Forums Migration
Please read this thread
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
96 registered members (28oz, 53' Stude, 77Se7en, 2004tdigls, 4WD, 1911CHAMPION, 11 invisible), 1,994 guests, and 44 spiders.
Topics307,637
Posts5,314,780
Members71,897
Page 1 of 3 1 2 3
Car battery dead #5450522 06/10/20 12:54 PM
dan765 Offline OP
Hello all. I have a 2012 Hyundai Genesis, 93k miles.
This morning, it hesitate to start as if it had a weak battery. Got to work without any problems. Tried to go out for lunch but the car wouldn't start (had that clicking sound that you get from a dead battery). Had it jumped. Drove around for a while. Went to the store. Came out from the store, battery dead again.
Do you guys think I'll have to replace the battery?
2012 Hyundai Genesis 3.8L sedan
2015 Hyundai Santa Fe Sport 2.4L
Re: Car battery dead [Re: dan765] #5450525 06/10/20 12:58 PM
bdcardinal Offline
Yes. Is it the factory battery? I say you got a good life out of it if it is.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Car battery dead [Re: bdcardinal] #5450538 06/10/20 01:08 PM
dan765 Offline OP
I dont' think it was the original. It's some korean brand battery.
Re: Car battery dead [Re: dan765] #5450541 06/10/20 01:12 PM
Duffyjr Online Content
Online Content
You could try putting it on a charger and see what happens, driving it around for bit is not enough to put much of a charge in it. I've had batteries do this and last a while after putting them on a charger but the second time it does this it's time for new battery.
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: Car battery dead [Re: dan765] #5450544 06/10/20 01:14 PM
B
brages Offline
B
If it was replaced, I'd expect to see a Duralast or Interstate or some other common aftermarket brand. Korean battery on a Korean brand car sounds original to me, is there a date code?
Re: Car battery dead [Re: brages] #5450545 06/10/20 01:17 PM
dan765 Offline OP
Yeah, that's what I thought too. However, I've got another Hyundai that has the original battery and it's branded hyundai (or at least it has a hyundai sticker on it). There is not date code on it from what I've seen.
Re: Car battery dead [Re: Duffyjr] #5450550 06/10/20 01:21 PM
dan765 Offline OP
Yeah, I'll try that. Won't hurt
Re: Car battery dead [Re: dan765] #5450553 06/10/20 01:25 PM
Supersonic Offline
Battery replacement is a good place to start, alternator may not be doing it's job is next case you might try to diagnose. You could checked and made sure the connections are clean.
Could also be a starter problem, had to tap my starter once to get it working, worked good for about a month, then I ended up replacing it. Starter connections may also be cleaned.
Re: Car battery dead [Re: dan765] #5450559 06/10/20 01:28 PM
Chris142 Offline
What is the volts when it is running?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Car battery dead [Re: dan765] #5450560 06/10/20 01:29 PM
Char Baby Offline
YES!
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Car battery dead [Re: dan765] #5450562 06/10/20 01:31 PM
W
WyrTwister Offline
W
The whole car was built in Korea .
Wyr
God bless
Re: Car battery dead [Re: dan765] #5450569 06/10/20 01:37 PM
R
ripcord Offline
R
Definitely put a charger on it (over night if possible). Once a battery is low, it will never be fully recharged just by driving the car around town. Also, check the alternator output with a volt meter. You should see voltage over 14.5 volts right after startup.
Re: Car battery dead [Re: dan765] #5450572 06/10/20 01:38 PM
B
BigCahuna Offline
B
If it was my car, it would have had a new battery in it in less time then it took to write the post.,,,
Re: Car battery dead [Re: dan765] #5450593 06/10/20 02:06 PM
Donald Offline
Charge overnight and have it tested. But if its the original or over 5 years old by date code, just replace.
2015 Ford F-250 w/Powerstroke
Re: Car battery dead [Re: dan765] #5450598 06/10/20 02:12 PM
PimTac Offline
Check the date code. Batteries these days don’t last like they used to and the Utah heat doesn’t help either.
Get a new battery.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Page 1 of 3 1 2 3
