Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
16 registered members (Gene K, Bjornviken, GMguy84, alcyon, farrarfan1, GumbyJarvis), 716 guests, and 35 spiders.
Topics307,584
Posts5,313,572
Members71,876
Honda Odyssey P3497 #5448988 06/08/20 11:28 AM
diyjake Offline OP
2014 Honda Odyssey has a CEL code P3497 - Cylinder deactivation system bank 2.
I searched the web and found that this code is for the front oil pressure sensor, either the oil level is low or faulty sensor. I changed the oil a week before the light came on so I double checked and oil level and that was good I replaced the sensor with a new OEM sensor, erased the code and it comes back a few days later. What else could be causing this code?
Re: Honda Odyssey P3497 [Re: diyjake] #5448992 06/08/20 11:45 AM
T
Trav Offline
T
A bad/sticking spool valve, dirty spool valve filter (sometimes there is one on the oil filter pad also as well as in the spool valve) can also cause this code also.
Check the engine for sludge and varnish.
Re: Honda Odyssey P3497 [Re: diyjake] #5448994 06/08/20 11:53 AM
JustN89 Offline
I did find a service bulletin covering this code: Honda SB 13-055
It's something to keep in mind, as the relief valve spring plays a prominent role in oil pressure, which is what drives this system.
You know what they say, cross threads are tighter than locktite!
Re: Honda Odyssey P3497 [Re: diyjake] #5449029 06/08/20 12:54 PM
diyjake Offline OP
I guess i'll have to dig in and replace the relief valve spring sooner than later.
How dangerous is it driving the van with the code / issue?
Re: Honda Odyssey P3497 [Re: diyjake] #5449255 06/08/20 07:52 PM
A
ARB1977 Offline
A
How many miles the the van?
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Honda Odyssey P3497 [Re: diyjake] #5449329 06/08/20 09:16 PM
diyjake Offline OP
104K
