FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
55 registered members (alarmguy, Astro14, avi1777, Aredeeem, Amkeer, bbhero, 8 invisible), 970 guests, and 37 spiders.
Topics307,398
Posts5,310,366
Members71,843
Whoosh-whoosh noise after brake job #5449913 06/09/20 06:00 PM
M
mclasser Offline OP
M
My friend's 2014 Pilot had a rear brake job (rotors+pads) done at a shop. As soon as he left the parking lot, he started hearing this faint whoosh-whoosh noise. Since I have the same car, he asked me to drive it and sure enough, when you're coasting thru the neighborhood, there's a whoosh-whoosh-whoosh rubbing noise. It's there when both coasting + braking. It isn't a scraping noise like a bent rotor shield but I pushed each of them back just to make sure. I also noticed the foot parking brake is tighter and takes less clicks to apply than in my Pilot.
I told him to take it back to the shop but what could be the culprit? I looked at the RO and it appears they used SilentStop parts from Fisher Auto.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Whoosh-whoosh noise after brake job [Re: mclasser] #5449929 06/09/20 06:21 PM
T
Timmastertech Offline
T
That has drum in hat parking brake, parking brake shoes are a little tight, minor adjustment. SHoes had to be adjusted after rotor replacement so the parking brake works. I usually set them a little tight and let them wear in to the new rotor on road test. Parking brake works much better that way. Noise will go away on its own in a few days or the adjustment can be backed off slightly
Re: Whoosh-whoosh noise after brake job [Re: mclasser] #5449932 06/09/20 06:26 PM
R
RyanY Offline
R
Deleted.
2007 Cadillac CTS 3.6L >131k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >109k miles; QSUD 0W20 + STP S6607XL
Re: Whoosh-whoosh noise after brake job [Re: mclasser] #5449959 06/09/20 06:48 PM
G
Gebo Offline
G
OEM brake pads will fix the problem.
And hope they didn't throw away the Honda hardware.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Whoosh-whoosh noise after brake job [Re: mclasser] #5453436 06/14/20 06:30 AM
H
HangFire Offline
H
Probably would be the parking shoes as Timmastertech stated. The factory service manual instructions are to set them too tight, then break them in by driving a given distance and speed with the parking brake on (not making this up).
Could be eccentrically mounted rotors and/or dry pins.
Could be the splash shield, just lightly touching.
Various musings: http://hangfire.net
Re: Whoosh-whoosh noise after brake job [Re: Gebo] #5454109 06/15/20 12:24 AM
The Critic Offline
No relation to the brake pads or hardware.
This is purely a parking brake adjustment issue.
2020 Ram 1500 5.7L eTorque - <1K - Factory Fill
2011 Toyota Prius 1.8L - 209K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Whoosh-whoosh noise after brake job [Re: The Critic] #5454207 06/15/20 07:44 AM
G
Gebo Offline
G
Due to the inferior quality of the non OEM pad material and poor design of the hardware.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Whoosh-whoosh noise after brake job [Re: Gebo] #5454305 06/15/20 09:48 AM
The Critic Offline
Again, there is no relation - the issue is with the parking brake shoe adjustment. The parking brake shoes and hardware are not replaced during a routine brake job.
Re: Whoosh-whoosh noise after brake job [Re: mclasser] #5458006 06/19/20 07:34 PM
M
meep Offline
M
Concur. The tech did the right thing and set the shoes to where they just touch. I’m assuming this isn’t loud. With the old manual drum brakes, you’d tighten them until you couldn’t spin the wheel and then back off 4 clicks or so.
It’s nice to have a good firm e-brake.
M
2018 F150
2015 crv (wifey!)
