Forums Migration
Please read this thread
anyone noticed worse acceleration with fram ultra?
by cals400ex - 07/09/20 08:39 AM
Good article on battery recycling
by Fattylocks - 07/09/20 07:19 AM
Civic rear wheel bearing
by toad - 07/09/20 07:06 AM
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
99Burbans, EmanInOz, Apollon, lulliya, bike70ride
71894 Registered Users
100 registered members (afree, ARCOgraphite, 2015_PSD, 1911CHAMPION, amh, 4WD, 9 invisible), 1,762 guests, and 45 spiders.
Topics307,632
Posts5,314,667
Members71,894
AC taking too long to cool #5448322 06/07/20 12:57 PM
dan765 Offline OP
Hello,
'12 Hyundai Genesis, ~93k miles.
Taking the AC a while to cool. If I start the car on a hot day and let it idle it doesn't get cold. it just blows hot air. When I start driving, it takes quite a few miles for it to start to cool. When it eventually does, it blows nice and cold, though. An suggestions?
2012 Hyundai Genesis 3.8L sedan
2015 Hyundai Santa Fe Sport 2.4L
Re: AC taking too long to cool [Re: dan765] #5448329 06/07/20 01:10 PM
R
Rygrego Offline
R
Have your A/C serviced. You're probably a little low on refrigerant.
Re: AC taking too long to cool [Re: Rygrego] #5448341 06/07/20 01:29 PM
CT8 Online Content
Online Content
I bet a higher grade of syn oil would fix the problem !!! yep get the AC looked at.
2015 F150 2.7
2018 F350 6.2
Re: AC taking too long to cool [Re: dan765] #5448348 06/07/20 01:47 PM
Chris142 Offline
No system is 100% leak free. Most of the cars I recharge are 5-7 years old. Yours being 8 is due.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: AC taking too long to cool [Re: dan765] #5448400 06/07/20 03:03 PM
Starman2112 Offline
Check the condenser fan(s).
2018 Toyota Tacoma SR5, 4X4, 2.7L / Mobil 1 AFE 0W-20 / OEM filter
2010 Toyota Camry LE, 2.5L / Mobil 1 AFE 0W-20 / OEM filter
Re: AC taking too long to cool [Re: Starman2112] #5448404 06/07/20 03:08 PM
Char Baby Offline
Yes, check your system.
Check the condenser fins for debris, cotton, lint
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: AC taking too long to cool [Re: dan765] #5448464 06/07/20 04:23 PM
R
Reddy45 Offline
R
You can also buy a can of this and spray down the condensor and radiator. A car with 93k miles on it probably has a lot of gunk on the fins.
https://www.homedepot.com/p/AC-Safe-Air-Conditioner-Foaming-Coil-Cleaner-AC-921/206740351
Re: AC taking too long to cool [Re: dan765] #5448505 06/07/20 05:19 PM
01rangerxl Offline
I had the same symptoms with my 02 Ranger, it ended up being the compressor relay.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 241K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 256K miles
Re: AC taking too long to cool [Re: dan765] #5448515 06/07/20 05:35 PM
Nick1994 Offline
Make sure the fans are working properly. But probably just low on refrigerant.
Don’t just top it off. It needs to be recharged with a legit machine by weight.
2015 Hyundai Genesis 5.0L 63k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: AC taking too long to cool [Re: 01rangerxl] #5448560 06/07/20 06:51 PM
dan765 Offline OP
How did you figure it out? My problem is that if I take it for someone to look at it then by the time I get there, it will be blowing cold.
Re: AC taking too long to cool [Re: dan765] #5448567 06/07/20 07:00 PM
01rangerxl Offline
Honestly, guessing and next cheapest thing to replace. I had thrown a can of freon at it with no change, so I got an OE relay which was around $15, and it started working fine. That was 9 years ago, haven't touched the AC since and it still works great.
Re: AC taking too long to cool [Re: dan765] #5452113 06/12/20 12:46 PM
Silver Offline
Search youtube for ac diagnosis videos. Check one thing at a time.
