Forums Migration
Please read this thread
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
Best fuel stabilizer/cleaner ?
by icemanrrc - 07/06/20 09:39 PM
Engine Restorer = Glittery oil?
by nastyc5 - 07/06/20 09:35 PM
MC FL-820S Cut Open
by BlueOvalFitter - 07/06/20 09:03 PM
sycboi, Chuck_Ellison, BakonBittz, ssoH, Sumpter_al
71869 Registered Users
88 registered members (86cutlass307, Anthony, ABN_CBT_ENGR, 2010Civic, 2009Edge, aquariuscsm, 10 invisible), 1,297 guests, and 33 spiders.
Topics307,536
Posts5,312,681
Members71,869
Page 1 of 3 1 2 3
Should I change the oil? #5451096 06/11/20 08:09 AM
T
thunderfog Offline OP
T
Long story short, I lost my serpentine belt (it was a month old) while on the interstate. I noticed it fairly quickly when the power steering went and the battery light came on, but the temp gauge was already up to about the 3/4 mark (not into the "red" yet). The split second I noticed that, I shut it down - that whole diagnosis process took about 5 seconds once I noticed something was off.
I smelled the oil fill tube and dipstick, and nothing seemed to be burned.
The oil has ~4000 miles on it, and the OCI for the truck is 10k miles. It's a 2016 4Runner with 115k miles, and I have run Kendall GT-1 FS 0w-20 since the factory fill. Should I change it?
'16 4 Runner Kendall GT-1 FS 0w-20
'14 CX-5 GT AWD - QSUD 0w-20
'78 Evinrude 15HP - E/J TC-W3
Honda GCV160 - Pennzoil Ultra 10w-30
Re: Should I change the oil? [Re: thunderfog] #5451107 06/11/20 08:19 AM
T
ToadU Offline
T
No
Re: Should I change the oil? [Re: thunderfog] #5451109 06/11/20 08:20 AM
T
ToadU Offline
T
Btw Turing the heater to full blast can quickly cool down an engine to a safe temperature before shutting it off. You never overheated so no worries.
Re: Should I change the oil? [Re: ToadU] #5451115 06/11/20 08:30 AM
T
Triple_Se7en Offline
T
I haven't had a vehicle overheat in three decades. But in those years, I always preferred using the Defrost setting, over the heat setting, to help cool off the engine. Reason-being I could hear what I thought was the compressor turning on, using the defrost setting and that compressor sound was absent using the heater setting in vehicles of three decades ago.
Not sure if the same M.O. exists today, with our more modern engines and electronics. No need to change the oil here. But I would - only because it's already seen 4k and you seem accustomed to long OCIs. All engines need an earlier-than-normal bath / engine cleanup, once in a while.
Stay Safe - Stay Healthy
Do a 2nd thought, before walking down the wrong path
Keep Your Korean TGDI / GDI engines clean-4k OCI
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: Should I change the oil? [Re: Triple_Se7en] #5451123 06/11/20 08:34 AM
T
ToadU Offline
T
Interesting. Probably varies by make of vehicle. I tend to drive American made vehicles and all of the ones I have had I could run the heat With -or- without the AC compressor. I am a huge fan of Saabs and can’t remember if this was true for my Saabs. I had a couple if Maximas too. Can’t recall either. My wife like European makes but I hardly ever drive her SUV. Will check and see. Interesting.
Re: Should I change the oil? [Re: thunderfog] #5451126 06/11/20 08:37 AM
T
ToadU Offline
T
>>But I would - only because it's already seen 4k and you seem accustomed to long OCIs. All engines need an earlier-than-normal bath / engine cleanup, once in a while.<<
Totally disagree. I’ve never seen a single owners manual or service bulletin at my service shop suggest this. An-earlier-than-normal bath is another one of those old wives tales and urban oil legends. Gut feelings. Totally not necessary. Waste of money and resources accomplishing nothing.
Re: Should I change the oil? [Re: thunderfog] #5451128 06/11/20 08:38 AM
supton Offline
Odds are, if the serpentine came off, the water pump quit too. Idling with the heater on in an attempt to cool is likely worse than just shutting down. [This being a 4Runner it's "conventional" and not like some timing belt setup with the water pump driven by the timing belt.]
