Forums Migration
Please read this thread
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
Slick122, Ford4life76, Patrick_Hall1988, Ron1948, cadillactech
71914 Registered Users
87 registered members (2strokeNorthstar, Audios, A_Spruce, Averroes, 2004tdigls, 2010Civic, 9 invisible), 2,001 guests, and 25 spiders.
Topics307,769
Posts5,317,430
Members71,914
Triton motors good ? #5450935 06/10/20 11:32 PM
L
Lee4212 Offline OP
L
Looked at 2 trucks with the v/8 Triton engines.
Much of what i read is about spark plugs and coils along with timing chain parts all going bad.
I saw something saying the v2 motor is worse than the v3 with the v3 being the better motor,plugs etc.The v3 version should last 300,000 miles easily versus the v2 motor.
Both trucks looked great but had the Triton engines.
I wouldn't like the thought of broken spark plugs ya know.
OH....somewhere i read those spark plugs on the v3 motors we're made a tad shorter so as to not break the tips off
and to always replace any Triton plug before the 30,000 mile mark to get them out easier.
Just your thoughts on the Triton's ??
The 2 trucks looked terrific.
'05 impala base that so far has been great.3.4 v/6. 62,500 miles. Runs ultra smooth.
Re: Triton motors good ? [Re: Lee4212] #5450940 06/10/20 11:46 PM
P
PowerSurge Offline
P
Run away from the 5.4 3 valve engines. Their timing components from the factory are junk. The cam phasers have been revised 3 times last I heard. If the engine has been updated with those newer parts (tensioners, guides, chains, etc.) and a high flow oil pump they can last a long time. But other than that, run away.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra 5.7L
Re: Triton motors good ? [Re: Lee4212] #5450941 06/10/20 11:47 PM
F
FlyNavyP3 Offline
F
Stay away from the 3 valve 5.4L. The 2 valve (2v) 4.6 and 5.4 are pretty dauntless.
Luke
Re: Triton motors good ? [Re: Lee4212] #5450942 06/10/20 11:47 PM
Chris142 Offline
The sparkplug problems are very common. The cam phasers and timing chain component life depends on whether it had oil changes on time or not.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Triton motors good ? [Re: Chris142] #5450943 06/10/20 11:49 PM
P
PowerSurge Offline
P
Has nothing to do with it. The oil pump loses psi over time and causes low oil flow to the passenger side cam phaser and then it’s all downhill from there. Watch fordtechmakuloco’s YouTube videos on the subject.
Re: Triton motors good ? [Re: Lee4212] #5450944 06/10/20 11:51 PM
clinebarger Offline
The 2004/2005 3V Modular's seem to be the worst in my experience for the plugs breaking, Which isn't the end of the world with the extraction tools available.
Phaser rattle. Tensioner leakage, & Oil Pump leakage can affect any 3V Modular that hasn't had updated parts installed. Chain guide deterioration seems to affect 2004/2005 engines more often as does Camshaft Journal issues.
Roller Follower & Broken Valve Springs can affect any year model, If it develops a tick....Have it fixed right away to avoid further/catastrophic damage!
I take care of '06, '07, & '08 F250 3V 5.4L service body trucks for a electrical contractor......They have been very reliable besides the '08 breaking a valve spring. I also have taken care of a 2010 Expedition since new with a 3v 5.4L & has been perfect for 250,000 miles.
If buying a F150.....Get a newer model with the 6R80 transmission!!!!!
2001 Chevy Camaro L92/4L80E
Re: Triton motors good ? [Re: Lee4212] #5450948 06/11/20 12:03 AM
O
ondarvr Offline
O
You received some odd info.
The 2V 5.4 would occasionally blow out a spark plug, changing to a higher torque setting eliminates the potential problem. And fixing a blown plug is fairly easy too.
Other than that they are a reliable and long lasting motor.
Re: Triton motors good ? [Re: ondarvr] #5450952 06/11/20 12:32 AM
clinebarger Offline
I thought he meant Version 2....Being the early 3V Modulars & Version 3 being the late 3V Modulars with the updated spark plugs.
Re: Triton motors good ? [Re: ondarvr] #5451013 06/11/20 06:01 AM
K
krismoriah72 Online Content
Online Content
K
Had one of these.. in a shop truck. Blew out two spark plugs, also had 5 coil packs go out over the life of the truck.
I bought two 3V F150s for $1500 to flip.. both had serious cam phaser issues... cheapest way was to swap engines.. so i unloaded them as is.
After that i no longer look at 5.4 only 5.3 chevys.
Re: Triton motors good ? [Re: Lee4212] #5451034 06/11/20 06:32 AM
P
PontiacHO Offline
P
As a point of reference: the 4.6 was the Crown Vic police engine for almost 20 years. Tough engine.
Re: Triton motors good ? [Re: Lee4212] #5451043 06/11/20 06:48 AM
sopususer Offline
RUN from the 5.4 3-valve.
Re: Triton motors good ? [Re: Lee4212] #5451071 06/11/20 07:40 AM
T
thastinger Offline
T
The 2v 5.4s last forever and the engine accessories in those year trucks are generally very reliable as well. My 98 still has the factory starter, alternator, ac compressor, water pump. I've taken care of it but I've never had to replace anything except upper and lower ball joints.
Re: Triton motors good ? [Re: Lee4212] #5451149 06/11/20 08:58 AM
M
MNgopher Offline
M
Run away from the 3V 5.4 trucks. And I say that as a Ford guy generally... I owned a 2004 F150 with the 5.4 3V and I dumped it when it needed over $2500 in engine repairs (timing chains, seals, tensioners, cam phasers, etc... along with plugs that are a pain to remove). I've driven a ton of vehicles for work and personal use, and the 3V engines were universally not liked.
There is a reason so many Ford trucks of that era are "cheap". Seems to hit typically at 150,000 on the clock or so...
I'd have no problem with a 2V or later 5.0 or ecoboost trucks...
Re: Triton motors good ? [Re: MNgopher] #5451160 06/11/20 09:05 AM
J
joekingcorvette Offline
J
This + 1, I owned a a 1999 and a 2005 and they were both pretty good engines but the horror stories you read are absolutely true. The 2014 5.0K engine is much better and the plugs are very easy to get to.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Triton motors good ? [Re: PowerSurge] #5451170 06/11/20 09:12 AM
F
Fattylocks Offline
F
Great resource for Ford maintenance and repair issues.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
