etals (ppm)
Iron (Fe) 26 11
Chromium (Cr)
2 Lead (Pb)
1 Copper (Cu) 30
2
Tin (Sn)
1 Aluminium (Al) 10
3
Nickel (Ni)
2 Silver (Ag) Titanium (Ti) Vanadium (V) Contaminants (ppm)
Silicon (Si)
6
5
Sodium (Na) 36
6
Potassium (K) 26
2
Additives (ppm)
Magnesium (Mg) 94 555
Calcium (Ca) 2571 1700
Barium (Ba) Phosphorus (P) 1217 826
Zinc (Zn) 1398 954
Molybdenum (Mo) 123 127
Boron (B) 81 315
Contaminants
Water (%) Coolant No No
Physical Tests
Viscosity (cSt 100C) 13.7 13.4
Fuel (%) 1
Soot (%) Infrared 0.5 0.4
Physical / Chemical
Base Number (mgKOH/g) 6.7 6.5
Oxidation (Abs/0.1mm)
E2412/D7414
17 18
Sorry for the format but that is how it copied over. The first number value is the current reading and the second one is the past sample. the wear number have gone up but the lab says still in normal range. Oil used was Mag1 15w40 and Chevron Ursa 15w40 for the past sample. Will run Amsoil 15w40 next run. This was 250 hours of hard use.
Iron (Fe) 26 11
Chromium (Cr)
2 Lead (Pb)
1 Copper (Cu) 30
2
Tin (Sn)
1 Aluminium (Al) 10
3
Nickel (Ni)
Silicon (Si)
6
5
Sodium (Na) 36
6
Potassium (K) 26
2
Additives (ppm)
Zinc (Zn) 1398 954
Boron (B) 81 315
Contaminants
Physical Tests
Fuel (%) 1
Physical / Chemical
E2412/D7414
17 18
