Forums Migration
Please read this thread
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
55 registered members (avi1777, Bailes1992, alchargo, AlienBug, ammolab, Astro14, 7 invisible), 1,346 guests, and 31 spiders.
Topics307,780
Posts5,317,676
Members71,917
Oil Pan Plug Problem #5447575 06/06/20 10:14 AM
CarbonSteel Offline OP
How tight should a oil pan plug be?
Asking for a friend who works at Jiffy Lube...
[Linked Image]
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Kendall GT-1 Max + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447582 06/06/20 10:25 AM
I
Inspecktor Offline
I
Needs another quarter turn.
2004 Mini Cooper 45,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 75,000 mi
2001 Buick LeSabre Limited 303,000 mi
2001 Subaru Outback 171,000 mi
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447584 06/06/20 10:28 AM
J
JeffKeryk Offline
J
Love the wrench...
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447593 06/06/20 10:49 AM
W
wkcars Offline
W
48 ft-lbs like it says on the lug
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447616 06/06/20 11:19 AM
Yah-Tah-Hey Offline
Well would you look at that. If 28 ft lbs is good, 58 ft lbs in gooder. Go for it cowboys.
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447629 06/06/20 11:40 AM
supton Offline
I see a dot between the 4 and the 8. Means 4.8 unga-dungas. To get past 4.0 one usually has to rap it with a hammer so as to make sure it's exceeded one guttentight.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447652 06/06/20 12:10 PM
J
Jetronic Offline
J
guys, no wonder the bolt was torqued too tight!, for lubricated bolts you have to reduce the torque spec by 30%, so 3.2 ish unga-dungas....
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447659 06/06/20 12:14 PM
L
LMG1 Offline
L
Righty-tighty, lefty-loosey...
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447669 06/06/20 12:29 PM
T
Trav Offline
T
That looks about right. Who needs a stinkin torque wrench for an oil drain plug.
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447690 06/06/20 12:54 PM
J
JohnG Offline
J
I'd definitely rely on advice from Jiffy Lube guys. My neighbors oil filter fell off after they did the oil change.
OH, we'll put in a new engine....
UH, no we won't it only knocks a little bit.....
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447762 06/06/20 03:09 PM
O
oldhp Offline
O
I use a 6" long wrench, pull it "kinda" tight and give it a open hand smack. Never had a leak in 50 some years changing oil.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Oil Pan Plug Problem [Re: Trav] #5447782 06/06/20 03:44 PM
Yah-Tah-Hey Offline
We don't need a stinking torque wrench.
Re: Oil Pan Plug Problem [Re: JeffKeryk] #5447787 06/06/20 03:52 PM
Chris142 Online Content
Online Content
Originally Posted by JeffKeryk
Love the wrench...
Snap-On flank drive.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5447869 06/06/20 06:09 PM
samven Offline
I imagine every oil drain plug is going into an aluminium casting weather it is or not. I bottom them out and then just a little more unless they use a crushable washer and then just enough to feel it compress. I have never had one come out or leak in 50 years of doing my own changes.
Re: Oil Pan Plug Problem [Re: CarbonSteel] #5448200 06/07/20 09:11 AM
E
Eddie Offline
E
Snug is what I do. After using a torque wrench for 50 years, I am snugging to about 20 ft/lbs. Ed
2014 CX5 Touring 2.5L :-)
