Forums Migration
Please read this thread
Nokian Entyre C/S
by Robster - 07/09/20 06:00 AM
Corolla Cross
by wemay - 07/09/20 05:51 AM
Pennzoil strikes again with PDS (Euro 5W40)
by edyvw - 07/09/20 01:44 AM
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
84 registered members (86cutlass307, 77Se7en, alarmguy, 55hambone, afree, 94astro, 11 invisible), 1,209 guests, and 39 spiders.
Topics307,629
Posts5,314,533
Members71,888
Run away tiller #5448096 06/07/20 06:28 AM
dlundblad Offline OP
Ie the widowmaker.
I gave up on the engine that was originally in my hand tiller and put a HF 6.5 hp Predator engine on it. Couldn’t get it running. Cleaned the carb, bought a new carb that didn’t have matching holes. etc. Small engines aren’t my forte.
Anyways, everything works the way it should including the self propelled, minus it having no reverse (original 5 hp Briggs had twin cranks that made reverse with a tensioner) and the throttle is now at the engine rather than the handle.
It does decent on soft soil with the depth gage lowered, but if it’s angled just right, it’ll shoot across the ground pulling me with it. Quite the site to see I’m sure. Any deeper amounts of soil and/ or lower throttle and it does the same thing.
What would cause this?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Run away tiller [Re: dlundblad] #5448124 06/07/20 07:15 AM
A
Astro_Guy Offline
A
Sounds like a Try-Bilt Pony. Am I getting warm? Normally the drive wheels would hold it back. Mine would only take off like that when trying to till too deep into soil that hadn't been tilled before. Try multiple passes, lowering the tilling depth as you go.
'01 Volvo V70XC, 253k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: Run away tiller [Re: dlundblad] #5448137 06/07/20 07:49 AM
E
eljefino Offline
E
haha, I have the same setup. What's worse is the spring that held it in neutral broke, so it would jump into gear when idling. crzy Fixed that with a zip-tie and a leftover spring from a drum brake hardware kit.
You're catching roots or other obstacles with the tines. Wife is the "tiller operator" and she was mad that the factory tecumseh motor wouldn't pull like a bull at 1000 rpm, and kept stalling. I put the predator on and she's tickled now with the torque and smooth running.
Re: Run away tiller [Re: dlundblad] #5448161 06/07/20 08:32 AM
J
JLawrence08648 Offline
J
If it's front tine, Normal; if it's rear, and no drive wheels, Normal; gear driven machines less so, heavy machines, Never!
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Run away tiller [Re: dlundblad] #5448180 06/07/20 08:56 AM
M
mk378 Offline
M
Is the wheel clutch engaged? With the engine stopped you should NOT be able to roll the machine freely on the wheels. On a Troy-Bilt Pony, etc. the wheel clutch is the turn lever on the right side to disengage the wheel drive to roll the tiller around with the engine stopped. During operation it should be engaged instead.
I always thought the tires should be put on backwards from how tractor tires are normally mounted, since their real purpose is not to drive the machine forward, but to hold it back.
Re: Run away tiller [Re: dlundblad] #5448221 06/07/20 09:41 AM
The garden was tilled with a 3 point tiller behind the tractor last fall. No roots or obstacles.
It’s a rear tine forward rotating tiller. Pretty heavy too and has the front weights. Figured an old school beefy tiller with a reliable engine would be the ticket. The wheels are pinned when in use.
Could dull tines case this?
*The engine bolted right up btw. No drilling required.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Run away tiller [Re: dlundblad] #5448226 06/07/20 09:58 AM
N
NormanBuntz Offline
N
I had a very similar tiller made by Snapper. With your throttle no longer on the handle, be careful! It could easily be a widow maker.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Run away tiller [Re: NormanBuntz] #5448321 06/07/20 12:56 PM
U
user52165 Offline
U
Yup. Install this or similar:
https://smile.amazon.com/Stens-290-163-Throttle-Control-Cable/dp/B00D9TI6WI/ref=sr_1_5
Re: Run away tiller [Re: dlundblad] #5448409 06/07/20 03:13 PM
E
eljefino Offline
E
I have not had great luck fitting throttle cables to HF engines. They have too much friction in the pivots of their throttle levers.
However, you could easily install an electric kill switch. Splice into or replace the low-oil shutdown wire.
Re: Run away tiller [Re: eljefino] #5448468 06/07/20 04:32 PM
U
user52165 Offline
U
You do realize there is an adjustable nut with nylon insert to set the tension on the pivot? wink
Re: Run away tiller [Re: dlundblad] #5448614 06/07/20 08:14 PM
Good idea on the kill switch at least. I’ll see if I can rig something up for the throttle too.
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
