Forums Migration
Please read this thread
Are FSM Destined to the Dustbin of History?
by user52165 - 07/09/20 01:22 PM
Time to Dump or Repair?
by GMFan - 07/09/20 12:46 PM
TIREREVIEW : Videos
by odie - 07/09/20 12:39 PM
HYUNDAI ; Manual tranny w/o a clutch pedal
by odie - 07/09/20 12:30 PM
Need Pressure Washer Recommendations
by qdeezie - 07/09/20 12:28 PM
1992 Chevy 1500 Truck
by HowAboutThis - 07/09/20 12:01 PM
Window Tint
by The Critic - 07/09/20 11:59 AM
12 month Interval on oil ?
by jdw1222 - 07/09/20 11:06 AM
Toyota Caliper Pin Question
by Gebo - 07/09/20 11:02 AM
Iphone text being used for ads
by stockrex - 07/09/20 10:14 AM
Price shock with used cars
by dlundblad - 07/09/20 09:47 AM
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
kuldeep, BillDros, peterboyce, 99Burbans, EmanInOz
71897 Registered Users
117 registered members (77Se7en, 2004tdigls, 1911CHAMPION, 4WD, 53' Stude, 94astro, 11 invisible), 1,944 guests, and 34 spiders.
Topics307,646
Posts5,314,920
Members71,897
E85 Cleaning? #5449086 06/08/20 02:39 PM
P
Phishin Offline OP
P
So my 2018 Silverado 3500HD has the 6.0L gas engine under the hood. It's Flex Fuel compatible. The truck currently has 43k miles on it.
Usually ever 20k miles or so, I run 3-4 bottles of Gumout Regane High Mileage through the tank to give me a bit of cleaning.
Do you think running a tank or two of E85 through it would provide a decent amount of cleaning to the fuel system, including the injectors?
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: E85 Cleaning? [Re: Phishin] #5449139 06/08/20 04:06 PM
Skippy722 Offline
Every tear down I’ve seen while watching YouTube of engines running E85 look really clean. Whether that’s conjecture or not I’m not sure, as they’re usually high output, high strung engines.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: E85 Cleaning? [Re: Phishin] #5449181 06/08/20 06:01 PM
M
Mainia Offline
M
Yep!
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: E85 Cleaning? [Re: Phishin] #5449340 06/08/20 09:35 PM
Marco620 Offline
Maybe not! Gumout with Regane is gonna lay down a barrier to prevent ethanol corrosion so it cant inhibit anything. Throwing E85 / Gumout will probably nullify each other. I think its using one or the other but both working against each other seems more likely.
15' Civic r18, 344,000 mi M1 5w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Doberman Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: E85 Cleaning? [Re: Marco620] #5449458 06/09/20 05:52 AM
P
Phishin Offline OP
P
I wouldn't put Regane in the E85.......
My question was: Would running a tank or two (by itself) of E85 provide any cleaning?
Re: E85 Cleaning? [Re: Phishin] #5450363 06/10/20 09:16 AM
L
LeoStrop Offline
L
To the fuel system? Maybe it could clean some fuel lines and old gas deposits, but i think any dedicated fuel system cleaner will work better. The true cleaning effect of ethanol would be on the inside of your engine after the fuel is burned.
Chevrolet Kadett EFI '94 (Neat ethanol) - Shell Rimula RT4X 15W40
Honda Fit '09 (FlexFuel) - Shell Helix HX8 5W30 > Motul 6100 SYN-nergy 5W30
Re: E85 Cleaning? [Re: Phishin] #5451033 06/11/20 06:31 AM
silversport Offline
don't most engine manufacturers who offer flex fuel E-85 use recommend more frequent oil changes (Ford does with my 2007 F150 Flex Fuel 5.4 3V)...isn't the more frequent oil changes because the oil may be dirtier due to the use of that higher alcohol content in the fuel cleaning something???...
Bill
