Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
89 registered members (53' Stude, 4WD, 97tbird, 87sammy, andy2001, Alfred_B, 6 invisible), 2,051 guests, and 25 spiders.
Topics307,451
Posts5,311,410
Members71,850
Exhaust manifold bolts? #5451119 06/11/20 08:32 AM
J
joshuawesl Offline OP
J
I will be replacing exhaust manifold gaskets soon and I'm unsure if this is something I should attempt myself, or leave it to a professional shop.
I'm worried about breaking/stripping the hardware when removing everything. I've never done any exhaust work before, but I understand breaking something here can lead to quite an adventure. I've watched a few videos and read about torching the hardware, soaking with PB Blaster or AeroKroil for a few days before doing the job, and trying to slightly tighten - then loosen to get the hardware moving and free.
I do have a can of AeroKroil that I've been saving for really tough stuff, so if I do try this myself, I imagine that's what I'll use.
I would prefer to do this job myself to save a little money, but I'd also prefer to not break half the hardware and spend an entire day just trying to drill out holes.
Advice/tips from the experienced?
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451136 06/11/20 08:43 AM
supton Offline
What vehicle, engine, etc? That might help.
I've watched some of those videos too, and quite frankly I might just hand the job off no matter what! Chasing broken studs looks like no fun for a novice like me.
I suppose as a counterpart, you could always attempt it, and if you snap a bolt and it won't go, you could always put it back together and limp it to a shop. No harm in failing at something.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451137 06/11/20 08:43 AM
DriveHard Offline
Sounds like you are mostly prepared with the oil and heat! Another huge help is to use a "light duty" electric impact (3/8" battery unit). That assures all you are applying is torque (not a side load like a ratchet) and it's in tiny moments in time, so the material can stay in the elastic deformation regime, and not yield.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451151 06/11/20 08:58 AM
K
Kira Offline
K
I removed Heddman headers my friend installed on his SBC (5.7l in an '89) using quality hardware.
The bolts' 3/8" hex edges were sharp and precise.
That's all the experience I have.
I'd spray the Kroil every other day for a week. Remember, hosing it like Niagara Falls does nothing.
Use 6 sided sockets and make sure tools fit. Cheap sockets with loose fit won't do.
Shim with tin foil to make as tight a fit as you can.
"They" always say, "Heat is your friend here". Heat and quench as you see fit.
Be prudent. If the hardware is already rusted and rounded off OR if it looks like you'll need $200 worth of slim-angled-wobblers, consider hiring the job out.
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451215 06/11/20 09:51 AM
T
Trav Offline
T
+1 more info needed. Are you doing the manifold gaskets on the head or manifold to pipe gaskets?
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451222 06/11/20 10:00 AM
A
Anduril Offline
A
Penetrating oil and an impact. The intermittent hammering of an impact is much less likely to break/strip something than constant torque applied via a ratchet or breaker bar.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451227 06/11/20 10:04 AM
Donald Offline
Did you watch the video of the guy (posted a few weeks back here) that loosens and tightens watching to see if the threaded part is moving. And after removing and squirting with some lube put it back in tightened slightly. Move on to next.
2015 Ford F-250 w/Powerstroke
Re: Exhaust manifold bolts? [Re: Donald] #5451297 06/11/20 11:36 AM
W
wag123 Offline
W
That entire thread disappeared.
Re: Exhaust manifold bolts? [Re: Donald] #5451333 06/11/20 12:44 PM
DGXR Offline
I'm not the OP here but I did watch that video and it was good. Even if the fastener doesn't turn (or doesn't look like it is turning), the back-and-forth directions often help to loosen corroded fasteners... but as he said, it takes time. Patience is key and some people have none. The time investment is far less expensive than the work of removing a broken bolt. The most surprising part of that video is the amount of rust dust that streamed out of that one bolt. Dang...
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451391 06/11/20 02:37 PM
Dadillac Offline
I have done many exhaust manifolds. I just use a ratchet and loosen. Have never broken or stripped a stud. Maybe I am lucky. Maybe the vehicles I have worked on aren't prone to major corrosion on the exhaust. Not sure but I just grip it and rip it and all has worked out over 35 years
Don
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451410 06/11/20 03:03 PM
B
Bighorn2500 Offline
B
Keep a drill bit and an easy out near by grin
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: Exhaust manifold bolts? [Re: joshuawesl] #5451432 06/11/20 03:38 PM
J
JohnG Online Content
Online Content
J
You won't know or learn until you do it!
Re: Exhaust manifold bolts? [Re: wag123] #5451444 06/11/20 03:56 PM
Danno Online Content
Online Content
Here it is.
https://www.youtube.com/watch?v=9PKNCVXvZ6w
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Exhaust manifold bolts? [Re: Bighorn2500] #5451484 06/11/20 05:09 PM
T
Trav Offline
T
I would not use a easy out on anything that is rusted in there and broke off during removal, break the easy out off and its trouble. I wouldn't recommend anyone take this on without experience at broken bolt removal.
Re: Exhaust manifold bolts? [Re: Bighorn2500] #5451496 06/11/20 05:30 PM
W
wag123 Offline
W
This is a waste of time. Ask me how I know. As far as I am concerned, an "easy out" is a contradiction in terms. It is a very rare vehicle that gives you enough access to the sides of an engine to use a drill and easy out, and using an impact wrench is out of the question. In some of these engine compartments you will be lucky if you have enough room to get at those bolts with a ratchet and socket.
The only good way to get a broken bolt out of an engine block is by using a mig welder and welding an extension and nut on the end of the broken bolt. The heat and electricity that goes through the broken bolt help to loosen it and it will come right out. https://www.youtube.com/watch?v=FewfvNX08go
