Forums Migration
Please read this thread
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
100 registered members (4WD, ABN_CBT_ENGR, Anthony, 2003f7, AndyB, 2015_PSD, 10 invisible), 1,720 guests, and 33 spiders.
Topics307,542
Posts5,312,757
Members71,870
How are people mixing refrigerants? #5449386 06/08/20 11:08 PM
Chris142 Online Content OP
OP Online Content
I have been getting calls from people that have put R134a into their newer car that calls for R1234yf. How are they doing this as the fittings are different? One lady put a whole AC pro can into her 1234 car. How??
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: How are people mixing refrigerants? [Re: Chris142] #5449391 06/08/20 11:20 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I’m surprised any 1234 cars need service yet.
Re: How are people mixing refrigerants? [Re: JHZR2] #5449397 06/08/20 11:26 PM
OP Online Content
Seems to leak more than r134a. Lots of 17-18 cars needing a recharge already.
Re: How are people mixing refrigerants? [Re: Chris142] #5449401 06/08/20 11:48 PM
B
bbhero Online Content
Online Content
B
Redneck ingenuity LOL
Chris142... Do you think vehicle ac systems need to be recharged every so often?? Like every 8-10 years for example..
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: How are people mixing refrigerants? [Re: Chris142] #5449413 06/09/20 12:31 AM
clinebarger Offline
Swap out the 1234yf charge hose fitting for a R134a one. I do this on retrofit R12 systems all the time because retrofit fittings leak. Just a guess as I haven't messed with 1234yf yet.
2001 Chevy Camaro L92/4L80E
Re: How are people mixing refrigerants? [Re: bbhero] #5449418 06/09/20 12:42 AM
clinebarger Offline
Not answering for Chris.....But, Yes.....Most vehicles could use a vacuum & recharge every 10 years or so.
Re: How are people mixing refrigerants? [Re: bbhero] #5449497 06/09/20 07:13 AM
OP Online Content
More like 5-6 years. All systems leak a little. When they get 5+ years old they may still cool ok but will be low enough to not move the oil. Then the compressor locks up and you spend $1500+ to fix it.
Re: How are people mixing refrigerants? [Re: Chris142] #5449499 06/09/20 07:16 AM
G
GMBoy Offline
G
I am very familiar with the 1234yf. I was involved with the change-over on our SUV's in the plant. With that there is no reason you cannot go back to r134a in these systems. I just had a 2013 XTS in the shop that needed a new compressor and condensor. I discussed the price of the 1234yf vs the r134a and there was no hesitation of the customer to go back to the older freon. In 2013 XTS could have either freon as they were transitioning. The 1234yf required 1.30lbs of freon and r134a required 1.5lb per the service manual. This is pretty common practice with the high freon price for 1234yf. I have a specific set of gauges for r12, r134a and 1234yf.
Re: How are people mixing refrigerants? [Re: Chris142] #5449502 06/09/20 07:18 AM
supton Offline
Interesting! I am curious, as I have a couple of 10 year old vehicles that haven't had their a/c touched--another is 20 but I can't vouch for its first 15 years.
is there value in periodically testing the pressures in the system?
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: How are people mixing refrigerants? [Re: Chris142] #5449505 06/09/20 07:23 AM
R
RamFan Offline
R
Funny enough just this weekend I went to turn the A/C on in the Giulia and noticed no cold air. Couldn’t hear the compressor engaging either, popped the hood and took a look. Sure enough the compressor was just sitting there, no engagement at all. Was going to check the charge and discovered it has 1234yf, to the dealer it will go...
18 Giulia Ti Sport Q4
  • 2.0T I4 - 27k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 72k - Citgo Supergard Syn 5w30 - Wix - 7.5k/1yr
Re: How are people mixing refrigerants? [Re: supton] #5449546 06/09/20 08:21 AM
OP Online Content
No. The only way to check the charge is to remove what os in it,vacuum and recharge with a scale to spec.
I often get cars with normal pressures only to find them extreemly low on charge.
Re: How are people mixing refrigerants? [Re: GMBoy] #5449548 06/09/20 08:22 AM
OP Online Content
we just got one of the trade magazines. It says that putting r134 into a 1234 car is considered tampering with emissions and carries a hefty fine
Re: How are people mixing refrigerants? [Re: Chris142] #5449562 06/09/20 08:31 AM
Donald Offline
Do you just vacuum, check for leaks and refill or do things like replace all o-rings?
2015 Ford F-250 w/Powerstroke
Re: How are people mixing refrigerants? [Re: Donald] #5449575 06/09/20 08:55 AM
OP Online Content
if I replace the O-rings on the discharge side,schraders,orifice tube at the minimum on every car.
Re: How are people mixing refrigerants? [Re: Chris142] #5449576 06/09/20 08:55 AM
supton Offline
Ah thanks. I'll mull that over, wife's car is getting up there in age but it's a necessity for her car to have working a/c. Is there any risk to messing with a system that isn't showing signs of problems? As in, crack open a non-leaking valve and it'll leak just to spite you?
