Forums Migration
Please read this thread
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
95 registered members (4WD, A310, 55hambone, 2010Civic, 28oz, 2004tdigls, 9 invisible), 1,904 guests, and 43 spiders.
Topics307,635
Posts5,314,722
Members71,897
Stupid torque wrench question #5450064 06/09/20 08:44 PM
J
JeffKeryk Offline OP
J
Of course I relieve the tension on my torque wrenches after use.
My question is, do I spin 'em down all the way or to the lowest range value?
I got a funny feeling I have been doing it wrong for ever...
Thanks in advance.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Stupid torque wrench question [Re: JeffKeryk] #5450066 06/09/20 08:48 PM
Quattro Pete Offline
That's what I've always done, but curious what others do.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Stupid torque wrench question [Re: JeffKeryk] #5450071 06/09/20 08:50 PM
samven Offline
I spin mine down all the way until I can tell there is no tension on the spring but if you are going to 0 on the scale I'm sure you are going to be fine. The spring will never take a set with that light compression.
Re: Stupid torque wrench question [Re: JeffKeryk] #5450072 06/09/20 08:51 PM
T
Trav Offline
T
Click type all the way down to zero or "STOP" marking if it has one, on split beam there is no need to do anything.
Re: Stupid torque wrench question [Re: JeffKeryk] #5450079 06/09/20 09:01 PM
G
GSCJR Offline
G
Option 2 - Set to the lowest available value.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Stupid torque wrench question [Re: JeffKeryk] #5450083 06/09/20 09:05 PM
H
hallstevenson Online Content
Online Content
H
Mine says set it at 10 ft/lbs when not in use
Re: Stupid torque wrench question [Re: Trav] #5450101 06/09/20 09:40 PM
J
J
OK, here's the SO spun all the way down. If I understand, this is correct. Or should it be set to 5 pound feet?
I believe the Bonny can be spun down past the markings.
Thank you.
2018 Lexus RX450h
2006 Acura TSX
Re: Stupid torque wrench question [Re: JeffKeryk] #5450122 06/09/20 10:08 PM
T
Trav Offline
T
Realistically at a setting that low it isn't going make much of if any difference, there is almost no tension on the spring.
Re: Stupid torque wrench question [Re: JeffKeryk] #5450124 06/09/20 10:10 PM
doitmyself Offline
I follow the mfg. directions. Most, if not all of the major manufacturers (Proto, Snap-On/CDI, Precision Instrument, Sturdevant) recommend to store them at the lowest setting (not below) on the wrench, AND do not relieve all the tension.
Norbar's : "A fully loaded torque wrench, left in storage for a long period, can cause a set in the spring, causing it to weaken over time. On the other end of the scale, by completely off-loading the spring, other components within the wrench may move fractionally relative to each other. When you reapply spring compression the orientation of these components can change, therefore affecting accuracy. All in all, it is better to leave a bit of compression in the spring while in storage. "https://www.norbar.com/News-Events/...you-should-know-about-your-torque-wrench
Sturdevant Richmont states this about "some" torque wrenches: "When taking pressure off the spring, the design may allow the wrench to relieve pressure on the torque block. This can allow the torque block to disorient, shift. Some wrenches can be set to zero pressure on the spring or have the handle further away from the spring. Not only can the torque block disorient, but it can also even fall out of place in the wrench. If the torque block disorients, calibration is lost. Repeatability becomes an issue because the block no longer functions as designed. Typically in the tilt block design, the block itself is not square. That means when the tilt block is reoriented and is on its side, the torque value has changed without your knowledge. The scale still reads the same torque value, but what wrench says, and what it does, are two entirely different things. The difference in torque could be 20% or it could be 50%. It depends on the dimensions of the torque block. " https://www.srtorque.com/error-proo...e-quietly-sabotaging-your-quality-score/
Snap On/CDI " If using a click-type torque wrench, always store it at the lowest level on the scale." https://www1.snapon.com/display/231/ToolNews/TechRefs/2008/TorqueWrench08.pdf
Precision Instrument: "Every click wrench other than the "C" series must be returned to the bottom of the scale after use. "
Remember, the bottom of the scale often is not zero on most wrenches.
Re: Stupid torque wrench question [Re: JeffKeryk] #5450243 06/10/20 05:55 AM
F
FT92 Offline
F
yep I always spin mine down to zero...seems to have worked good all these years
Re: Stupid torque wrench question [Re: JeffKeryk] #5450333 06/10/20 08:47 AM
I
incognito_2u Offline
I
Take it for what its worth, but not only do I spin it down to zero after use, I also run it up and down three times from zero to max before I set the Torque values. Don't know where I heard to do this, but its what I've always done.
Just saying...... grin
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Stupid torque wrench question [Re: JeffKeryk] #5450335 06/10/20 08:49 AM
2015_PSD Offline
I do the same, but after seeing statements about how springs wear out from work versus constant compression, does it matter? I mean, what would be the issue with leaving it set at say 25% of the range or even 50%?
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Stupid torque wrench question [Re: JeffKeryk] #5450358 06/10/20 09:14 AM
Silverado12 Offline
FWIW last time I used my torque wrench I had it at 18# for my Mustang's spark plugs. I just left it at that because I can't see how such little torque could hurt it.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Stupid torque wrench question [Re: Silverado12] #5450368 06/10/20 09:26 AM
spasm3 Offline
Don't know, but the idea is to leave the spring neutral so the tension does not drift and become inaccurate.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Stupid torque wrench question [Re: JeffKeryk] #5450370 06/10/20 09:28 AM
A
ARCOgraphite Offline
A
Down to 15 or 20. Not Zero.
Especially Hand torque DRIVERS which can "fall apart" when de-tensioned.
I used to bring hundreds of wrenches and driver to the lab for semi annual cal.
I had to since the shop Layouts didn't seem to care about Audits!
See Something, DO something.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
