Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
27 registered members (carlprop, Alfred_B, ChristianBerg, alex16, Blkstanger, clinebarger, 2 invisible), 761 guests, and 21 spiders.
Topics307,436
Posts5,311,039
Members71,848
fuel cleaner with premium #5448750 06/08/20 01:50 AM
A
avi1777 Offline OP
A
hi people
i read somewhere that its better to use premium fuel when using a fuel cleaner(i use the sl-1)
is it so?
tnx.
Re: fuel cleaner with premium [Re: avi1777] #5448754 06/08/20 02:29 AM
B
blufeb95 Offline
B
Originally Posted by avi1777
hi people
is it so?
tnx.
No reason to use premium in a car that doesn't need it, in most cases it only contains a marginal amount more detergent than regular gas. With premium being as much as $1 more per gallon than regular, I'd skip putting premium in the tank, for as much extra as you pay for a tank of premium you could run buy a second bottle of fuel system cleaner.
Re: fuel cleaner with premium [Re: avi1777] #5448757 06/08/20 02:44 AM
A
avi1777 Offline OP
A
tnx but i meant using premium only during the use of a fuel cleaner,not on a regular basis.
Re: fuel cleaner with premium [Re: avi1777] #5448761 06/08/20 03:19 AM
Char Baby Offline
Again, No reason to use premium fuel even when just using the FSC.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: fuel cleaner with premium [Re: avi1777] #5448803 06/08/20 06:00 AM
P
philipp10 Offline
P
hi people
is it so?
tnx.
First off you fuel system doesn't need cleaning. The gas you run through it is clean and on top of that, filtered inside your car. Secondly, no the grade of fuel makes no difference.
Re: fuel cleaner with premium [Re: avi1777] #5448824 06/08/20 06:56 AM
B
BMWTurboDzl Offline
B
Answer: It should be irrelevant.
Side note: The blending rates for additives dispensed at the terminal have been posted on this site before. It's a fact that premium fuel gets more additive.
435i
Re: fuel cleaner with premium [Re: avi1777] #5448882 06/08/20 08:03 AM
G
Gebo Offline
G
I don't know if it's better, but I always add premium when I run a fuel cleaner.
I will run a cleaner about once a year in all my cars. I use the Amsoil Cleaner.
I also only use Top Tier Gasoline here in the US. Do you have Top Tier in Israel?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: fuel cleaner with premium [Re: avi1777] #5448914 06/08/20 08:53 AM
Donald Offline
hi people
is it so?
tnx.
Better to use Top-Tier. Premium only needed is the owners manual calls for it.
2015 Ford F-250 w/Powerstroke
Re: fuel cleaner with premium [Re: avi1777] #5448948 06/08/20 10:15 AM
A
avi1777 Offline OP
A
we have 98 octane which is103 in the u.s,we dont have the top tier.
Re: fuel cleaner with premium [Re: avi1777] #5448949 06/08/20 10:19 AM
A
avi1777 Offline OP
A
I use 95 octane which is 100in the u.s and is the lowest octane we get here.we have 95,98 or diesel.
Re: fuel cleaner with premium [Re: blufeb95] #5448951 06/08/20 10:22 AM
T
Triple_Se7en Offline
T
hi people
is it so?
tnx.
I wouldn't pay $1.00 more for 93 octane Shell, but I would pay 65 cents more, as I just did buy 13 gallons one hour ago. My vehicles run better on it, versus 87 octane.
My lawnmowers and gas blower and snow blower too.
I use a 20oz bottle of Techron Concentrate every 4K, two fill-ups prior to oil change.
Stay Safe - Stay Healthy
Happy July 4th
Pennzoil Ultra Platinum // Mobil-1 EP // Valvoline Synthetics
Re: fuel cleaner with premium [Re: philipp10] #5448952 06/08/20 10:23 AM
Davejam Offline
On the first point here I disagree. IF you only use top tier fuel then perhaps the fuel system cleaner isn't absolutely necessary.
But even so using a good fuel cleaner like sl-1 should help keep pistons and valves cleaner than not using it.
On the original point. No you don't need to use premium fuel. It is sometimes discussed whether higher octane would make an engine run hotter or colder and whether that would help.
But there is no real consensus and it is really theoretical. Using the fuel system cleaner at the recommended octane for your vehicle is what you should do.
Edit: Sorry I see this is in Israel, and 'top tier' fuel is a US thing. The point is the name brand fuels likely are putting adequate cleaning detergents, etc in the fuel. Avoid off-name/no-name fuel stations if you can on a regular basis. But the sl-1 should still benefit you.
Re: fuel cleaner with premium [Re: avi1777] #5448957 06/08/20 10:38 AM
R
Rand Offline
R
you are backwards.
your country uses RON, USA is AKI
95 ron = 89 AKI aprox.
if using a techron product average treat levels are aprox 10x the additives in normal gas if used according to directions.
so even if premium(93) had double the additives of regular(87) which it doesnt...
using Premium would not be much different than regular. for the additive concentration.
Re: fuel cleaner with premium [Re: avi1777] #5448971 06/08/20 11:00 AM
G
Gebo Offline
G
My understanding is he's just asking if he should use premium gas only when he is using a fuel cleaner.
Just one tankful. Not as a permanent issue.
Since you say you don't have Top Tier gasoline in Israel, I'd be using a cleaner 3-4 times a year.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: fuel cleaner with premium [Re: BMWTurboDzl] #5448972 06/08/20 11:04 AM
B
blufeb95 Offline
B
But it was only a small amount more, the amount of additive in a bottle of fuel system cleaner is far more than what is in top tier gas even, Chevron says that their fuel system cleaner when used one ounce per gallon is about 10x the amount of additive as is in their Chevron gas w/ techron that you get at their gas stations. The blend chart showed that premium only gets like 25% more additive so if you were to use regular Chevron gas with Techron fuel system at 1oz/gal you'd have about 11x the concentration of PEA as is in the fuel normally if you use premium you'd have 11.25x the concentration given that it's like $10-20 more to fill most tanks with premium now it's certainly not worth paying extra for it because it has a marginal amount more detergents, you'd be better off buying regular and doing a double dose of fuel system cleaner if that was your concern.
