Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
115 registered members (4WD, 1911CHAMPION, 2004tdigls, 55hambone, 77Se7en, 2015_PSD, 11 invisible), 1,799 guests, and 42 spiders.
Topics307,632
Posts5,314,635
Members71,894
Question about air filters #5448762 06/08/20 03:23 AM
B
boostedtsiawd Offline OP
B
The Hengst air filter at the top has way more paper than the Audi brand air filter on the bottom so wouldn't less paper equal to better air flow? I have a 2006 Audi A8 4.2l
[Linked Image]
[Linked Image]
Re: Question about air filters [Re: boostedtsiawd] #5448771 06/08/20 04:35 AM
W
WyrTwister Offline
W
No idea . One thing that could affect this is how " Porous " the paper is ?
Wyr
God bless
Re: Question about air filters [Re: boostedtsiawd] #5448813 06/08/20 06:31 AM
B
BMWTurboDzl Offline
B
I don't believe so.
Assuming the filter media is the same more pleats = more filter area = longer life.
Without knowing the individual characteristics of the filter media for the filters in question you're just guessing.
435i
Re: Question about air filters [Re: WyrTwister] #5448892 06/08/20 08:16 AM
G
Gebo Online Content
Online Content
G
Agreed.
If I may add a little info that you may find interesting. Your engine "meters" the amount of gas based on the volume of air.
As your filter gets more clogged, it will compensate for the more restricted air flow volume by reducing the amount of gasoline.
Your car's computer is constantly maintaining the proper air/fuel ratio.
I used to think that as my air filter got more clogged over time that it would hurt my gas mileage. I have now been
taught that is not the case as my car's computer will simply reduce the amount of gasoline being injected into the cylinders.
It may hurt performance, I guess???
I may not be saying this in the technically correct way.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Question about air filters [Re: Gebo] #5448898 06/08/20 08:30 AM
supton Offline
Originally Posted by BMWTurboDzl
I don't believe so.
That would be my guess also. More surface area (of the media) shoved into that area means it can be used for a longer time.
True. What happens as the filter clogs up is that the throttle valve is simply opened up more when more power is required. The extra drag of the clogged air filter is simply countered by opening the throttle more. Until one hits WOT then nothing is noticed. Until WOT the engine is being choked from full power output, and it doesn't matter if it's a throttle valve or something else restricting airflow.
In ye olden days it was different, the extra throttle opening might cause the carb to change from idle circuits to high speed circuits, and the extra vacuum signal might play with things... been too long since I understood how those worked, but they did use vacuum and were very mechanical in nature, and altering the system would alter the mechanisms at work. EFI just doesn't care (until WOT).
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Question about air filters [Re: boostedtsiawd] #5448976 06/08/20 11:11 AM
Strokenmerc Offline
Just judging by the pictures, the media appears to be different with the bottom filter being a thicker looking media. Not sure this explains the pleat number difference, but it may play into to price/performance aspect.
2018 Kia Sportage
2011 Chevrolet Cruze
2004 Silverado 2500HD
2003 Chevrolet Trailblazer
2001 Chevrolet Camaro SS
1999 Toyota Tacoma
Re: Question about air filters [Re: boostedtsiawd] #5449006 06/08/20 12:19 PM
B
B
Re: Question about air filters [Re: Strokenmerc] #5449071 06/08/20 02:04 PM
B
bbhero Offline
B
I tend to agree... Top one is a paper filter media. Bottom one could be synthetic. .
Nissan Altima 3.5 Coupe
Royal Purple 10w30+ Ceratec+ Carquest red 85358
"Treat your family like your friends and treat your friends like your family."
Re: Question about air filters [Re: boostedtsiawd] #5449196 06/08/20 06:18 PM
CR94 Offline
Originally Posted by boostedtsiawd
The Hengst air filter at the top has way more paper than the Audi brand air filter on the bottom so wouldn't less paper equal to better air flow? ...
No. If the media were the same, less paper would mean more restriction to flow. However, the media obviously isn't the same, so there's no way we can tell by looking which will create more restriction.
The air flow rate through both will be identical, except at or near WOT.
2011 Toyota Prius now at 111K
