Forums Migration
Please read this thread
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Wax / Sealer Recommendations
by 92saturnsl2 - 07/12/20 01:45 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
44 registered members (Bailes1992, avi1777, Autodiculous, Ag76, Alex38, alcyon, 6 invisible), 1,242 guests, and 24 spiders.
Topics307,780
Posts5,317,685
Members71,917
Mobil 1 versus Motul for a 2020 Camry 0w16 #5447405 06/06/20 05:52 AM
A
Amkeer Offline OP
A
With these lower viscosity oils such as 0w16 I am considering using Motul in my new 2020 Camry. I have been a loyal Mobil 1 user for many years and may still stick with the 0w16 from them, however, with this new ride is Motul a consideration? I will be sticking with the 10,000 mile intervals. I am also trying to decide when I should drain this factory fill?
https://www.motul.com/us/en-US/products/hybrid-0w16
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-0w16/
I was also thinking about 0w20, but see no real benefit at this point in using it. Thoughts?
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447407 06/06/20 05:55 AM
I
Imp4 Offline
I
Does the Motul meet the manufacturer recommendations?
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447413 06/06/20 06:16 AM
A
Amkeer Offline OP
A
Oil grade: API SN/RC multigrade engine oil
It also has a 4.8 quart capacity. Motul comes in a gallon size and Mobil 1 in 5 quart.
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447437 06/06/20 07:11 AM
Astro14 Offline
For convenience (one jug vs. one jug and an extra quart) as well as cost, I would go with the MOBIL 1
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447440 06/06/20 07:12 AM
7
77Se7en Offline
7
Your owners manual gives you a 0w16 or 0w20 option for the entire warranty period? Or does it say you can 0w20 for "one time use' - then requires 0w16 again?
Spiritual Intuitive / Whisperer-Medium (Involuntary & Non-Profit)
Valvoline ME, Mobil-1 EP & Pennzoil Ultra Platinum 5w30s
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447442 06/06/20 07:16 AM
Cujet Offline
There may not be much, if any, real world difference. I'd choose the M1, just due to the fact that it's available anywhere, anytime. Some Motul products are simply exact copies of Mobil 1 products....
I'd also suggest you change it more frequently than 10K miles.
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447446 06/06/20 07:18 AM
Astro14 Offline
From the OM:
■ Engine oil selection
 2.5 L 4-cylinder (A25A-FKS) engine
“Toyota Genuine Motor Oil” is used in your Toyota vehicle. Use Toyota approved “Toyota Genuine Motor Oil” or equivalent to sat- isfy the following grade and viscosity.
Recommended viscosity: SAE 0W-16
SAE 0W-16 is the best choice for good fuel economy and good start- ing in cold weather.
If SAE 0W-16 is not available, SAE 0W-20 oil may be used. However, it must be replaced with SAE 0W- 16 at the next oil change.
Oil viscosity (0W-16 is explained here as an example):
• The 0W in 0W-16 indicates the characteristic of the oil which allows cold startability. Oils with a lower value before the W allow for easier starting of the engine in cold weather.
• The 16 in 0W-16 indicates the viscosity characteristic of the oil when the oil is at high temperature. An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447462 06/06/20 07:40 AM
A
ARCOgraphite Offline
A
I have Motul VW 508 (a real majority) PAO synthetic in my Jetta, it's a good oil, but its too thin and the engine ran bad on it and started drinking it. When it was down a half liter I put some Mobil 1 0W40 FS in there ( I had purchased it for an oil change on my Generac 5000) Previously teh dealer has incorrectly put 5W40 in it and that was too thick!
Well the engine responded surprisingly to the small increase in viscosity and has run well since and has not used oil at a high rate.
This is only a 1.4 L Turbo DI motor with a favourable aspect ratio to the piston, but long stroke.
IN your Toyota 2.5 I would expect things to be much worse as this is basically 1/2 of a 302 V8.
I would use Mobil 1 AP 0W20 and if it noisy after break in - supplement it with the M1 0W40.
This is the way of the world and the way of a good mechanic and engine tuner.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447477 06/06/20 08:00 AM
K
krismoriah72 Offline
K
"The 0W in 0W-16 indicates the characteristic of the oil which allows cold startability. Oils with a lower value before the W allow for easier starting of the engine in cold weather."
Its not cold weather now and wont be for awhile.
"The 16 in 0W-16 indicates the viscosity characteristic of the oil when the oil is at high temperature. An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions."
My brain says 20 or 30..
So my translation from Toyota is.. 5w20/5w30 in summer/fall 0w20/0w30 in winter. and 0w40 sounds like a good year round oil.
I doubt i would ever buy 0w16 to keep the CAFE folks happy.
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447481 06/06/20 08:05 AM
K
kschachn Offline
K
What does your owner's manual say?
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447494 06/06/20 08:28 AM
CT8 Offline
Despite all the marketing claims , what does oil do? It keeps the parts separated bottom line , then it has additives to do certain things prevent wear when the oil film is not thick enough on certain parts and to make the oil last longer in the engine. If you buy oil from a well known major company with the proper ratings will allow long engine life I have seem more Toyota Camrys with 350,000+ miles running fine running quick change oils and filters.
2015 F150 2.7
2018 F350 6.2
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5447748 06/06/20 02:33 PM
Direct_Rejection Offline
M1 >> Motul.
All day.
2019 Lexus UX 250h F-Sport
HPL HD 0W16 SL
@ 64k miles
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: CT8] #5448194 06/07/20 09:05 AM
A
A
And they are running a 30 grade.
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Direct_Rejection] #5448198 06/07/20 09:09 AM
A
A
Originally Posted by Direct_Rejection
M1 >> Motul.
All day.
It depend if you want a real synthetic oil.
Many Mobil grades are not.
Not saying that make a 8100 series Motul the "cat's meow".
Just that you get what you are paying for - or at least what the label says you bought.
You don't get that in the USA. Big Corporate Lies. NA they are all to blame - and the un-eductaed consumer.
Re: Mobil 1 versus Motul for a 2020 Camry 0w16 [Re: Amkeer] #5448219 06/07/20 09:37 AM
7
77Se7en Offline
7
Yep, I'd choose Motul over Mobil-1 Vanilla also.
The only Mobil-1s that interest me are the new Mobil-1 EP and ESP.
