Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
84 registered members (antonmnster, 4WD, andy2001, Alfred_B, Arrechera, Atrocious, 5 invisible), 2,079 guests, and 23 spiders.
Topics307,450
Posts5,311,404
Members71,850
2006 scion tc intake manifold oil leak #5448676 06/07/20 09:57 PM
R
researcher Offline OP
R
I discovered a weeping oil leak on the air intake manifold on my 06 Scion tc. I know the 2az-fe engine has the head bolt issue, but that doesn't look like the issue here. It's only one bolt (furthest right side) that's wet with oil towards the throttle body (driver's side of the car).. I didn't try snugging that bolt down because I could see a bit of the gasket sticking out.. which I don't think is normal at all.. Is it a common issue or known issue with the intake manifold gasket going bad? Thought I'd ask.. yes I know I'll have to get in there and take things apart, but wanted to ask..
Re: 2006 scion tc intake manifold oil leak [Re: researcher] #5448844 06/08/20 07:27 AM
R
rob1715 Offline
R
03 - 08 Toyotas (1.8 and 2.4) had an issue with oil leaks. My 03 Matrix bought used about 3 years ago with 80k miles, and had to replace all gaskets. I guess Toyota was trying to cut corners and oil leaks is what happened. Just the nature of that particular beast.
2003 Toyota Matrix - Whatever synthetic is cheapest - OEM Filter
2019 Kia Sorento - OEM Filter
“Think of how stupid the average person is, and realize half of them are stupider than that.”
Re: 2006 scion tc intake manifold oil leak [Re: rob1715] #5450176 06/09/20 11:38 PM
R
R
thanks for the info! I am towards 70k miles, and that makes a lot of sense that it's coming from the valve cover gasket.. Since there isn't any oil sources around the air intake manifold (itself).. Thinking what you're saying, it IS 14.5 years old now! Guess nothing lasts forever. grin2
Re: 2006 scion tc intake manifold oil leak [Re: researcher] #5450343 06/10/20 09:00 AM
M
MarkM66 Offline
M
Not sure why that much oil is running through the intake ???
Maybe PCV system needs a look.
Then change intake gasket.
Re: 2006 scion tc intake manifold oil leak [Re: researcher] #5459472 06/21/20 09:45 PM
R
R
UPDATE: I was able to check the valve cover gasket (didn't have time until now, no I haven't been driving this Scion) and I found the entire valve cover gasket is DRY! There is no oil leaking from there to the intake manifold. I looked below the intake manifold area and it looked dry. I'll probably have to get up from underneath and use an inspection camera to see behind the air intake manifold. The PCV valve system is completely dry. And how could an air intake manifold be leaking oil??
Is this the dreaded head bolt issue that the 2az-fe is known for? Can the head bolts pull free enough to leak oil but not enough to have coolant in the oil or oil in the coolant? There isn't any in either right now. If it is the headbolt issue I remember hearing ARP made a kit for this? I'll check just thinking.
If it isn't the headbolt issue, what else at the back of the engine besides this??
