Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
90 registered members (andy2001, Atrocious, 4WD, bdcardinal, 2K2AcuraTL, 10 invisible), 1,989 guests, and 25 spiders.
Topics307,449
Posts5,311,389
Members71,850
Antenna Booster #5450869 06/10/20 09:40 PM
pkunk Offline OP
An interesting thing happened. I lost all my TV reception from my antenna. I have a large expensive antenna to pull in reception from 150 mi away that requires a booster. I called the vendor and he walked me through testing volts at the input of the booster. Unscrew the cable, check for 5v, etc. OK, all good put it all back together ant Voila! TV works again. Classic take it apart-put it back together to make it work. No corrosion present, connection inside a boot, dry NM air. No explaination
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Antenna Booster [Re: pkunk] #5450884 06/10/20 09:59 PM
samven Offline
Get ready to replace the amp. Mine did the same thing and I thought I had it fixed then about 2 weeks later it did it again and about a week after that it stopped working and no power reset would bring it back.
I love these preamps when they work but climbing the tower to replace them and loosing all reception until you do is a real inconvenience.
Re: Antenna Booster [Re: samven] #5451104 06/11/20 08:17 AM
DriveHard Offline
Any reason you can't move your pre-amp inside? I did the same thing in my last house with a marginal antenna, but I simply put my pre-amp on the inside of my house. Worked great, and lasted over 8 years...until we moved and I upgraded to a much larger antenna with no need for amp.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Antenna Booster [Re: pkunk] #5451112 06/11/20 08:25 AM
A
ARCOgraphite Offline
A
Funny I had a similar issue Decided to re-make a connexion where the coax went into an indoor amplifier before running to first floor TV.
Cut the cable was looking around for new F- connector parts - and in the meantime water started dripping out of the cable.
This is 15' inside the dry attic space!
It appear water entered at the YAGI connexions even though they were wrapped with mouldable rubber.
Then it must have wicked down the RG6 braided shield - as it was rusted to dust.
Amazing and disturbing.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Antenna Booster [Re: pkunk] #5451458 06/11/20 04:21 PM
pkunk Offline OP
Interesting.... The amplifier is a Winegard LNA-200 and in reading Amazon reviews not so highly rated. I should probably have a replacement on hand for when this quits.
Any recommendations for one more reliable?
2000 Mercedes ML320
Re: Antenna Booster [Re: DriveHard] #5455464 06/16/20 05:59 PM
L
Lubener Offline
L
In theory there is more noise present and a weaker signal further down the cable run and the noise will get ampified as well as the signal. "Ideally" it is best near the antenna. Mine is inside too, it works.
The "thinking" man's friend.
Re: Antenna Booster [Re: pkunk] #5455663 06/16/20 10:40 PM
Saabist Offline
I moved mine inside after having a few antenna-mounted amplifiers fail. Have not noticed any difference aside from the amp not dying.
