FJC Foaming Evaporator Cleaner Review
by Reddy45 - 07/04/20 12:10 AM
Ford 351W oil filter best value
by alex16 - 07/03/20 11:12 PM
Super tech euro 5w40 - Canada
by Johan1 - 07/03/20 10:19 PM
Strangers show up for vet's funeral.
by simple_gifts - 07/03/20 09:44 PM
Troybilt tb22ec refuses to run correctly
by Dogred08 - 07/03/20 09:43 PM
Harbor Freight Nitrile gloves
by 1978elcamino - 07/03/20 09:04 PM
Did anyone get a 25% coupon for July 4th?
by 1978elcamino - 07/03/20 08:58 PM
05 4.6 Northstar crank sensor re learn?
by cknight49090 - 07/03/20 08:40 PM
In the year 2049...
by eljefino - 07/03/20 08:05 PM
2-year old oil 124 Spider
by DAC17 - 07/03/20 07:57 PM
New to us van
by ram_man - 07/03/20 07:22 PM
original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Johan1, MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria
71843 Registered Users
67 registered members (AandPDan, alarmguy, Alaskanmont, Astro14, 555, amh, 6 invisible), 1,389 guests, and 27 spiders.
Topics307,398
Posts5,310,392
Members71,843
Computer - Hypervisor - Increase I/O Performance #5447768 06/06/20 03:30 PM
B
brueggma1 Offline OP
B
Greetings,
Are there any VMWare or VirtualBox gurus on this board? I'm looking to increase I/O performance on an old Dell referb. I was thinking about purchasing a PCie to NVMe adapter and a NVMe card to speed things up. My question is how should I use the space? Can I use it as some kind of cache that sits infront of the spinning HHD? I think I need to pay $$ VMWare for this, no?
Is RH/Debian + Virtualbox a better option? Maybe using lvmcache?
Computer: Dell Optiplex 9010 - 16Gb Mem - i7-3770 - 2Tb Spinning HD
Hypervisor: ESXi 7.0 (free version)
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447780 06/06/20 03:41 PM
Skippy722 Offline
I’d ditch the spinning HDD entirely and replace it with a SSD personally.
Intel’s Optane acts as a cache and stores your more used data on that case the HDD.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447788 06/06/20 03:58 PM
T
terry274 Offline
T
I don't really understand what you are trying to do, but Debian supports kernel based virtual machines natively. The link below may help:
System virtualization
And I agree, change to an SSD drive instead of the spinning platter.
2011 Toyota Avalon
2019 Honda Ridgeline
2009 Ford Taurus
2012 Honda Accord
1996 Ford F150
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447829 06/06/20 04:51 PM
J
Jethro_Bob Offline
J
Do you actually need a Hypervisor? More specify are you running two or more operating systems at the same time?
If not, it will severely slow down your computer even when it's not in use. (For example, on bootup an os has to check all hardware even the virtual stuff, so it's always running and changing how you computer "sees" stuff.
Anyways, the Dell Optiplex 9010 actually has bios updates that actually supports NVMe and in some cases (depending on the drive) it's even bootable. You are the rare exception to the rule "never update your bios" because NVMe wasn't even a thing that existed when your pc was built.
Also, there are fake adaptors like this one: youtube
There is a lot more info here by people have accomplished this: Dell
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447830 06/06/20 04:51 PM
J
JustinH Offline
J
Is ESXI running encapsulated in windows or is it running raw metal on the 9010?
Either way the drive is too slow, and there isn't enough cores or memory for running a hypervisor.
Also there is no RAID array in place.
May I suggest a used dell rackmount server.
'16 Ford Escape
'11 Scion XB
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447890 06/06/20 06:59 PM
B
B
Thank you everyone for your perspective. I don't hear any feedback about using SSD/NVMe as a caching store of any kind, so I think I'll stay with ESXi and get a 1Tb NVMe drive to use as a typical datastore for the VMs that are important to me, and use the spinning disk for the O/S collection in the home LAB.
I was hoping that there was a solution to use NVMe device as a disk cache backed by a legacy spinning disks, so that all reads/writes went through the NVMe device to speed up for any subsequent disk I/O. Almost like a home made Hybrid SSD/HDD drive. This way I can have lots of cheap spinning storage, and a small amount of really fast/expensive NVMe cache.
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447893 06/06/20 07:02 PM
wwillson Online Content
Administrator
Online Content
Administrator
With virtualization, nomatter which hypervisor, the way to speed is RAM. You should have enough RAM so that your hypervisor rarely or never has to swap to give the virtual machine more memory. If that happens, the quest for performance is pretty much over. If you're going to run a single instance of Win10 and give it 8GB RAM, then make sure your hypervisor has 16GB. Another huge performance gain is the hardware virtualization extensions in the CPU. If a CPU doesn't do hardware virtualization, then forget it, find a box that does.
Don't spend $$ chasing performance with HDD IO, as it's a waste of money. Buy RAM
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5447932 06/06/20 07:57 PM
J
Jethro_Bob Offline
J
Ok, it sounds like you're looking for something like 'Intel Optane.' Unfortunately it's only available on Intel's 7th generation or newer. As wwillson said ram is the best option even with newer machines. You also notice a difference if you switch to ssd for storage, it's possible to get a 2tb ssd around the $200 range.
Re: Computer - Hypervisor - Increase I/O Performance [Re: brueggma1] #5448211 06/07/20 09:20 AM
B
B
Thank you everyone,
Sounds like I'm in the market from some memory and some new storage devices..
