Forums Migration
Please read this thread
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
58 registered members (ABN_CBT_ENGR, alarmguy, 2002 Maxima SE, bigjl, bullwinkle, 7 invisible), 1,003 guests, and 40 spiders.
Topics307,629
Posts5,314,516
Members71,888
Ringing sound coming from CD/DVD player #5450812 06/10/20 08:22 PM
dan765 Offline OP
Hello,
Weird thing here. I've got a '12 Hyundai Genesis, 93k miles, There seems to be a ringing sound coming from the DVD player. At times it's faint and high pitch, but then there be a slight clicking sound and it lowers in pitch and the ringing gets more apparent. Any ideas on what it could be?
2012 Hyundai Genesis 3.8L sedan
2015 Hyundai Santa Fe Sport 2.4L
Re: Ringing sound coming from CD/DVD player [Re: dan765] #5450817 06/10/20 08:33 PM
samven Offline
Check your ground wires and have someone run an alternator ripple test. If the ground is going bad it will be susceptible to any noise in the electrical system and if a diode is going bad in the alternator it will generate a hugh amount of noise.
Re: Ringing sound coming from CD/DVD player [Re: dan765] #5450825 06/10/20 08:40 PM
R
Rand Offline
R
is this the car that has the battery going dead?
Re: Ringing sound coming from CD/DVD player [Re: Rand] #5450828 06/10/20 08:45 PM
dan765 Offline OP
Yes, I was wondering if it was related....
Re: Ringing sound coming from CD/DVD player [Re: dan765] #5450833 06/10/20 08:53 PM
samven Offline
AH, you did not mention the battery. Have your alternator and voltage regulator checked and if they are good replace the battery. If you drive with a bad battery long enough you can cause damage to the regulator that now adays is built into the alternator.The regulator should keep the charging current down but with a virtual short (bad battery) on the output it is running at max all the time and heat will kill it.
Re: Ringing sound coming from CD/DVD player [Re: samven] #5450838 06/10/20 08:56 PM
dan765 Offline OP
Do you think the ringing will stop if I put in a new battery?
Re: Ringing sound coming from CD/DVD player [Re: dan765] #5450887 06/10/20 10:04 PM
samven Offline
It may if its just your alternator running at full open trying to charge the battery but it would still be a good idea to run by AZ or AAP and ask them to check your charging system.
Re: Ringing sound coming from CD/DVD player [Re: samven] #5450901 06/10/20 10:17 PM
dan765 Offline OP
Will do. Thanks
Re: Ringing sound coming from CD/DVD player [Re: dan765] #5451095 06/11/20 08:09 AM
DriveHard Offline
if the ringing is coming from the head unit itself, it could be the CD drive motor, and associated mechanisms. If you have a CD in there, or it thinks there is a CD in there and it can't read it, it will continue to cycle the lens focus and speed sweeps to "find" the disc. Push eject, and see what happens. If there is no disc, put one in and see if it goes away.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Ringing sound coming from CD/DVD player [Re: DriveHard] #5451106 06/11/20 08:19 AM
dan765 Offline OP
I think you're right. It does sound like it's trying to read someting that's not there. BUt I've hit eject and popped something and played and ejected, but the sound it still there.
Re: Ringing sound coming from CD/DVD player [Re: dan765] #5452051 06/12/20 11:43 AM
dan765 Offline OP
Here's a short update:
I ended up unplugging the fuse for the CD/DVD player and the ringing stopped. I plugged it back in and it started again. So it's gotta be that.
Any ideas on what might be causing it to do that?
