Gas Buddy Card to pay?
by Redright9 - 07/02/20 04:35 AM
Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
28 registered members (BigGeo, Alaskanmont, AlienBug, caprice_2nv, Char Baby, 4WD, 3 invisible), 598 guests, and 25 spiders.
Topics307,389
Posts5,309,631
Members71,821
Mower Engine Got Drenched With Oil #5447488 06/06/20 08:19 AM
V
viscous Offline OP
V
The oil cap on top of my push mower's 6HP B&S engine "unlocks" with a quarter turn has an attached dipstick. Apparently, the oil cap unscrewed and lifted while mowing under some shrubs. This evidently caused oil to spray out the open fill port, onto the underside of the open dipstick cap, and back down onto the engine. Hot oil drenched the motor, entered the rotating screen, and even pooled a bit on the mower deck. The air filter is covered and didn't get sprayed. I didn't notice the problem until excessive smoke started spewing out the muffler. A bit of smoke rose from the top of the engine as well. I only noticed the loose oil cap after allowing the engine to cool. Luckily, the oil level remained in the dipstick's crosshatched area, as it was slightly overfilled to start. The next day, I wiped down the mower (difficult to clean the rotating screen) and started the engine. Smoke began puffing out the muffler within seconds. Is this a problem, or should I just let it run and spew smoke?
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447490 06/06/20 08:24 AM
Driz Offline
Call it home grown rust treatment and use it as always.
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447495 06/06/20 08:29 AM
supton Offline
Heh, I did the same thing just the other day. I don't think I got the dipstick on properly--it has two tabs to lock down on, and I think I only got one.
I'd run it and ignore it. Any oily will just burn off eventually. If worried, run it for a bit in the backyard where no one will see it.
2011 Toyota Camry, base, 2.5L/6MT, 206k
2010 Toyota Tundra DC, 4.6L/6AT, 160k
2003 CRV, 2.4L/4AT, 161k
1999 Toyota Camry LE, 2.2L/4AT, 225k
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447498 06/06/20 08:32 AM
CT8 Offline
Use an engine dergreaser or A simple green type product and wash the engine.
2015 F150 2.7
2018 F350 6.2
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447500 06/06/20 08:32 AM
E
Eddie Offline
E
I did the same thing with my riding mower and lost about a 1/2 quart all over the engine and inside the cowling. I cleaned up with some oil cleaner and a hose wash. The mower still smoked for a while. Just check the oil level and mow.Remind self to double check the oil fill cap. :-)) Ed
2014 CX5 Touring 2.5L :-)
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447548 06/06/20 09:37 AM
danez_yoda Offline
You would not believe what the youtube guys have tried to intentionally kill at B&S lawn mower engine. empty oil and run dry. pour shampoo in the oil chamber. sand down the carb, sand in the crank case. SUGAR in the crank case.
Yes they run like crap but that don't die.
You probably have oil in the carb that is mixing with the gas. it will take a while to burn off but it will eventually. If not, you wont be the only one pushing a smokey lawnmower. To make you feel better, use your art class skills and make a giant cigar to mount to the top of the engine to justify the smoking.
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447617 06/06/20 11:20 AM
H
hemitom Offline
H
YUP..... typical day at the spa , gave the old girl at hot oil treatment.
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447625 06/06/20 11:35 AM
J
jeepman3071 Offline
J
Just wash the engine with a garden hose, it will burn off the rest.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (62k) - Liqui Moly 5w40, MANN HU816X
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5447797 06/06/20 04:13 PM
Slick17601 Offline
Run it till she blows!
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Mower Engine Got Drenched With Oil [Re: Slick17601] #5447804 06/06/20 04:20 PM
V
vw7674 Offline
V
I haven't seen a B&S 6hp blow, a Tecumseh shoot the rod out of the block yes but not a B&S.
For that reason I'd top off the B&S, it takes about 20 oz. from dry to full, & just run it. Till you're too old to cut grass with a push mower.
Re: Mower Engine Got Drenched With Oil [Re: jeepman3071] #5448015 06/06/20 10:19 PM
V
viscous Offline OP
V
Oil may have entered the carburetor by spilling on top of the engine and the rotating screen?
I wiped down the engine exterior, but smoke puffs out the exhaust. Why would that be expected in this scenario?
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5448056 06/06/20 11:59 PM
B
Brian123 Offline
B
You probably still have some oil on the outside of the muffler, did you take the plastic cover off the mower?
Re: Mower Engine Got Drenched With Oil [Re: danez_yoda] #5448068 06/07/20 01:34 AM
V
viscous Offline OP
V
Yes, I removed the plastic cover, wiped the engine, muffler, etc., but I didn't spray it with water as some recommend. The smoke is actually puffing out the exhaust, which I found alarming.
How may oil have entered the carburetor?
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5448132 06/07/20 07:34 AM
supton Offline
There is a feed for oil vapor to go into the engine. If it looks like the one I have, it can be seen once the air filter is removed, just a port going off to somewhere (never pulled apart an OHV B&S yet). Why it would now be sucking oil is beyond me--I still think it's got oil trapped in the exhaust somehow, like it pooled in there.
Re: Mower Engine Got Drenched With Oil [Re: viscous] #5449189 06/08/20 06:06 PM
V
viscous Offline OP
V
Thanks for the info everyone. I'm still not sure why the smoke is actually puffing out the exhaust, rather than just burning off the exterior surfaces. But the consensus seems to be that it's safe to operate, so I guess that's what I'll do.