I don't think you have to worry here. Idiot gauges tend to dampened and will lie to you, but a couple of minutes without cooling flow at something other than full engine load shouldn't hurt anything. 5 seconds of running sans belt should almost count as a non-event.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Should I change the oil? [Re: ToadU] #5451134 06/11/20 08:42 AM
T
T
No wives tale. I've kept clean engines for many decades. First and last owner of many vehicles.
In all this time, I've kept a clear dipstick at 1000 miles Methodology of an OCI. Usually just amber color to 2.5k at least.
If you prefer dirty, that's your M.O. But you will never convince me I've wasted a dime.
My Hyundai GDI will challenge me to a fight. It gets sooty / carbon-black, more rapidly. Looks like it will be full synthetic changes at 3K. It may even require a Fram Ultra filter to keep clean.
Re: Should I change the oil? [Re: supton] #5451135 06/11/20 08:43 AM
T
T
Oh yeah, water pump wasn't working, and yes, it's a timing chain in the 4Runner, so I shut it down and popped the hood to release heat. I figure I was probably about 20-30 seconds without the belt.
Re: Should I change the oil? [Re: Triple_Se7en] #5451141 06/11/20 08:49 AM
T
ToadU Offline
T
Color of oil on a dipstick is a poor indicator of oil quality. It’s akin to dowsing and the divining rod. My service center has fleet contracts to service and repair police, city, school busses and all kinds of other fleet vehicles. I use the absolute cheapest oils and filters and other fluids meeting spec and follow OEM change intervals. Same for my fleet of tow trucks. Insane mileage and abuse is the norm for most of these vehicles. Never have or see any oil related issues.
It may make you feel good but the reality is you would have the same exact longevity and results using cheap fluids meeting specs and following the OEM service intervals. You have proved nothing. The absence of problems and a “clean stick” doesn’t prove anything.
Re: Should I change the oil? [Re: ToadU] #5451145 06/11/20 08:56 AM
T
T
I'm not sure who decides what oil & when to change, at your facility. But if you prefer high profits and dirt, that's you - not me.
No high profit margins in my backyard / garage. My stuff stays clean.
So carry-on, enjoy the filth.
Re: Should I change the oil? [Re: thunderfog] #5451152 06/11/20 08:59 AM
T
ToadU Offline
T
It amazes and entertains me all of the craziness I see on here. popcorn2
At best most of the extreme procedures people invent and convince themselves are necessary and somehow beneficial and most of the additives people choose to use are a waste of time, money and resources. At worst they are harmful to their vehicles.
A 3k oil change interval boggles my mind. It’s so unnecessary on so many levels. I would literally take your oil at 3k miles and put into any of my vehicles and continue to run it. I’d have no problem with it going into my wife’s Range Rover.
The amount of wives tales and urban legends is truly unbelievable to me.
Re: Should I change the oil? [Re: ToadU] #5451154 06/11/20 09:01 AM
supton Offline
Don't forget, vocality does not mean majority. It is hard to size up a group that says little when the only measurement tool is number of responses.
Re: Should I change the oil? [Re: thunderfog] #5451163 06/11/20 09:06 AM
T
ToadU Offline
T
So carry-on, enjoy the filth.<<
Profit margins are the sole reason for being in business.
Not sure what “enjoy the filth” means!!?!?! I don’t take used oil and roll around in it or something like that. Oil isn’t seen, touched or anywhere around you from using a vehicle.
Oil is supposed to look dirty. It’s supposed to have soot and contaminates suspended within it. That’s the main purpose for its existence.
It’s not even possible to keep oil looking clean in a diesel. It goes into a diesel amber and 30 seconds after starting the vehicle looks dark. Color means nothing and is a poor indicator of anything.
At my service center I have tried ethically to convince some of our regular customers 3k and other oil changes intervals more frequently than spec’d by the OEM are a waste of their money and resources. If they insist we change it for them of course. Their money. Might as well be in my cash register.
Your Obsession with a certain color of a oil or how it appears on a dipstick is a waste of your money, time and natural resources. Totally your right to do that so carry on. It’s just accomplishing nothing.
Re: Should I change the oil? [Re: ToadU] #5451165 06/11/20 09:07 AM
F
Fattylocks Offline
F
Sitting in a coffee shop while the engine idling for a half hour could also be considered a waste of money and resources.
I seem to recall that you recently posted doing just that.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Page 1 of 3 1 2 3
