Forums Migration
Please read this thread
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
22 registered members (alcyon, Bjornviken, EdwardC, ChristianBerg, edhackett, Bailes1992, 3 invisible), 725 guests, and 29 spiders.
Topics307,584
Posts5,313,570
Members71,876
Honda GX390 #5448658 06/07/20 09:43 PM
M
mobilaltima Offline OP
M
Honda GX390 13 hp air cooled, Blackmax Generator 8kw , my dad bought it new for Hurricane Katrina, so its knocking on 15 years old but it has never given him a lick of trouble and doesnt have many hours ( thankfully, low hours means not much hurricane activity). I've maintained it for him using various 30 and 40 wt oils, but I'm considering switching to either M1 15W50, as recommended by Cujet, or a natural gas specific 15W40 oil. I brought up the natural gas oil due to the fact that my dad had a natural gas conversion kit put on it years ago, he has a hose under the house with a valve that he connects to it and can run it continuously until either the power comes back on or when he has to stop it to change the oil, which I do every 50 hours. So should I go with the 15W50, or the natural gas 15W40, and should I keep the oci at 50 hours or extend it to 100? I'm also considering the fact that the 15W40 NG oil is normally used in liquid cooled NG engines, so it may not be the best oil for this air cooled, high heat engine.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Honda GX390 [Re: mobilaltima] #5448700 06/07/20 10:21 PM
CT8 Offline
I havea Honda GX 390 on a pressure washer I have used 15W-40 and 5W-40. 15W-50 M1 would be fine .Change the oil often as there is no oil filter.
2015 F150 2.7
2018 F350 6.2
Re: Honda GX390 [Re: mobilaltima] #5448730 06/07/20 11:38 PM
M
motor_oil_madman Offline
M
Is the GX390 13hp or 11hp? I swear I've heard it be called either one.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Honda GX390 [Re: mobilaltima] #5448731 06/07/20 11:40 PM
M
M
I use 15w40 in mine. 20w50 would be fine too, if you're in the south. I'm not sure how much harder it would make it to start if it was cold though, the pull cord likes to try and dislocate my arm occasionally. You have to make sure it's on the compression stroke so this doesn't happen cause it hurts. lol
Re: Honda GX390 [Re: motor_oil_madman] #5448887 06/08/20 08:11 AM
CT8 Offline
i have GX160 on my irrigation lines to move them, running 5W-40 Rotella during the summer the engines starter rope pull easy and start by the time the pull cord is pulled 1 compression stroke, in the winter "freezing" weather the engines starter rope pulls really hard and takes a while to start. It is amazing the difference.
2015 F150 2.7
2018 F350 6.2
