Forums Migration
Please read this thread
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
105 registered members (77GrandPrix, 2015_PSD, 77Se7en, 4WD, 53' Stude, 28oz, 14 invisible), 1,998 guests, and 42 spiders.
Topics307,640
Posts5,314,798
Members71,897
Nylon washer? #5450846 06/10/20 09:10 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Looking for washers for my Andersen storm door. They are 15mm (0.58in) ID and 18.5mm (0.73in) OD. It’s less than 1mm thick, maybe 0.03”.
Any ideas? Not seeing this readily, and the washer charts all usually have very large ODs to get to that ID.
I’d take PTFE instead.
Thanks!
[Linked Image]
Re: Nylon washer? [Re: JHZR2] #5450858 06/10/20 09:24 PM
R
Rand Online Content
Online Content
R
https://parts.andersenstormdoors.com/detail_37553__all_handles.html
I typed anderson storm door washer into google and it was the 3rd hit if that link doesnt work right.
looks like free shipping cost is $1 and arrival in upto 12 days.
Re: Nylon washer? [Re: JHZR2] #5450860 06/10/20 09:25 PM
doitmyself Offline
This part at MacMasterCarr could probably be filed to fit: 95606A480 Lifetime supply. https://www.mcmaster.com/95606A480
.56 ID .75 OD
Re: Nylon washer? [Re: JHZR2] #5451037 06/11/20 06:34 AM
M
MasterSolenoid Offline
M
Go to Andersens web-site and buy OEM.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Nylon washer? [Re: JHZR2] #5451217 06/11/20 09:54 AM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
So, I’ve noticed that my door wears through these. So I should have been more clear that I’d like something other than the OE. I’d think that PTFE might be more lubricating?
Re: Nylon washer? [Re: JHZR2] #5453962 06/14/20 07:14 PM
J
JimPghPA Offline
J
You can order round solid stock of different types of plastic from McMaster-Carr. If there is metal that would support both sides of the washer if the washer was wider you might make it wider to distribute the weight over more area so it does not wear as fast.
You need to find someone with a lathe to cut the material to the desired size.
Our refrigerator that was not very old wore out the plastic washer and I made a better one with my lathe and it has held up fine for a long time now. If I remember correctly I made it out of some solid bar white nylon I had. I think the nylon I used was a high density nylon and not as soft as the original washer.
When you machine or drill plastic the cutting tool should always be a new tool that was never used to machine any metal. Plastic is very soft compared to metals, but the cutting tool has to be very sharp to cut it properly, and that means a new tool that was never used on any metal.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Nylon washer? [Re: JHZR2] #5454003 06/14/20 08:24 PM
4WD Online Confused
Online Confused
Copper with Teflon grease ?
Re: Nylon washer? [Re: JHZR2] #5454016 06/14/20 08:49 PM
spasm3 Offline
I could not find a source of ptfe washers in your size.
I dont know if you want to try cutting them yourself.
Here is a ptfe sheet 1mm thick. For marking/sizing My craftsman 3/8 10mm socket is about 15mm OD, my 13mm is about 18mm in OD.
https://www.amazon.com/White-Teflon...fe+sheets&qid=1592185414&sr=8-30
15mm punch.
https://www.amazon.com/GEDORE-4543890-Arc-Punch-15/dp/B000UYV0WI/ref=sr_1_2?dchild=1&keywords=15mm%2Bpunch&qid=1592185854&sr=8-2&th=1
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
