobil-1 EP & Pennzoil Ultra Platinum 5w30s
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451308 06/11/20 11:55 AM
edyvw Offline
AT 10.6cst, Mobil1 5W30 EP is just there. Not too thick, not too thin.
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451327 06/11/20 12:35 PM
F
FlyNavyP3 Offline
F
For whatever a single data point is worth, my father's wife has a 2013 Pilot that she purchased new. It has had 0w20 since new changed between 5-15% OLM with mostly M1 AFE 0w20. It now has 177,000 mikes on it and has been relatively trouble free. Only issue was a stuck spool valve (I suspect) replaced by the dealer under extended warranty at 115k, dealership installed TSB update parts of valve, pressure regulator spring, VCM screen. It does not have VCM disabled and uses no measurable oil between changes. Seems like hers has held up just fine on 0w20.
Also, banner day, my 2000th post. Woo hoo!
Luke
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451341 06/11/20 12:53 PM
T
tbm5690 Offline
T
Agreed, a 30 is fine. VCM hasn't proven to be problematic on these, that was more of an older gen issue with consumption. For me, running is 30 is most beneficial being DI knowing there is some level of fuel dilution, although not anywhere near some other engines.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport/Tech
2007 Honda Shadow Spirit VT1100C
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451369 06/11/20 01:40 PM
Dave Sherman Offline
I don't think you'll see a noticeable change in economy with 0w-20 over 5w-30. I had a 2008 CR-V and I ran 5w-20 until it was out of warranty, keeping a log of fuel purchases. Went to 5w-30 and kept a log for a year, and the average was slightly better (about 0.5 MPG) with 5w-30, but there were so much variation from one tank to the next that it was impossible to say the oil had any measurable effect. I've been running 0w-20 in my Pilot and I've got no noticeable consumption.
2015 Honda Pilot EX AWD Pennzoil Platinum 0W-20 STP filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451396 06/11/20 02:44 PM
wemay Offline
20 or 30 will work. I'm running a 30 in the VW that calls for 0w20 as well. We've been having very high temps for this time of year, 89f / heat index 98-105f / 80% humidity.
19 Passat Wolfsburg 2.0 TSi: Castrol 508 0W-20
13 Santa Fe Sport 2.0T: GTX Magnatec 5W-30
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451401 06/11/20 02:47 PM
J
jcbcts Offline OP
J
Sorry for the ignorance here but what is "VCM"?
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451424 06/11/20 03:28 PM
wemay Offline
Variable Cylinder Mngmnt
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451435 06/11/20 03:43 PM
2
2K2AcuraTL Offline
2
I continually do a mix of both 20 and 30
all i use is PP
summer gets 75% 30 and winter gets 75% 20 weight
but thats just me..
my 2c
J.
2002 Acura TL-P --- 2013 Acura MDX-Elite --- 2008 Civic
ALL on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
Re: 2016 Honda Pilot 0W-20 Spec [Re: jcbcts] #5451436 06/11/20 03:44 PM
J
jcbcts Offline OP
J
Thanks, does the VCM discussion tie into the oil viscosity discussion or just warning me of possible other issues with the engine? Appreciated either way!
Re: 2016 Honda Pilot 0W-20 Spec [Re: wemay] #5451497 06/11/20 05:30 PM
T
tc1446 Offline
T
Wemay, thanks for the video. i had never heard of VCM either until now.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
