Forums Migration
Please read this thread
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
40 registered members (87sammy, Char Baby, 77GrandPrix, bfleeman, bbhero, CapriRacer, 3 invisible), 874 guests, and 38 spiders.
Topics307,627
Posts5,314,505
Members71,888
Trouble shooting A/C on a Focus #5450871 06/10/20 09:40 PM
R
RazorsEdge Offline OP
R
This is on a Ford Focus.The air coming out of the vents is cool, but not super cold. When you hook up a can of refrigerant to the low pressure side, the gauge never reads high enough ( green area). I'm assuming there is a leak in the system.
Schaeffer Oil πŸ‘πŸ˜Ž
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5450883 06/10/20 09:59 PM
Propflux01 Offline
Get a set of real gauges and instructions before proceeding or charging.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Trouble shooting A/C on a Focus [Re: Propflux01] #5450909 06/10/20 10:21 PM
R
R
Thanks for the great tip! smirk2
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5450919 06/10/20 10:46 PM
J
JMJNet Offline
J
This refrigerant R134 or newer are very picky.
If you put too much in there, it will not be cold.
So more does not mean it is better cooling.
I personally will bring it to a good Car AC shop and let them troubleshoot it.
Otherwise, you need to get an AC Manifold gauges.
There are a lot of cheap disposable use once or twice type but the good one is not that cheap.
The shop also have the tool to sniff the leak properly if it is leaking.
  • 2017 Toyota Sienna
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5450934 06/10/20 11:28 PM
Chris142 Offline
I have found that gauges are about useless with r 134a. Get it evacuated and recharged to spec by weight and go from there.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Trouble shooting A/C on a Focus [Re: Chris142] #5451079 06/11/20 07:48 AM
G
GMBoy Offline
G
This.
Offering those freon top off cans with the gauge is the worst thing possible for auto AC. People use these and mess things up all the time!
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5451201 06/11/20 09:37 AM
R
ragtoplvr Offline
R
Most independent shops around here only charge about $100 labor plus any refrigerant and oil to evacuate and recharge with the correct amount using a machine. If they do not have a machine for that then do not use them. If you have put in sealer or have contamination they will charge for the filters you ruin also.
Rod
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5451664 06/11/20 09:08 PM
F
Fsharp Offline
F
How many cans of refrigerant have you put in? Was it working at all before you added extra refrigerant? It would be good to know the high side pressure as well. A harbor freight manifold may be in order.
Re: Trouble shooting A/C on a Focus [Re: Fsharp] #5451671 06/11/20 09:32 PM
R
R
We tried just one can thus far. The air coming out of the vents is cool,not super cold. When you attach the canister with the gauge, the gauge fluctuates, meaning the needle will move into the green area, then drop back again.
I don't know, I'm just trying to help. Maybe I should just walk away from it and let them take it to the shop.
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5452350 06/12/20 06:57 PM
F
Fsharp Offline
F
Shop might be a good idea at this point if after a full can of refrigerant the gauge still isn’t in the β€œgreen”. Normally the low side pressure will be above the green range on those gauges when the compressor is off and go down into green range when compressor is on. It sounds like either the system is leaking and pressure is way too low. Or there is a problem with the expansion valve and so high side pressure is high (but you can’t tell) and low side pressure is too low. If the car is not yours I would not mess with it further at this point.
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5454073 06/14/20 10:40 PM
Propflux01 Offline
Sorry. It’s more than obvious you needed it. smirk2
Re: Trouble shooting A/C on a Focus [Re: Propflux01] #5454082 06/14/20 10:53 PM
R
R
Lmao
Considering I've charged several other vehicles A/C systems successfully,your input didn't help so again, thanks.
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5454138 06/15/20 03:57 AM
A
artbuc Offline
A
I guess it depends on how you define success. Not knowing why it needed refrigerant to begin with and not knowing how much refrigerant was in the system when you were done and not knowing what your high side pressure was, does not sound like success to me, at least not long term success. A more accurate description would be risky to downright dangerous.
Re: Trouble shooting A/C on a Focus [Re: RazorsEdge] #5454624 06/15/20 05:44 PM
Propflux01 Offline
Lmao
Considering your using a gauge that is "in or out of the green" reinforces my post. We all know where they come from. Your quite welcome.
Re: Trouble shooting A/C on a Focus [Re: artbuc] #5454627 06/15/20 05:45 PM
Propflux01 Offline
But...But... I've charged so many successfully!
