Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
31 registered members (ctechbob, bmod305, Astro_Guy, 53' Stude, Char Baby, BlakeB, 3 invisible), 834 guests, and 24 spiders.
Topics307,781
Posts5,317,734
Members71,917
Long shot - resistor values for Nissan Xterra cruise control #5451091 06/11/20 08:03 AM
DriveHard Offline OP
I tried over on the Xterra board, but no luck yet...I thought I would give it a shot here, as I am guessing what I am looking for is common across several Nissan models.
Subject is my 2007 Nissan Xterra. Cruise control has not worked since I got it a couple years ago. It appears to just be a bad clock spring in the steering wheel...as when I turn the wheel all the way in one direction, I can get the controls to work. From what I can see, clock springs are several hundred bucks, and a pain in the arse to swap out (I hate dealing with airbags). I have a bank of momentary switches I was going to install for other accessories, coolers, etc. and have enough spots that I could simply use four of them to run the cruise, if only I could find the value of the resistors shown in the schematic. So long story short...anybody know the values of those resistors???
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Long shot - resistor values for Nissan Xterra cruise control [Re: DriveHard] #5451101 06/11/20 08:13 AM
M
mk378 Online Content
Online Content
M
You have a working button assembly, right? Disconnect it and press each button measure the resistance. If you don't want to take the wheel apart, detach the light blue wire and measure from the car side after turning the wheel to where the clock spring makes contact.
Re: Long shot - resistor values for Nissan Xterra cruise control [Re: mk378] #5451108 06/11/20 08:19 AM
Yes, yes...I appreciate the help, I already have resigned myself to doing this, I was just hoping to get the real specification and not rely on test data. I do appreciate the comment though.
Re: Long shot - resistor values for Nissan Xterra cruise control [Re: DriveHard] #5451451 06/11/20 04:09 PM
E
eljefino Offline
E
I don't know xterras but airbags and clock springs are actually pretty easy from the one's I've seen.
Re: Long shot - resistor values for Nissan Xterra cruise control [Re: eljefino] #5451876 06/12/20 08:47 AM
part of my complaint was dealing with an airbag and the several hundred bucks it costs to buy it. This is just a "dog truck" and trail toy.
It just seems funny to me that there is nothing I can find for a specification for this...
Re: Long shot - resistor values for Nissan Xterra cruise control [Re: DriveHard] #5454272 06/15/20 09:24 AM
I think I finally found the answer...
Main switch pressed : 0 Ohm
Main switch released : 4000 Ohm
Cancel switch pressed : 250 Ohm
Cancel switch released : 4000 Ohm
Resume/Accel switch pressed : 1480 Ohm
Resume/Accel switch released : 4000 Ohm
Set/Coast switch pressed : 660 Ohm
Set/Coast switch released : 4000 Ohm
Re: Long shot - resistor values for Nissan Xterra cruise control [Re: DriveHard] #5454285 06/15/20 09:34 AM
So I calculate the resistor values to be from top to bottom:
250 Ohms
410 Ohms
820 Ohms
2520 Ohms
Am I missing anything else? I'll buy 12 volt rated, but I am guessing they are only running 5 volts...any other concerns?
