Hour meter - not moving?
by Serge - 07/04/20 11:52 AM
Was in a Parade today!
by sasilverbullet - 07/04/20 11:40 AM
Amsoil bypass kit ford 6.7 (BMK33)
by willypete - 07/04/20 11:39 AM
Should I buy a "B" Temperature tire for 2016 Pilot?
by oily boyd - 07/04/20 11:15 AM
Happy 4th of July
by 4WD - 07/04/20 09:12 AM
Collective car nouns, real and imagined
by MrHorspwer - 07/04/20 08:44 AM
Motorcraft FL-820S, ~9000 miles
by robertcope - 07/04/20 08:42 AM
FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
78 registered members (aquariuscsm, bdcardinal, 94astro, Audioquest, 1WildPig, bchannell, 8 invisible), 2,051 guests, and 16 spiders.
Topics307,409
Posts5,310,566
Members71,843
Page 1 of 3 1 2 3
Which brake pads for towing? #5447946 06/06/20 08:27 PM
P
pburchett Offline OP
P
I have a 2008, F150, Crew Cab, 5.4L, 4X4, 6.5 ft bed, 78,000 miles. Weighs in around 6000 pounds. When I bought it the brakes sucked, brake dust was bad and it ate rotors.
I up-graded (or so I thought) to the Wagner ThermoQuite semi metallic pads and rotors. No difference except the drake dust was almost non-existent. Still didn’t want to stop and it ate the rotors.
I now tow a trailer and tractor (about max towing capacity) once or twice a year so went to Bendix Fleet MetLok severe duty semi metallic brake pads and rotors. These stop better, rotors are holding up, but the dust is unbearable.
It is time to get something with less dust. Looked at Power Stop Z36 Carbon Fiber Ceramic but several reviews state that the first two stops are as if the brakes went out. Don’t need this. Several state that Raybestos and Bosh make good pads. Going to buy through Rock Auto.
Suggestions…
Re: Which brake pads for towing? [Re: pburchett] #5447971 06/06/20 09:00 PM
M
MParr Offline
M
Forget about the Power Stop products. The Bendix fleet brakes are pretty darn good for your application. You are not going to get good stopping performance out of ceramic pads. You are going to need severe duty semi-metallic pads for towing. I like Wagner Severe Duty or the Motorcraft equivalents. You are going to get brake dust from semi-metallics. But, your vehicle will stop better and the pads and rotors will stay cooler.
https://www.wagnerbrake.com/products/brakes/wagner-sd-severeduty.html
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Which brake pads for towing? [Re: pburchett] #5447975 06/06/20 09:06 PM
Chris142 Offline
I do not think that you will get goods stopping power from 1/2 ton brakes.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Which brake pads for towing? [Re: pburchett] #5447982 06/06/20 09:12 PM
samven Offline
Nothing stops like semi metallic but as you found out they are dusty and the dust sticks and they eat rotors for breakfast. I have the same issue with my Dodge 1500 QC. When I asked the mechanic at the shop that does my inspections he said the only real solution was to upgrade the callipers and rotors to an oversized kit with multiple pistons if it would fit in my wheel.
Re: Which brake pads for towing? [Re: pburchett] #5448016 06/06/20 10:19 PM
O
Oildudeny Offline
O
You definitely want to go semi-metallic.. Akebono are always nice..
Re: Which brake pads for towing? [Re: pburchett] #5448018 06/06/20 10:23 PM
B
buck91 Offline
B
Now I don't tow but once every few years but I switched to Power Stop Z36 on my 2011 back in Feb (had one caliper seize and eat the pad/rotor before I could get to tear down and got a screaming deal on the PS kits). So far I've been very impressed. Heavy zinc coating on the rotors shows zero signs of break down after initial 1/2 winter of use. Brakes have an excellent feel, far better that OE or the Wagner TQ's I also ran prior to this. Brakes on my 2011 Scab seriously out perform the brakes on our newer 2018 Screw. Of course, I can't comment on longevity yet, nor on towing but so far so good.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Which brake pads for towing? [Re: MParr] #5448023 06/06/20 10:50 PM
CKN Offline
Power Stop products are very popular over on the Chevy Silverado Boards and guys like them.
Re: Which brake pads for towing? [Re: pburchett] #5448030 06/06/20 11:02 PM
slacktide_bitog Online Content
Online Content
Wagner has a line of Severe Duty pads. There is also OEX which is ceramic but should be better than the Thermoquiets smile
Akebono ASP pads are also good stuff
There's also Hawk LTS and EBC Greenstuff 6000. EBC also makes orange "extra duty" pads, but they are very expensive
A recent BITOG favorite seems to be the Raybestos EHT
Re: Which brake pads for towing? [Re: CKN] #5448033 06/06/20 11:06 PM
4WD Offline
I had PowerStop Truck/SUV pads with Callahan slotted zincs on my 2010 GMC.
History was:
Factory pads were getting too weak for 2k trailer with no brakes towed at 70 MPH speed limit
Went to EBC Yellow … great stopping power … BUT, ate discs in no time flat …
Went to the above, better stopping than the OEM without rotor damage …
(in hindsight would have been ideal) …
Re: Which brake pads for towing? [Re: pburchett] #5448063 06/07/20 12:52 AM
Z
Zaedock Offline
Z
I have Powerstop brakes on my '12 F150.
1) It is not my daily driver (my company Escape is). It's used for towing and firewood work.
2) I completed the appropriate break-in procedure. Stops on a dime - i.e. Awesome.
3) I tow my 5500lb Jeep on my 1800 lb trailer several times a year as well as my 26' Jayco camper and a 18' trailer full (plus bed) of ATV's.- No issues.
I have also pulled a couple cord of green oak (11,000 lbs) without issue -in my town.
There are bunch of good pads for your app. Not sure why you're not doing rotors too? Brake performance with a new matched set of rotors and pads would offer the best performance. Powerstop has worked well for me and is inexpensive. My $.02
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Which brake pads for towing? [Re: pburchett] #5448079 06/07/20 05:24 AM
G
Gasbuggy Offline
G
Akebono baby
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Which brake pads for towing? [Re: pburchett] #5448112 06/07/20 06:56 AM
J
Jimzz Offline
J
Yea get a good set of semi-metallic or performance ceramic pads.
The RAYBESTOS SP1083TRH are a good truck based semi-met pad. Will make some dust but hold up well to towing.
If you want a ceramic pad the POWER STOP Z361011 are made for high heat while using a ceramic base.
The RAYBESTOS EHT1083H is a hybrid pad that offers a little better performance than ceramic without much dust.
yup
Re: Which brake pads for towing? [Re: pburchett] #5448134 06/07/20 07:44 AM
M
Micahmcmeen Offline
M
I have powerstop on my jeep and they have done well.
Re: Which brake pads for towing? [Re: pburchett] #5448166 06/07/20 08:35 AM
U
UncleDave Online Content
Online Content
U
Hawk LTS Pads and
Frozen rotors / rotor pro rotors.
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Which brake pads for towing? [Re: pburchett] #5448185 06/07/20 09:00 AM
P
P
I am going to keep the Bendix MetLock Rotors as they are almost new with less than 5,000 miles on them. They seem like good rotors.
I think there is several new formulations of pad materials but with the Covid outbreak getting in touch with someone at most companies is nearly impossible.
Page 1 of 3 1 2 3
