Cummins ISL 8.9L trash truck
VA
etals (ppm)
Iron (Fe) 26 11
Chromium (Cr)
2 Lead (Pb)
1 Copper (Cu) 30
2
Tin (Sn)
1 Aluminium (Al) 10
3
Nickel (Ni)
2 Silver (Ag) Titanium (Ti) Vanadium (V) Contaminants (ppm)
Silicon (Si)
6
5
Sodium (Na) 36
6
Potassium (K) 26
2
Additives (ppm)
Magnesium (Mg) 94 555
Calcium (Ca) 2571 1700
Barium (Ba) Phosphorus (P) 1217 826
Zinc (Zn) 1398 954
Molybdenum (Mo) 123 127
Boron (B) 81 315
Contaminants
Water (%) Coolant No No
Physical Tests
Viscosity (cSt 100C) 13.7 13.4
Fuel (%) 1
Soot (%) Infrared 0.5 0.4
Physical / Chemical
Base Number (mgKOH/g) 6.7 6.5
Oxidation (Abs/0.1mm)
E2412/D7414
17 18
Sorry for the format but that is how it copied over. The first number value is the current reading and the second one is the past sample. the wear number have gone up but the lab says still in normal range. Oil used was Mag1 15w40 and Chevron Ursa 15w40 for the past sample. Will run Amsoil 15w40 next run. This was 250 hours of hard use.
Calcium is listed as 2571 ppm for the used oil sample but the new oil lists 1050 ppm calcium. What could cause that number to rise?
Originally Posted by Chris142
Lot of weight for such a small engine!
Really? I wouldn't consider a 9 liter diesel with 300 HP and 900-1000 ft lbs torque small. They sell the same truck with a 6.7L!
How much weight do they carry? I am used to 14L engines. The 10L I hauled trusses with was miserable on any hill and rarely grossed 40k.
The trash trucks here are allowed 66k gross. But often come in a lot heavier. I saw one @90k on the scale once lol
