Forums Migration
Please read this thread
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
92 registered members (2015_PSD, 4WD, 379KITTY, 53' Stude, 2004tdigls, 2003f7, 9 invisible), 1,954 guests, and 30 spiders.
Topics307,771
Posts5,317,469
Members71,916
2nd-3rd Gen Tundras and the front brakes #5450308 06/10/20 07:59 AM
T
thooks Offline OP
T
I thought I'd start a new thread to go over my experiences and not garble up the other towing brake thread anymore.
I have a 2014 Tundra with 121k miles. I just replaced the front pads/rotors for the 2nd time. I bought the truck new. First OEM set of pads/rotors were replaced about 65k miles. I was experiencing fairly bad shake/shimmy when applying the brakes, especially at highway speeds. I bought the PowerStop Z36 drilled/slotted rotors and Z36 pads, I re-used the OE clips/springs and caliper pins. I did not re-use the OE shims.
I did completely wire-brush/wheel the rotor mating surface of the hubs, taking care to really get all the rust off and make the surface smooth again. I put some copper anti-seize on the mating surface on the hub. Being in the Southeast, rust is not a major issue. There was some rust, but nothing crazy. As I said, I re-used the "anti-rattle" clips (springs) that are the only means of spreading the pads back off the rotors when braking is not used. And there's only ONE of these springs/clips on each caliper/pad set. There's not any real service data/instructions anywhere that say to replace these clips. And certainly none of the Youtube videos show anyone replacing them with new.
Fast forward 60k miles and I'm suffering the same, maybe worse, shimmy/shake when applying the brakes. I'm even seeing / feeling a rough ride/vibration at certain highway speeds. Road force balancing made most of it go away.
I replaced the Powerstop pads/rotors with new Toyota OEM pads, rotors, shims and bought a new anti-rattle/spring kit. It only included two springs. I re-used the original two and put the new springs in, one on each caliper. The new springs are much larger/robust than the OE springs, at least it seems that way. I'm going to buy another set, take the wheels off, and put a new spring on each caliper where I've re-used the old springs. Both calipers will then have 2 new anti-rattle clips (springs), pushing the pads back on both ends when the brake pedal is not applied.
I think this lack of a second spring (anti-rattle clip) is the problem with the front rotors warping prematurely on the Tundras. There is no reason the PowerStop products should have had problems. There is no reason the Toyota OEM rotors/pads should have problems. These are STOUT, Made in the USA products. 4-piston calipers, LARGE calipers, rotors and pads. This is on the verge of heavy duty 3/4 ton truck components.
I also saw very poor performance from the brakes I put on our 2011 Sequoia. All the same components, same problem except at 35,000 miles, the pads and rotors were SHOT. I replaced the pads, rotors, ALL hardware. We sold that vehicle about 5k miles later, so I don't know how it's doing now, but I bet it's better than it's ever been.
So to boil it down, if you are having the warping problem with your Tundra, Sequoia, etc., try putting in 2 sets of springs on the pads.
Also....for the love of all that's good - when you are pushing the pistons back in the calipers.... PLEASE get your 10mm wrench out, a 1/4" clear plastic hose, old milk jug and open the bleeder screw up and push the old fluid OUT into the jug and NOT back into the brake lines. It's 100 times easier to push the pistons back in and you're not pushing old fluid back into your system. Refill the master cylinder reservoir, then do the other side. Finally, bleed the system out 5-6 pedal pushes and put some new fluid in the system.
I think I'm on to the solution, tho. I re-set my MPG monitor on the dash this morning. Generally, I have been averaging 15.5 MPGs for YEARS. I have a 65 mile commute a couple days a week. This morning it's showing 16.7 MPG after the reset. I'll report back after a week or so and let it settle in.
Re: 2nd-3rd Gen Tundras and the front brakes [Re: thooks] #5450328 06/10/20 08:41 AM
P
PowerSurge Offline
P
I service a total of four Tundras including my two and never had any brake problems. Including two of those that tow daily, one near max towing capacity. I only use factory rotors and pads.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra 5.7L
Re: 2nd-3rd Gen Tundras and the front brakes [Re: thooks] #5450329 06/10/20 08:42 AM
supton Offline
FWIW I've had nothing but trouble with the pins that retain the pads. I would say to anyone with this truck in the rustbelt, try to remove on a regular basis. That or turn them down somehow. They seem to always need to be hammered out--the last shop to work on my truck indicated that they sometimes had to replace the caliper due to this problem.
Next up, the pads on mine like to seize up. I think the problem is worse than on "conventional" setups due to the much larger pad ears.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: 2nd-3rd Gen Tundras and the front brakes [Re: thooks] #5450331 06/10/20 08:43 AM
R
ragtoplvr Offline
R
Google brake bed in procedures. Do one.
Light driving and parking for several days result in uneven wear surface on the rotors.
Rod
Re: 2nd-3rd Gen Tundras and the front brakes [Re: thooks] #5450488 06/10/20 12:18 PM
Supersonic Offline
4-piston calipers, same as my 2005 4Runner, replaced the calipers because I could tell one side was sticking, read many 4Runner complaints about sticking calipers is what persuaded me and that was the right call.
Re: 2nd-3rd Gen Tundras and the front brakes [Re: thooks] #5450528 06/10/20 12:59 PM
T
thooks Offline OP
T
Let me reiterate my points in my OP-
1. Buy new anti-rattle clips and use two per caliper
2. Put some copper anti-seize on the pins (and hub where the rotor mates)
3. Please don't push old fluid back in. Use the bleeder screw and bleed new fluid through the system.
I did bed-in the new pads on Tuesday morning. I drove about 10 minutes on unoccupied roads around my house. I ramped up from 40 mph to 15 mph braking to 50 to 15, 65 to 15, etc. I could smell a little grease and such getting hot by the time I headed back home. I tried to not get on the brake the last 3-4 minutes on the way home and gently braked and coasted down the driveway. I've not had a hard brake yet. The pedal feels much better, the truck stops better and there is zero shake/shimmy when braking at any speed.
Again, the MPG increase will tell the truth about the second anti-rattle clip. I'll update it Friday.
