FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
28 registered members (Brad1119, ArrestMeRedZ, blufeb95, BLND1, carlprop, 4 invisible), 910 guests, and 39 spiders.
Topics307,396
Posts5,310,319
Members71,843
Page 1 of 3 1 2 3
Aluminum vs Castiron water pumps? #5449532 06/09/20 08:06 AM
M
mpack88 Offline OP
M
What's the pro and cons of castiron vs aluminum water pump? My 75 LTD with a 400m engine overheats at idle. Was thinking about getting a high flow water pump as I learned these engines are prone to over heat at idle. I see cast and aluminum options as well as a aluminum timing cover. Original timing cover is castiron. Should I not worry about it, use aluminum pump with iron cover or switch cover aswell?FYI, radiator is a new 3 core, hoses are new. Thermostat is new and at 195°. I have a 180° on hand. Have a 7 blade fan from a 460 and new clutch.
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449534 06/09/20 08:09 AM
K
kstanf150 Offline
K
I would think the 180 thermostat and 7 blade fan would help more to reduce temp at idle
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449538 06/09/20 08:14 AM
Chris142 Offline
Is the fan clutch working? Just cause it is new does not mean it's good. Especially if it was made by Hayden. Turning up the idle speed helps also. How many fins per inch is the radiator core? I have seen low quality ones with 4-6 fins per inch. Original was 12
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449590 06/09/20 09:11 AM
L
Lubener Offline
L
Do whatever you can do to improve airflow. Running hot at idle is an airflow issue, running hot on the freeway is a waterflow. Clean the radiator fins of any debris and replace the radiator if the fins are rotted out. Make sure your fan is in good shape and the shroud isn't missing. I doubt a different water pump will help in your situation.
I thought back in 1975, Ford used a flex fan driven directly off the water pump with no clutch. Even though it is new, I am suspicious of that fan clutch working properly and might consider going without the fan clutch in favor of direct off the pump..
The "thinking" man's friend.
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449596 06/09/20 09:21 AM
slacktide_bitog Offline
aluminum doesn't rust smile
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449597 06/09/20 09:22 AM
supton Offline
Add an electric fan up front to help?
Any value in changing pulley sizes so as to drive the water pump (and fan) faster?
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Aluminum vs Castiron water pumps? [Re: slacktide_bitog] #5449604 06/09/20 09:28 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
No, but it does corrode.
Re: Aluminum vs Castiron water pumps? [Re: supton] #5449621 06/09/20 09:55 AM
DBMaster Offline
This^
Plus, I don't think it really matters which material you go with. My 1972 Pontiac Catalina used a aluminum timing chain cover and cast iron water pump. My preference would be aluminum due to lighter weight (like it matters on those old road boats).
Re: Aluminum vs Castiron water pumps? [Re: Lubener] #5449631 06/09/20 10:09 AM
M
mpack88 Offline OP
M
You are correct. I took it off because it roars all the time and installed a fan clutch and a 7 blade fan from a 460. The ac wasn't working good at idle and it works better with the clutch. The clutch seems to be working now the ac works good but overheating at idle. FyI, it went from 10mpg to 12 mpg after installing the fan clutch. 20% gain in fuel milage is pretty good to me.
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449637 06/09/20 10:14 AM
M
mpack88 Offline OP
M
As far as the high flow water pump. All 23 reviews were positive in quality and all claimed it helped reduce temps at idle. Brand is flowkool at summit racing.
Re: Aluminum vs Castiron water pumps? [Re: Chris142] #5449640 06/09/20 10:15 AM
M
mpack88 Offline OP
M
It's a duralast from autozone. What brand do you recommend?
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449643 06/09/20 10:22 AM
DBMaster Offline
I tried a 7-blade flex fan on the old Pontiac and it didn't improve the overheating. It made a lot of noise and ultimately produced more vibration than a clutched fan and the water pump started leaking. My problem was that the car was always on the verge of overheating in the summer and actually did run hot frequently when running the AC in traffic. If I had kept the car I would have gone with the electric fan on the front option to supplement the belt driven fan. Mercedes used to do this routinely on cars of the same vintage. I had even replaced the 3-row radiator with a 4-row radiator. On my car airflow was the issue.
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449686 06/09/20 11:52 AM
Get the GMB aluminum
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449729 06/09/20 01:10 PM
R
Randy_R Offline
R
Check out Stewart Components. I think Summit has them but I bought mine direct, SBC stage 2 aluminum and 180 thermostat.
2018 Mazda CX-5 9000 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 70,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 Wix 51061
Re: Aluminum vs Castiron water pumps? [Re: mpack88] #5449760 06/09/20 01:57 PM
J
joegreen Offline
J
If you run an aluminum water pump do you have to change the coolant you use? If it's conventional green with silicates there might be cavitation issues that cause the aluminum to get eroded away? I would do some research on that.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Page 1 of 3 1 2 3
