Forums Migration
Please read this thread
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Horrible Duramax Aftermarket Filter Mod
by ToadU - 07/12/20 01:29 PM
Japan unveils timeline for indigenous fighter jet program
by gathermewool - 07/12/20 12:27 PM
NEW Rotella T6 15w40
by ToadU - 07/12/20 11:54 AM
2001 Silverado 1500 4x4 Alignment Concerns
by Blang - 07/12/20 11:37 AM
Full Synthetic for ATS V
by cadillactech - 07/12/20 11:33 AM
Gasoline engine oil in a diesel engine?
by LeslieX - 07/12/20 11:32 AM
Can I use IPA 70% to clean windshield?
by painfx - 07/12/20 09:47 AM
The Heat is on
by Snagglefoot - 07/12/20 07:39 AM
Working on your car
by CourierDriver - 07/12/20 07:35 AM
My last two cars were direct injection
by Railrust - 07/12/20 06:52 AM
fxxkat, Ajreitano, Slick122, Ford4life76, Patrick_Hall1988
71916 Registered Users
89 registered members (Alaskanmont, 2004tdigls, A310, 2strokeNorthstar, 4WD, 53' Stude, 9 invisible), 1,959 guests, and 26 spiders.
Topics307,769
Posts5,317,439
Members71,914
Any small engine carb experts? #5449121 06/08/20 03:39 PM
M
maverickfhs Offline OP
M
Does anyone know if float bowl(with same diameter), float and pin can be swapped between carburetors or they are designed specific to each model of the carburetor?
Have a almost brand new power washer: https://www.bobistheoilguy.com/foru.../costco-pressure-washer-carb#Post5448478 but missing float, pin and bowl.
So was planning to swap it from a non-working lawn mower after ensuring diameter is same.
Thanks for any tips and help thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Any small engine carb experts? [Re: maverickfhs] #5449123 06/08/20 03:45 PM
Z
Zaedock Offline
Z
I've fixed carbs from multiple donors to make a working unit.
You can test the functionality of the float by squirting some cleaner in the fuel line and manually exercising the float and needle to stop the flow.
As long at the float moves freely on the pin and the needle stops the gas, it should work p!ssah.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler / John Deere 750 Tractor
Re: Any small engine carb experts? [Re: Zaedock] #5449127 06/08/20 03:49 PM
M
M
Thank you in my case, everything present besides float bowl, float and needle.
So top part of the carb is good, just need bottom parts for it. thumbsup
Re: Any small engine carb experts? [Re: maverickfhs] #5449177 06/08/20 05:43 PM
N
Normac Offline
N
In many cases today, it's often cheaper and easier to replace the carb rather than rebuild it.
True victory does not come from defeating an enemy, true victory comes from giving love and changing an enemies heart.
Re: Any small engine carb experts? [Re: Normac] #5449212 06/08/20 06:53 PM
W
wings&wheels Offline
W
I had a hard time admitting to this myself....but very true. I have an old Massey Ferguson 16 lawn tractor that i use as a yard tug. I've serviced the carb a few times, but the float was at its end and it needed a new bowl gasket. But ~$30 had a brand new imported carb to my door and it runs the best it has in years.....
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Any small engine carb experts? [Re: maverickfhs] #5449235 06/08/20 07:23 PM
M
M
Do you guys recommend honda OEM or chinese should be good too? Thanks again
Re: Any small engine carb experts? [Re: maverickfhs] #5449241 06/08/20 07:42 PM
N
Normac Offline
N
Your choice, and often you get what you pay for.
At the same time, many people (including myself) have had very good luck with the Chinese carbs.
Re: Any small engine carb experts? [Re: Normac] #5449244 06/08/20 07:44 PM
M
M
Sure, have any recommended seller? Price difference is almost 2 times between Honda(Thailand) and Chinese one.
Re: Any small engine carb experts? [Re: maverickfhs] #5449246 06/08/20 07:46 PM
N
Normac Offline
N
Honestly - I usually go with whoever's cheapest (and a USA Seller, if possible) on 'The Bay'.
And while I can completely relate to what 'wings&wheels' was saying above, these days I'm more of a realist. It is what it is.
Re: Any small engine carb experts? [Re: maverickfhs] #5449263 06/08/20 07:59 PM
J
JLawrence08648 Online Content
Online Content
J
The original is the best but if it's no good then buy Chinese.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Any small engine carb experts? [Re: maverickfhs] #5449297 06/08/20 08:42 PM
samven Offline
You could always try the swap but the float needs to be the same height as the old one too and the needle needs to be the same length or else you need to try and figure a way to jury rig the float adjustment, that and hopefully the needle seat fits the needle shape (same taper) unless you are going to swap seats too.
The ebay carbs have been good to me, one in my snow blower and one in my tiller although the one in the tiller was not a perfect match I took linkage and vane off the old one and jury rigged it to the new one.
Re: Any small engine carb experts? [Re: samven] #5449383 06/08/20 10:56 PM
W
W
I had to do the same w/ the choke plate on mine....took a minute exclusive of time on the floor looking for a detent ball. The choke shaft was a bit loose and the screws would not swap between old and new because the new carb is metric.... Be careful swapping critical parts as they may not be a perfect match.
'05 Lotus Elise S/C
'74 Triumph TR6
'74 BMW 2002
'99 Porsche 996
Piper Pa28-236
Re: Any small engine carb experts? [Re: maverickfhs] #5449402 06/08/20 11:56 PM
A
andyd Online Content
Online Content
A
The 2 stroke Chinese clone carbs are proving to be reliable on the weed wacker and the Mantis. Both were less than 15$ delivered with the entire gas lines, filter plug and air filter. If I can't revive a carb with Berryman's Chem Tool, I go surfing the interwebs. I dose all the OPE fuel with MMO. Also fuel is dumped and carbs are run dry. 2 stroke is mixed 32;1, a qt at a time. Maybe when I mix the next qt, I'll take out the old Lawnboy I revived by cleaning the 30 yr old Walbro carb grin2
Thick oil is better grin2
Re: Any small engine carb experts? [Re: maverickfhs] #5449452 06/09/20 05:11 AM
Z
Zaedock Offline
Z
I agree with andyd from Mah-shfield.
I used a couple of new chinese carbs on two of my snow blowers last Fall and they worked very well and were $12-$15ea.
Replacement factory carbs, as you can expect, are much higher in price ($50 +/-). When I need to buy small specialty items, I've used Jack's Small Engines in Wisconsin.
The new chinese carbs can be a real time saver. With the Covid mess, I've been working from home for two months and have made time to catch up with old mower and small engine projects. I just took the time to clean the carb on a spare B&S 6.75 which will be installed on a Craftsman mower deck. I could easily toss it and buy a $130 mower, but I enjoy working on them and I don't like to waste stuff that still has plenty of life with a little bit of effort.
Re: Any small engine carb experts? [Re: maverickfhs] #5449564 06/09/20 08:32 AM
Donald Offline
No harm in trying. But new carbs are dirt cheap on Amazon or EBAY.
2015 Ford F-250 w/Powerstroke
