Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
20 registered members (EdwardC, ChristianBerg, edhackett, Bailes1992, E365, Drosselmier, 1 invisible), 758 guests, and 24 spiders.
Topics307,584
Posts5,313,569
Members71,876
2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 #5450040 06/09/20 08:20 PM
Colt45ws Offline OP
This is my work van, and it gets driven a lot. I put between 500 and 1k miles on it almost every week. We have some customers that are 100-150 miles one way, so its not uncommon for me to do 5-6 hours of driving to do 2-3 hours of work.
I run the thing pretty hard. I have a tune on it thats supposed to bring the stock 154HP engine up closer to 200HP. It also disables the EGR function.
Recently I bought a handbuilt Scangauge type device. Its a Arudrino Mega with a touchscreen and a couple of CAN bus interfaces. It shows me a lot of information on the health of the engine I wouldnt otherwise know.
What Ive discovered is that the oil temperature on this engine runs about 220-240F pretty much all the time Im on the road. I believe thats pan, and there is a OTW cooler after the cartridge oil filter so thats knocking it down somewhat. Hills or long periods of high load raise that temperature easily. Theres a real nasty hill I climb on occassion. 12% grade, about 5 miles long and posted 50mph. I always keep it in 3rd gear with engine load between 80-90% all the way up maintaining 55mph. When I crest the top of the hill, pan temperature is 260-265F.
With that in mind, Ive converted to the new Rotella T6 15W40 for improved HTHS and NOACK. So my next change will be with that.
I did have to add 2qts to the engine over the course of this change. Thats another cool feature of the Arduino, it reads the oil pan level and displays it in mm, so I always know when my engine oil is at, and when I need to add some top off.
Total run was 14,266 miles, and that was determined by the Mercedes ASSYST function. It starts at 10k miles remaining after a change, but usually ends up stretching it out farther, as that is I guess a worst case scenario.
Lab is OAI
Code
Iron		46
Chromium	4
Aluminium	9
Copper		1
Silicon		9
Sodium		15
Potassium	3
Boron		146
Magnesium	98
Calcium		2394
Phosphorus	1052
Zinc		1267
Fuel		<1% - Estimate
Water		<0.1% - FTIR
Soot		0.2% - E2412
[email protected]	15.5
TBN		5.01
Oxidation	15 abs/cm
Nitration	9 abs/0.1mm
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Colt45ws] #5450081 06/09/20 09:04 PM
R
Rand Offline
R
potassium and sodium??
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Rand] #5450105 06/09/20 09:46 PM
Colt45ws Offline OP
OAI did not draw attention to it. The only thing they 'flagged' was Chromium and it was only a Severity 1.
-Colton
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Colt45ws] #5450273 06/10/20 06:58 AM
K
krismoriah72 Offline
K
I think that looks fantastic for 14K miles.. I doubt that you will do better with 15w40.
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: krismoriah72] #5451386 06/11/20 02:31 PM
Colt45ws Offline OP
Yeah, I was impressed. Depending on how much longer I have the van, I may change the filter at the next interval the ASSYST goes off at, take a sample, then top it off and run another interval. That would be 28k or so? There would probably be at a gallon of top off too.
-Colton
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Colt45ws] #5451529 06/11/20 06:20 PM
CleverUserName Offline
That's crarzy.
The oil has thickened and the TBN is 50% depleted. I've never seen a group III synthetic perform well above 15K miles on a diesel engine. That oil is done and pushing it above 15K is foolish.
If you want to go above 15K try one of the group IV synthetics.
If you decide to sell the van send me a message.
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Colt45ws] #5451640 06/11/20 08:31 PM
I
Ignatius Offline
I
Thanks for the report, I have a 2005 Sprinter as well and normally run 0w40 from Valvoline or Mobil 1. I have used Rotella T6 5w40 in other diesels before but never tried it in a Sprinter.
2018 Subaru Outback Limited - 100,000 miles
2012 Hyundai Accent GLS - 105,000 miles
2005 Dodge Sprinter 3500 - 168,000 miles
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: CleverUserName] #5451692 06/11/20 10:50 PM
Colt45ws Offline OP
That's crarzy.
Visc is only 4% over the spec sheet, Im not concerned with it. Oxidation # doesnt seem to indicate the oil is stressed. TBN doesnt necessarily drop linearly.
In all honesty I wouldnt go double OCI right off the bat, maybe shoot for ~25k, and at least get another sample at that point.
-Colton
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Colt45ws] #5451779 06/12/20 06:19 AM
I
Ignatius Offline
I
That's crarzy.
My concern would be at what mileage points did you have to add oil? I am changing my Sprinter's oil today and it has gone a year and 10,000 miles without any oil consumption issues noted. I will measure what drains out but to say that has never been an problem with my van's engine and it is currently sitting at 168,000 miles.
Re: 2005 Dodge Sprinter, 2.7L OM647, 207.5k mi, 14.3 k mi on Rotella T6 5W40 [Re: Colt45ws] #5451971 06/12/20 10:17 AM
Colt45ws Offline OP
I dont consider 2 quarts in over 14k to be any sort of a problem or issue. As I said I run it hard and so I expect it to consume some oil. That has been my experience in the past with other vehicles. I dont keep track of when oil was added. It wasnt consuming more later in the OCI vs earlier however.
-Colton
