Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
25 registered members (bernardch, bbhero, Falcon_LS, edyvw, dishdude, 77GrandPrix, 3 invisible), 744 guests, and 22 spiders.
Topics307,436
Posts5,311,045
Members71,848
Cummins ISL 8.9L trash truck #5450302 06/10/20 07:50 AM
M
mpgo4th Offline OP
M
etals (ppm)
Iron (Fe) 26 11
Chromium (Cr)
2 <1
Lead (Pb)
1 <1
Copper (Cu) 30
2
Tin (Sn)
1 <1
Aluminium (Al) 10
3
Nickel (Ni)
2 <1
Silver (Ag) <1 <1
Titanium (Ti) <1 <1
Vanadium (V) <1 <1
Contaminants (ppm)
Silicon (Si)
6
5
Sodium (Na) 36
6
Potassium (K) 26
2
Additives (ppm)
Magnesium (Mg) 94 555
Calcium (Ca) 2571 1700
Barium (Ba) <1 <1
Phosphorus (P) 1217 826
Zinc (Zn) 1398 954
Molybdenum (Mo) 123 127
Boron (B) 81 315
Contaminants
Water (%) <0.05 <0.05
Coolant No No
Physical Tests
Viscosity (cSt 100C) 13.7 13.4
Fuel (%) <1
1
Soot (%) Infrared 0.5 0.4
Physical / Chemical
Base Number (mgKOH/g) 6.7 6.5
Oxidation (Abs/0.1mm)
E2412/D7414
17 18
Sorry for the format but that is how it copied over. The first number value is the current reading and the second one is the past sample. the wear number have gone up but the lab says still in normal range. Oil used was Mag1 15w40 and Chevron Ursa 15w40 for the past sample. Will run Amsoil 15w40 next run. This was 250 hours of hard use.
Re: Cummins ISL 8.9L trash truck [Re: mpgo4th] #5450303 06/10/20 07:52 AM
M
mpgo4th Offline OP
M
Calcium is listed as 2571 ppm for the used oil sample but the new oil lists 1050 ppm calcium. What could cause that number to rise?
Re: Cummins ISL 8.9L trash truck [Re: mpgo4th] #5450314 06/10/20 08:05 AM
Chris142 Offline
Lot of weight for such a small engine!
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Cummins ISL 8.9L trash truck [Re: Chris142] #5450319 06/10/20 08:16 AM
M
mpgo4th Offline OP
M
Really? I wouldn't consider a 9 liter diesel with 300 HP and 900-1000 ft lbs torque small. They sell the same truck with a 6.7L!
Re: Cummins ISL 8.9L trash truck [Re: mpgo4th] #5450342 06/10/20 08:54 AM
Chris142 Offline
How much weight do they carry? I am used to 14L engines. The 10L I hauled trusses with was miserable on any hill and rarely grossed 40k.
The trash trucks here are allowed 66k gross. But often come in a lot heavier. I saw one @90k on the scale once lol
Re: Cummins ISL 8.9L trash truck [Re: mpgo4th] #5450382 06/10/20 09:50 AM
M
mpgo4th Offline OP
M
It's a 20 yard rear loader and the registration says 56,000 GW.
Re: Cummins ISL 8.9L trash truck [Re: mpgo4th] #5450424 06/10/20 11:06 AM
Chris142 Offline
Still a lot of weight (IMO) for a 9L engine. 1000ftlbs is 1950's Diesel power!
Re: Cummins ISL 8.9L trash truck [Re: mpgo4th] #5450431 06/10/20 11:15 AM
SeaJay Offline
"Coolant No No" is the biggie in my book as far as a good result, the block and gasket are holding true.
