Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
electro, SilentC, paolo9fla, SunnyB, Mullady76
71849 Registered Users
91 registered members (77GrandPrix, 928, Astro14, 4WD, antonmnster, Atrocious, 10 invisible), 2,188 guests, and 25 spiders.
Topics307,445
Posts5,311,327
Members71,849
2 stroke oil #5447143 06/05/20 06:19 PM
O
opus Offline OP
O
I have 2 gallons of brand name 2 cycle outboard engine oil. Equivalent quality for a chainsaw, string trimmer, etc?
Re: 2 stroke oil [Re: opus] #5447146 06/05/20 06:26 PM
M
motor_oil_madman Offline
M
You can't use outboard oil in a 2 stroke.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 2 stroke oil [Re: opus] #5447151 06/05/20 06:30 PM
O
opus Offline OP
O
2 stroke outboard oil cannot be used in any other 2 stroke engine? Whats so different about it?
Re: 2 stroke oil [Re: motor_oil_madman] #5447154 06/05/20 06:34 PM
B
Brian123 Online Content
Online Content
B
Basically you should not use outboard 2 stroke oil in a chainsaw or trimmer. There are some who say that you can use tcw-3 2 stroke oil in a trimmer or chainsaw but you need to run the mix at either 40 to 1 or 32 to 1
Re: 2 stroke oil [Re: opus] #5447160 06/05/20 06:41 PM
O
opus Offline OP
O
Well who knew! Great, thanks...to the trash it goes.
Re: 2 stroke oil [Re: opus] #5447161 06/05/20 06:48 PM
9
97prizm Offline
9
Outboard 2 Stroke Oil is designed for water cooled engines. I used it in my cheap junk Poulan trimmer and it left ALOT of carbon build up on the piston.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: 2 stroke oil [Re: opus] #5447172 06/05/20 07:11 PM
Chris142 Offline
I can use it in my truck as lube for my fuel.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 2 stroke oil [Re: opus] #5447189 06/05/20 07:42 PM
M
M
They do have multi use oils, but I have my doubts about the quality. Usually it's some cheap stuff found at the gas station.
Re: 2 stroke oil [Re: opus] #5447197 06/05/20 08:00 PM
2
2004tdigls Offline
2
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwijzpOa_uvpAhVPpZ4KHSSvBHI4ChAWMAN6BAgDEAE&url=http%3A%2F%2Fwww.comolube.com%2Fwp-content%2Fuploads%2F2017%2F05%2FOutboard-vs.-Snowmobile.pdf&usg=AOvVaw3fJYIBPmpOl6Snu5Wy8Bf9
Re: 2 stroke oil [Re: opus] #5447203 06/05/20 08:09 PM
W
WobblyElvis Offline
W
I have been using outboard 2 stroke oil TCW3 in my chainsaw and string trimmer for 40 years without any problems. l like to live on the edge.
Re: 2 stroke oil [Re: WobblyElvis] #5447222 06/05/20 08:31 PM
G
GSCJR Offline
G
Originally Posted by WobblyElvis
I have been using outboard 2 stroke oil TCW3 in my string trimmer for years without any problems.
+1
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: 2 stroke oil [Re: WobblyElvis] #5447260 06/05/20 09:17 PM
R
rubberchicken Offline
R
I also have been using 2 stroke outboard oil in my OPE for 30 years. In my mind the outboard oil is better.
Re: 2 stroke oil [Re: WobblyElvis] #5447261 06/05/20 09:18 PM
N
nwjones18 Offline
N
You and me both (only about 10yrs for me) .. No problems here
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: 2 stroke oil [Re: opus] #5447300 06/05/20 10:30 PM
chainblu Offline
In the early '90s, my brother's (now ex) FIL gave me several qts of Quaker State outboard oil along with a leaf blower and a 'weed eater' (whipper snipper for the Aussies). Have used nothing but that oil and both are still running strong.
Re: 2 stroke oil [Re: opus] #5447341 06/05/20 11:54 PM
dwendt44 Offline
Outboard engines are thermostat at 140°. Air cooled saws and trimmers run
a good deal hotter. A richer(oil) might get you through though.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
