Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
94 registered members (andy2001, 2K2AcuraTL, 4WD, 97tbird, 92saturnsl2, 2010Civic, 8 invisible), 2,026 guests, and 22 spiders.
Topics307,449
Posts5,311,381
Members71,850
Croatian oil good? #5450997 06/11/20 04:56 AM
I
IvanPletex Offline OP
I
Hi,
Yesterday I bought this oil for my diesel car.
Any comments on it?
Iam suprised with TBN number..
Re: Croatian oil good? [Re: IvanPletex] #5451001 06/11/20 05:31 AM
B
bullwinkle Online Confused
Online Confused
B
Which diesel car? If it has a DPF, the SA levels are likely a little high.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Croatian oil good? [Re: bullwinkle] #5451002 06/11/20 05:40 AM
I
I
Had dpf, I removed it from the car, only EGR is in function now
Re: Croatian oil good? [Re: IvanPletex] #5451025 06/11/20 06:16 AM
P
Polyalphaolefin Online Content
Online Content
P
PAO based oil with "older" aditive package (mostly based on ZDDP), for gasoline and diesel engines without DPF.
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: Croatian oil good? [Re: IvanPletex] #5451197 06/11/20 09:35 AM
CT8 Offline
Have you tried to get information from the Oil Club RU oil site?
2015 F150 2.7
2018 F350 6.2
Re: Croatian oil good? [Re: IvanPletex] #5451280 06/11/20 11:14 AM
edyvw Offline
It is good oil. I worked on comparison testing using precisely that oil. INA has newer oils in line up, that one is leftover from beginning of 2000's. It is PAO based, very low Noack. If it is going to make your sleep any better I made 485,000km on 1991 BMW 520i using INA 10W40.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Croatian oil good? [Re: edyvw] #5451354 06/11/20 01:08 PM
I
I
I suppose It would not be the best to use that oil in winter because of its thickness? (Even when the sheet says its good till the -45°C)
Winter here is lets say average, about -10°C in the coldest mornings.
My car calls for 5w40 only (manual recommendation),
last winter I used 5w30 had no problems with it.
I wounder can I try 0w40 for the winter even when winter is not that cold?
Car has 183k km, and It doesnt burn any oil.
I change the oil every 7-9k kms and I always use synthetic ones.
Re: Croatian oil good? [Re: IvanPletex] #5451358 06/11/20 01:19 PM
P
Pelican Offline
P
Absolutely you can use 0W40 in fact at -10c you'd be hard pressed to notice any difference on start up with the 5W40
Re: Croatian oil good? [Re: IvanPletex] #5451716 06/12/20 12:18 AM
edyvw Offline
In any part of Croatia in winter you can use 15W40 at any time of winter, let alone 5W40.
Re: Croatian oil good? [Re: IvanPletex] #5451730 06/12/20 12:48 AM
Marco620 Offline
Who makes it? HS Produkt? Imported by Springfield Armory?!?
15' Civic r18, 342,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: Croatian oil good? [Re: IvanPletex] #5451861 06/12/20 08:28 AM
chrisri Offline
Hi from Rijeka. Millennium is fine PAO based oil with older approvals and additive pack- not necessarily a bad thing. INA makes good oils.
02 Nissan Terrano 2.7.TDi Total 5w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 Motul 5w40
